Hello all,
I am working on DM6446 building codec run remotely on the DSP using codec engine framework.
I am working using the videnc_copy example with the arm application in the examples to run the videnc_copy codec (runs remotely on dsp) using video thread that calls the encoder
I want to use two videnc_copy codecs each one runs through a thread.
i made a copy for videnc_copy codec and build it successfully, then added the two codecs (the original and the copy) to the codec.cfg for the server successfully.
My problem is from the ARM application how to distinguish between the two codecs, how to invoke each one separately.
