I am new to the entire Yocto build system and just trying to catch up.
In an effort to communicate to DSP, after reading through TI documentation, it looks like I need to add IPC 3.x support for dra7xx processor.
And as I understood ti-glsdk already has IPC 3.x integrated and if I use ti-glsdk I don't need to install IPC 3.x separately.
Currently I am seeing IPC under both meta-ti and meta-ti-glsdk in the yocto build system based repo that I am using. My question is what is the purpose of having two IPC folders and which one should I be using?
In addition to that, are there any advantages/disadvantages of using ti-glsdk vs installing IPC seperately?
Thanks.
