I'm using OMAP-L138, Kernel version 3.3.0 (mcsdk), and custom board. If my USB drive is inserted when arm boots, everything works good and usb drive is accessible.
However, if I insert the USB drive after boot is complete, there is no /dev/sdax directory and i get a udevd error instead.
root@arago:~# [ 24.657514] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 24.800775] usb 1-1: New USB device found, idVendor=154b, idProduct=005b
[ 24.808806] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 24.816009] usb 1-1: Product: USB 2.0 FD
[ 24.820888] usb 1-1: Manufacturer: PNY Technologies
[ 24.825823] usb 1-1: SerialNumber: AA00000000000575
[ 24.850936] scsi0 : usb-storage 1-1:1.0
[ 35.261666] scsi 0:0:0:0: Direct-Access PNY USB 2.0 FD 1100 PQ: 0 ANSI: 4
[ 35.292982] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 35.311946] sd 0:0:0:0: [sda] 63901440 512-byte logical blocks: (32.7 GB/30.4 GiB)
[ 35.359428] sd 0:0:0:0: [sda] Write Protect is off
[ 35.366147] sd 0:0:0:0: [sda] No Caching mode page present
[ 35.399308] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 35.447868] sd 0:0:0:0: [sda] No Caching mode page present
[ 35.453422] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 35.469913] sda: sda1
[ 35.501162] sd 0:0:0:0: [sda] No Caching mode page present
[ 35.506723] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 35.545873] sd 0:0:0:0: [sda] Attached SCSI removable disk
udevd[499]: worker [517] unexpectedly returned with status 0x0100
udevd[499]: worker [517] failed while handling '/devices/platform/musb-da8xx/musb-hdrc/usb1/1-1/1-1:1.0/host0/target0:0:0/0:0:0:0/block/sda'
I have attached boot log w/ USB inserted before and after boot so you can see the difference.
Loading UBL PRU IS RUNNING!!!! Booting with TI UBL Device OPP (300MHz, 1.2V) Booting Catalog Boot Loader BootMode = SPI 1 Flash 32 bit Address Copying U-Boot from SPI to 0xC1008000... FHB Validated ... Complete Copying FileSystem from SPI to 0xC1800000... FHB Validated ... Complete Copying uImage from SPI to 0xC3000000... FHB Validated ... Complete All images validated and loaded. Jumping to entry point at at 0xC1080000... U-Boot 2012.04.01-svn2297 (Apr 02 2015 - 08:19:38) DRAM: 64 MiB WARNING: Caches not enabled Using default environment In: serial Out: serial Err: serial Net: DaVinci-EMAC Hit any key to stop autoboot: 0 ## Booting kernel from Legacy Image at c3000000 ... Image Name: Linux-3.3.0 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2124232 Bytes = 2 MiB Load Address: c1008000 Entry Point: c1008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Linux version 3.3.0 (dan@DWAYER-UBUNTU) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #28 PREEMPT Tue Apr 14 15:47:45 CDT 2015 [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 [ 0.000000] CPU: VIVT data cache, VIVT instruction cache [ 0.000000] Machine: AMSC NGCC board [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] BUG: mapping for 0x80000000 at 0xfffe0000 out of vmalloc space [ 0.000000] DaVinci da850/amsc-ngcc/am18x variant 0x1 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 10160 [ 0.000000] Kernel command line: mem=40M@0xC1000000 console=ttyS0,115200n8 root=/dev/ram0 rw initrd=0xC1800000,6MB [ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes) [ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Memory: 40MB = 40MB total [ 0.000000] Memory: 29944k/29944k available, 11016k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xc3000000 - 0xff000000 ( 960 MB) [ 0.000000] lowmem : 0xc0000000 - 0xc2800000 ( 40 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc03ed000 (3988 kB) [ 0.000000] .init : 0xc03ed000 - 0xc0410000 ( 140 kB) [ 0.000000] .data : 0xc0410000 - 0xc043a5e0 ( 170 kB) [ 0.000000] .bss : 0xc043a604 - 0xc0458fac ( 123 kB) [ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] NR_IRQS:245 [ 0.000000] Console: colour dummy device 80x30 [ 0.000290] Calibrating delay loop... 227.32 BogoMIPS (lpj=1136640) [ 0.080050] pid_max: default: 32768 minimum: 301 [ 0.080594] Mount-cache hash table entries: 512 [ 0.081614] CPU: Testing write buffer coherency: ok [ 0.082273] Setting up static identity map for 0xc12fc200 - 0xc12fc23c [ 0.086270] gpiochip_add: registered GPIOs 0 to 31 on device: DaVinci [ 0.086325] gpiochip_add: registered GPIOs 32 to 63 on device: DaVinci [ 0.086364] gpiochip_add: registered GPIOs 64 to 95 on device: DaVinci [ 0.086402] gpiochip_add: registered GPIOs 96 to 127 on device: DaVinci [ 0.086438] gpiochip_add: registered GPIOs 128 to 143 on device: DaVinci [ 0.086949] DaVinci: 144 gpio irqs [ 0.087898] NET: Registered protocol family 16 [ 0.163652] bio: create slab <bio-0> at 0 [ 0.169767] SCSI subsystem initialized [ 0.173595] usbcore: registered new interface driver usbfs [ 0.174447] usbcore: registered new interface driver hub [ 0.175418] usbcore: registered new device driver usb [ 0.187117] DMA-API: preallocated 4096 debug entries [ 0.187157] DMA-API: debugging enabled by kernel config [ 0.187231] Switching to clocksource timer0_1 [ 0.251191] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host) [ 0.251414] musb-hdrc musb-hdrc: dma type: dma-cppi41 [ 0.252321] MUSB255 controller's USBSS revision = 4ea11003 [ 0.252360] Waiting for USB PHY clock good... [ 0.268015] [ 0.268024] MUSB_devinit [ 0.268033] [ 0.268052] [ 0.268061] MUSB_devinit [ 0.268071] [ 0.268087] [ 0.268095] MUSB_devinit [ 0.268104] [ 0.268119] [ 0.268126] MUSB_devinit [ 0.268136] [ 0.268150] [ 0.268158] MUSB_devinit [ 0.268168] [ 0.268181] [ 0.268189] MUSB_devinit [ 0.268199] [ 0.268213] [ 0.268221] MUSB_devinit [ 0.268230] [ 0.268360] musb-hdrc musb-hdrc: MUSB HDRC host driver [ 0.268470] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1 [ 0.268863] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.268902] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.268937] usb usb1: Product: MUSB HDRC host driver [ 0.268965] usb usb1: Manufacturer: Linux 3.3.0 musb-hcd [ 0.268994] usb usb1: SerialNumber: musb-hdrc [ 0.271294] hub 1-0:1.0: USB hub found [ 0.271385] hub 1-0:1.0: 1 port detected [ 0.271727] [ 0.271740] MUSB_START [ 0.271750] [ 0.272308] musb-hdrc musb-hdrc: USB Host mode controller at fee00000 using DMA, IRQ 58 [ 0.273689] NET: Registered protocol family 2 [ 0.274121] IP route cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.274975] TCP established hash table entries: 2048 (order: 2, 16384 bytes) [ 0.275110] TCP bind hash table entries: 2048 (order: 1, 8192 bytes) [ 0.275197] TCP: Hash tables configured (established 2048 bind 2048) [ 0.275227] TCP reno registered [ 0.275264] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.275328] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.275968] NET: Registered protocol family 1 [ 0.277191] RPC: Registered named UNIX socket transport module. [ 0.277238] RPC: Registered udp transport module. [ 0.277267] RPC: Registered tcp transport module. [ 0.277497] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.278157] Trying to unpack rootfs image as initramfs... [ 0.280702] rootfs image is not initramfs (no cpio magic); looks like an initrd [ 0.376724] Freeing initrd memory: 6144K [ 0.462192] JFFS2 version 2.2. (NAND) � 2001-2006 Red Hat, Inc. [ 0.469243] io scheduler noop registered (default) [ 0.483397] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled [ 0.488109] serial8250.0: ttyS0 at MMIO 0x1c42000 (irq = 25) is a AR7 [ 1.004336] console [ttyS0] enabled [ 1.009610] serial8250.0: ttyS1 at MMIO 0x1d0c000 (irq = 53) is a AR7 [ 1.017975] serial8250.0: ttyS2 at MMIO 0x1d0d000 (irq = 61) is a AR7 [ 1.028688] brd: module loaded [ 1.038192] st: Version 20101219, fixed bufsize 32768, s/g segs 256 [ 1.045917] osst :I: Tape driver with OnStream support version 0.99.4 [ 1.045947] osst :I: $Id: osst.c,v 1.73 2005/01/01 21:13:34 wriede Exp $ [ 1.063593] SCSI Media Changer driver v0.25 [ 1.075379] spi_davinci spi_davinci.1: DMA: supported [ 1.081043] spi_davinci spi_davinci.1: DMA: RX channel: 18, TX channel: 19, event queue: 0 [ 1.091483] m25p80 spi1.0: unrecognized id n25q256 [ 1.096482] ------------[ cut here ]------------ [ 1.101178] WARNING: at lib/dma-debug.c:866 check_unmap+0x188/0x704() [ 1.107666] NULL NULL: DMA-API: device driver tries to free DMA memory it has not allocated [device address=0x00000000c304b340] [size=1 bytes] [ 1.120500] Modules linked in: [ 1.123573] Backtrace: [ 1.126095] [<c000c140>] (dump_backtrace+0x0/0x110) from [<c02f98d8>] (dump_stack+0x18/0x1c) [ 1.134580] r6:c03a252d r5:00000362 r4:c203bdd8 r3:c041aac0 [ 1.140350] [<c02f98c0>] (dump_stack+0x0/0x1c) from [<c0017560>] (warn_slowpath_common+0x54/0x6c) [ 1.149301] [<c001750c>] (warn_slowpath_common+0x0/0x6c) from [<c001761c>] (warn_slowpath_fmt+0x38/0x40) [ 1.158827] r8:00000001 r7:00000001 r6:00000000 r5:00000000 r4:c203be40 [ 1.165421] r3:00000009 [ 1.168087] [<c00175e4>] (warn_slowpath_fmt+0x0/0x40) from [<c0197e10>] (check_unmap+0x188/0x704) [ 1.177001] r3:c03c94dd r2:c03a2a4f [ 1.180635] [<c0197c88>] (check_unmap+0x0/0x704) from [<c0198464>] (debug_dma_unmap_page+0x6c/0x78) [ 1.189724] r5:c304b340 r4:00000001 [ 1.193375] [<c01983f8>] (debug_dma_unmap_page+0x0/0x78) from [<c020b914>] (davinci_spi_bufs+0x558/0x7fc) [ 1.202991] r8:00000021 r7:c304b340 r6:00000000 r5:c2029b7c r4:c1bbfee0 [ 1.209799] [<c020b3bc>] (davinci_spi_bufs+0x0/0x7fc) from [<c020ab3c>] (bitbang_work+0x168/0x2c0) [ 1.218834] [<c020a9d4>] (bitbang_work+0x0/0x2c0) from [<c002c164>] (process_one_work+0x234/0x398) [ 1.227866] [<c002bf30>] (process_one_work+0x0/0x398) from [<c002e700>] (worker_thread+0x200/0x33c) [ 1.236992] [<c002e500>] (worker_thread+0x0/0x33c) from [<c00323a8>] (kthread+0x94/0xa0) [ 1.245165] [<c0032314>] (kthread+0x0/0xa0) from [<c001aa0c>] (do_exit+0x0/0x6f8) [ 1.252686] r6:c001aa0c r5:c0032314 r4:c2029f08 [ 1.257424] ---[ end trace c63a4532fdc1786f ]--- [ 1.262664] m25p80 spi1.0: found n25q256a, expected m25p80 [ 1.268590] m25p80 spi1.0: n25q256a (32768 Kbytes) [ 1.274838] Creating 15 MTD partitions on "m25p80": [ 1.280040] 0x000000000000-0x000000040000 : "Stage1" [ 1.289526] 0x000000040000-0x000000140000 : "Stage2" [ 1.299293] 0x000000140000-0x000000180000 : "NVRAM" [ 1.308587] 0x000000180000-0x0000001c0000 : "Mfg Dflts" [ 1.318339] 0x0000001c0000-0x000000200000 : "Params" [ 1.327839] 0x000000200000-0x000000300000 : "Stage3" [ 1.337129] 0x000000300000-0x000000500000 : "FPGA" [ 1.346538] 0x000000500000-0x000000900000 : "TestAppDSP" [ 1.356524] 0x000000900000-0x000000d00000 : "AppDSP" [ 1.366289] 0x000000d00000-0x000000d40000 : "TestAppParams" [ 1.376542] 0x000000d40000-0x000000d80000 : "UBL" [ 1.385935] 0x000000d80000-0x000000e80000 : "U-boot" [ 1.395522] 0x000000e80000-0x000001280000 : "UImage" [ 1.405272] 0x000001280000-0x000001880000 : "LinuxInitFS" [ 1.415416] 0x000001880000-0x000001c80000 : "LinuxUserFS" [ 1.421218] usb 1-1: new high-speed USB device number 2 using musb-hdrc [ 1.433326] spi_davinci spi_davinci.1: Controller at 0xfef0e000 [ 1.447081] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.455270] usbcore: registered new interface driver uas [ 1.460953] Initializing USB Mass Storage driver... [ 1.466687] usbcore: registered new interface driver usb-storage [ 1.473017] USB Mass Storage support registered. [ 1.477794] i2c /dev entries driver [ 1.482287] TCP cubic registered [ 1.485570] NET: Registered protocol family 17 [ 1.494104] console [netcon0] enabled [ 1.498132] netconsole: network logging started [ 1.504539] RAMDISK: gzip image found at block 0 [ 1.570675] usb 1-1: New USB device found, idVendor=154b, idProduct=005b [ 1.587453] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 1.594654] usb 1-1: Product: USB 2.0 FD [ 1.607439] usb 1-1: Manufacturer: PNY Technologies [ 1.612378] usb 1-1: SerialNumber: AA00000000000575 [ 1.639140] scsi0 : usb-storage 1-1:1.0 [ 3.298281] VFS: Mounted root (ext2 filesystem) on device 1:0. [ 3.304870] Freeing init memory: 140K INIT: version 2.86 booting Please wait: booting... Starting udev WARNING: -e needs -E or -F [ 6.307994] DMA-API: debugging out of memory - disabling Remounting root file system... Caching udev devnodes Populating dev cache root: mount: mounting rootfs on / failed: No such file or directory root: mount: mounting usbfs on /proc/bus/usb failed: No such file or directory Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device done. Setting up IP spoofing protection: rp_filter. hwclock: can't open '/dev/misc/rtc': No such file or directory Tue Aug 5 19:16:00 UTC 2014 hwclock: can't open '/dev/misc/rtc': No such file or directory INIT: Entering runlevel: 5 Starting telnet daemon. Starting syslogd/klogd: done Copying userfs from /dev/mtd14 to /usr/userfs.tar.gz... Attempting to open /dev/mtd14 device! File access to /dev/mtd14 created! Attempting to open /usr/userfs.tar.gz ! /usr/userfs.tar.gz created! Attempting to read /dev/mtd14 ! Read from /dev/mtd14 succeeded ! magic: 0x42484641 infoBlockOffset: 0x0000468A infoBlockLength: 0x00000410 infoBlockSignature: 0x4017096D imageOffset: 0x00000020 imageLength: 0x0000466A imageSignature: 0x5BEE4049 fhbSignature: 0xC351301C FHB Magic Number correct FHB CRC correct FHB read successfully Program image copied successfully! Image CRC correct Program image read successfully Closing file: /usr/userfs.tar.gz ! Closing file: /dev/mtd14 ! Complete. User Application Starting... Hello World, from the user application! User Application Complete... [ 12.020638] scsi 0:0:0:0: Direct-Access PNY USB 2.0 FD 1100 PQ: 0 ANSI: 4 [ 12.049673] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 12.077019] sd 0:0:0:0: [sda] 63901440 512-byte logical blocks: (32.7 GB/30.4 GiB) [ 12.103071] sd 0:0:0:0: [sda] Write Protect is off [ 12.127535] sd 0:0:0:0: [sda] No Caching mode page present [ 12.133086] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 12.196622] sd 0:0:0:0: [sda] No Caching mode page present [ 12.207487] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 12.227536] sda: sda1 [ 12.259682] sd 0:0:0:0: [sda] No Caching mode page present [ 12.265223] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 12.297514] sd 0:0:0:0: [sda] Attached SCSI removable disk _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org arago ttyS0 Arago 2011.09 arago ttyS0 arago login: root login[791]: root login on `ttyS0' root@arago:~# ls /dev autofs mtd2ro mtdblock8 tty11 tty37 tty62 block mtd3 mtdblock9 tty12 tty38 tty63 bus mtd3ro null tty13 tty39 tty7 char mtd4 pktcdvd tty14 tty4 tty8 console mtd4ro ptmx tty15 tty40 tty9 disk mtd5 pts tty16 tty41 ttyS0 fd mtd5ro ptyp0 tty17 tty42 ttyS1 full mtd6 ptyp1 tty18 tty43 ttyS2 initctl mtd6ro ptyp2 tty19 tty44 ttyp0 kmem mtd7 ptyp3 tty2 tty45 ttyp1 kmsg mtd7ro ptyp4 tty20 tty46 ttyp2 log mtd8 ptyp5 tty21 tty47 ttyp3 mem mtd8ro ptyp6 tty22 tty48 ttyp4 mtd0 mtd9 ptyp7 tty23 tty49 ttyp5 mtd0ro mtd9ro ram0 tty24 tty5 ttyp6 mtd1 mtdblock0 random tty25 tty50 ttyp7 mtd10 mtdblock1 sda tty26 tty51 ubi_ctrl mtd10ro mtdblock10 sda1 tty27 tty52 urandom mtd11 mtdblock11 sg0 tty28 tty53 vcs mtd11ro mtdblock12 shm tty29 tty54 vcs1 mtd12 mtdblock13 stderr tty3 tty55 vcsa mtd12ro mtdblock14 stdin tty30 tty56 vcsa1 mtd13 mtdblock2 stdout tty31 tty57 zero mtd13ro mtdblock3 tgt tty32 tty58 mtd14 mtdblock4 tty tty33 tty59 mtd14ro mtdblock5 tty0 tty34 tty6 mtd1ro mtdblock6 tty1 tty35 tty60 mtd2 mtdblock7 tty10 tty36 tty61 root@arago:~#
Loading UBL PRU IS RUNNING!!!! Booting with TI UBL Device OPP (300MHz, 1.2V) Booting Catalog Boot Loader BootMode = SPI 1 Flash 32 bit Address Copying U-Boot from SPI to 0xC1008000... FHB Validated ... Complete Copying FileSystem from SPI to 0xC1800000... FHB Validated ... Complete Copying uImage from SPI to 0xC3000000... FHB Validated ... Complete All images validated and loaded. Jumping to entry point at at 0xC1080000... U-Boot 2012.04.01-svn2297 (Apr 02 2015 - 08:19:38) DRAM: 64 MiB WARNING: Caches not enabled Using default environment In: serial Out: serial Err: serial Net: DaVinci-EMAC Hit any key to stop autoboot: 0 ## Booting kernel from Legacy Image at c3000000 ... Image Name: Linux-3.3.0 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2124232 Bytes = 2 MiB Load Address: c1008000 Entry Point: c1008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Linux version 3.3.0 (dan@DWAYER-UBUNTU) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #28 PREEMPT Tue Apr 14 15:47:45 CDT 2015 [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 [ 0.000000] CPU: VIVT data cache, VIVT instruction cache [ 0.000000] Machine: AMSC NGCC board [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] BUG: mapping for 0x80000000 at 0xfffe0000 out of vmalloc space [ 0.000000] DaVinci da850/amsc-ngcc/am18x variant 0x1 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 10160 [ 0.000000] Kernel command line: mem=40M@0xC1000000 console=ttyS0,115200n8 root=/dev/ram0 rw initrd=0xC1800000,6MB [ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes) [ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Memory: 40MB = 40MB total [ 0.000000] Memory: 29944k/29944k available, 11016k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xc3000000 - 0xff000000 ( 960 MB) [ 0.000000] lowmem : 0xc0000000 - 0xc2800000 ( 40 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc03ed000 (3988 kB) [ 0.000000] .init : 0xc03ed000 - 0xc0410000 ( 140 kB) [ 0.000000] .data : 0xc0410000 - 0xc043a5e0 ( 170 kB) [ 0.000000] .bss : 0xc043a604 - 0xc0458fac ( 123 kB) [ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] NR_IRQS:245 [ 0.000000] Console: colour dummy device 80x30 [ 0.000290] Calibrating delay loop... 227.32 BogoMIPS (lpj=1136640) [ 0.080050] pid_max: default: 32768 minimum: 301 [ 0.080593] Mount-cache hash table entries: 512 [ 0.081615] CPU: Testing write buffer coherency: ok [ 0.082272] Setting up static identity map for 0xc12fc200 - 0xc12fc23c [ 0.086269] gpiochip_add: registered GPIOs 0 to 31 on device: DaVinci [ 0.086323] gpiochip_add: registered GPIOs 32 to 63 on device: DaVinci [ 0.086362] gpiochip_add: registered GPIOs 64 to 95 on device: DaVinci [ 0.086400] gpiochip_add: registered GPIOs 96 to 127 on device: DaVinci [ 0.086436] gpiochip_add: registered GPIOs 128 to 143 on device: DaVinci [ 0.086947] DaVinci: 144 gpio irqs [ 0.087896] NET: Registered protocol family 16 [ 0.163729] bio: create slab <bio-0> at 0 [ 0.169793] SCSI subsystem initialized [ 0.173622] usbcore: registered new interface driver usbfs [ 0.174479] usbcore: registered new interface driver hub [ 0.175446] usbcore: registered new device driver usb [ 0.187162] DMA-API: preallocated 4096 debug entries [ 0.187203] DMA-API: debugging enabled by kernel config [ 0.187276] Switching to clocksource timer0_1 [ 0.251213] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host) [ 0.251436] musb-hdrc musb-hdrc: dma type: dma-cppi41 [ 0.252342] MUSB255 controller's USBSS revision = 4ea11003 [ 0.252380] Waiting for USB PHY clock good... [ 0.268058] [ 0.268066] MUSB_devinit [ 0.268076] [ 0.268095] [ 0.268105] MUSB_devinit [ 0.268114] [ 0.268130] [ 0.268138] MUSB_devinit [ 0.268149] [ 0.268163] [ 0.268170] MUSB_devinit [ 0.268180] [ 0.268195] [ 0.268203] MUSB_devinit [ 0.268213] [ 0.268226] [ 0.268234] MUSB_devinit [ 0.268244] [ 0.268258] [ 0.268266] MUSB_devinit [ 0.268275] [ 0.268407] musb-hdrc musb-hdrc: MUSB HDRC host driver [ 0.268523] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1 [ 0.268920] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.268959] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.268995] usb usb1: Product: MUSB HDRC host driver [ 0.269024] usb usb1: Manufacturer: Linux 3.3.0 musb-hcd [ 0.269053] usb usb1: SerialNumber: musb-hdrc [ 0.271339] hub 1-0:1.0: USB hub found [ 0.271435] hub 1-0:1.0: 1 port detected [ 0.271783] [ 0.271796] MUSB_START [ 0.271806] [ 0.272367] musb-hdrc musb-hdrc: USB Host mode controller at fee00000 using DMA, IRQ 58 [ 0.273741] NET: Registered protocol family 2 [ 0.274174] IP route cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.275047] TCP established hash table entries: 2048 (order: 2, 16384 bytes) [ 0.275182] TCP bind hash table entries: 2048 (order: 1, 8192 bytes) [ 0.275270] TCP: Hash tables configured (established 2048 bind 2048) [ 0.275301] TCP reno registered [ 0.275340] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.275408] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.276050] NET: Registered protocol family 1 [ 0.277266] RPC: Registered named UNIX socket transport module. [ 0.277316] RPC: Registered udp transport module. [ 0.277546] RPC: Registered tcp transport module. [ 0.277586] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.278236] Trying to unpack rootfs image as initramfs... [ 0.280770] rootfs image is not initramfs (no cpio magic); looks like an initrd [ 0.376726] Freeing initrd memory: 6144K [ 0.462126] JFFS2 version 2.2. (NAND) � 2001-2006 Red Hat, Inc. [ 0.469178] io scheduler noop registered (default) [ 0.483370] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled [ 0.488085] serial8250.0: ttyS0 at MMIO 0x1c42000 (irq = 25) is a AR7 [ 1.003917] console [ttyS0] enabled [ 1.009188] serial8250.0: ttyS1 at MMIO 0x1d0c000 (irq = 53) is a AR7 [ 1.017552] serial8250.0: ttyS2 at MMIO 0x1d0d000 (irq = 61) is a AR7 [ 1.028272] brd: module loaded [ 1.037729] st: Version 20101219, fixed bufsize 32768, s/g segs 256 [ 1.045468] osst :I: Tape driver with OnStream support version 0.99.4 [ 1.045498] osst :I: $Id: osst.c,v 1.73 2005/01/01 21:13:34 wriede Exp $ [ 1.063165] SCSI Media Changer driver v0.25 [ 1.074968] spi_davinci spi_davinci.1: DMA: supported [ 1.080543] spi_davinci spi_davinci.1: DMA: RX channel: 18, TX channel: 19, event queue: 0 [ 1.090966] m25p80 spi1.0: unrecognized id n25q256 [ 1.095968] ------------[ cut here ]------------ [ 1.100666] WARNING: at lib/dma-debug.c:866 check_unmap+0x188/0x704() [ 1.107156] NULL NULL: DMA-API: device driver tries to free DMA memory it has not allocated [device address=0x00000000c304b340] [size=1 bytes] [ 1.119990] Modules linked in: [ 1.123064] Backtrace: [ 1.125586] [<c000c140>] (dump_backtrace+0x0/0x110) from [<c02f98d8>] (dump_stack+0x18/0x1c) [ 1.134070] r6:c03a252d r5:00000362 r4:c203bdd8 r3:c041aac0 [ 1.139842] [<c02f98c0>] (dump_stack+0x0/0x1c) from [<c0017560>] (warn_slowpath_common+0x54/0x6c) [ 1.148792] [<c001750c>] (warn_slowpath_common+0x0/0x6c) from [<c001761c>] (warn_slowpath_fmt+0x38/0x40) [ 1.158316] r8:00000001 r7:00000001 r6:00000000 r5:00000000 r4:c203be40 [ 1.164911] r3:00000009 [ 1.167580] [<c00175e4>] (warn_slowpath_fmt+0x0/0x40) from [<c0197e10>] (check_unmap+0x188/0x704) [ 1.176496] r3:c03c94dd r2:c03a2a4f [ 1.180126] [<c0197c88>] (check_unmap+0x0/0x704) from [<c0198464>] (debug_dma_unmap_page+0x6c/0x78) [ 1.189216] r5:c304b340 r4:00000001 [ 1.192866] [<c01983f8>] (debug_dma_unmap_page+0x0/0x78) from [<c020b914>] (davinci_spi_bufs+0x558/0x7fc) [ 1.202482] r8:00000021 r7:c304b340 r6:00000000 r5:c2029b7c r4:c1bbdee0 [ 1.209290] [<c020b3bc>] (davinci_spi_bufs+0x0/0x7fc) from [<c020ab3c>] (bitbang_work+0x168/0x2c0) [ 1.218325] [<c020a9d4>] (bitbang_work+0x0/0x2c0) from [<c002c164>] (process_one_work+0x234/0x398) [ 1.227356] [<c002bf30>] (process_one_work+0x0/0x398) from [<c002e700>] (worker_thread+0x200/0x33c) [ 1.236478] [<c002e500>] (worker_thread+0x0/0x33c) from [<c00323a8>] (kthread+0x94/0xa0) [ 1.244648] [<c0032314>] (kthread+0x0/0xa0) from [<c001aa0c>] (do_exit+0x0/0x6f8) [ 1.252169] r6:c001aa0c r5:c0032314 r4:c2029f08 [ 1.256911] ---[ end trace f8e904209e598348 ]--- [ 1.262053] m25p80 spi1.0: found n25q256a, expected m25p80 [ 1.267976] m25p80 spi1.0: n25q256a (32768 Kbytes) [ 1.274231] Creating 15 MTD partitions on "m25p80": [ 1.279425] 0x000000000000-0x000000040000 : "Stage1" [ 1.288921] 0x000000040000-0x000000140000 : "Stage2" [ 1.298431] 0x000000140000-0x000000180000 : "NVRAM" [ 1.307778] 0x000000180000-0x0000001c0000 : "Mfg Dflts" [ 1.317219] 0x0000001c0000-0x000000200000 : "Params" [ 1.326744] 0x000000200000-0x000000300000 : "Stage3" [ 1.336300] 0x000000300000-0x000000500000 : "FPGA" [ 1.345706] 0x000000500000-0x000000900000 : "TestAppDSP" [ 1.355707] 0x000000900000-0x000000d00000 : "AppDSP" [ 1.365358] 0x000000d00000-0x000000d40000 : "TestAppParams" [ 1.375594] 0x000000d40000-0x000000d80000 : "UBL" [ 1.384982] 0x000000d80000-0x000000e80000 : "U-boot" [ 1.394565] 0x000000e80000-0x000001280000 : "UImage" [ 1.404280] 0x000001280000-0x000001880000 : "LinuxInitFS" [ 1.414415] 0x000001880000-0x000001c80000 : "LinuxUserFS" [ 1.424642] spi_davinci spi_davinci.1: Controller at 0xfef0e000 [ 1.438739] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.446473] usbcore: registered new interface driver uas [ 1.452184] Initializing USB Mass Storage driver... [ 1.458084] usbcore: registered new interface driver usb-storage [ 1.464146] USB Mass Storage support registered. [ 1.469028] i2c /dev entries driver [ 1.473520] TCP cubic registered [ 1.476805] NET: Registered protocol family 17 [ 1.485216] console [netcon0] enabled [ 1.489255] netconsole: network logging started [ 1.495656] RAMDISK: gzip image found at block 0 [ 3.238367] VFS: Mounted root (ext2 filesystem) on device 1:0. [ 3.244954] Freeing init memory: 140K INIT: version 2.86 booting Please wait: booting... Starting udev WARNING: -e needs -E or -F [ 6.143184] DMA-API: debugging out of memory - disabling Remounting root file system... Caching udev devnodes Populating dev cache root: mount: mounting rootfs on / failed: No such file or directory root: mount: mounting usbfs on /proc/bus/usb failed: No such file or directory Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device done. Setting up IP spoofing protection: rp_filter. hwclock: can't open '/dev/misc/rtc': No such file or directory Tue Aug 5 19:16:00 UTC 2014 hwclock: can't open '/dev/misc/rtc': No such file or directory INIT: Entering runlevel: 5 Starting telnet daemon. Starting syslogd/klogd: done Copying userfs from /dev/mtd14 to /usr/userfs.tar.gz... Attempting to open /dev/mtd14 device! File access to /dev/mtd14 created! Attempting to open /usr/userfs.tar.gz ! /usr/userfs.tar.gz created! Attempting to read /dev/mtd14 ! Read from /dev/mtd14 succeeded ! magic: 0x42484641 infoBlockOffset: 0x0000468A infoBlockLength: 0x00000410 infoBlockSignature: 0x4017096D imageOffset: 0x00000020 imageLength: 0x0000466A imageSignature: 0x5BEE4049 fhbSignature: 0xC351301C FHB Magic Number correct FHB CRC correct FHB read successfully Program image copied successfully! Image CRC correct Program image read successfully Closing file: /usr/userfs.tar.gz ! Closing file: /dev/mtd14 ! Complete. User Application Starting... Hello World, from the user application! User Application Complete... _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org arago ttyS0 Arago 2011.09 arago ttyS0 arago login: root login[778]: root login on `ttyS0' root@arago:~# [ 24.657514] usb 1-1: new high-speed USB device number 2 using musb-hdrc [ 24.800775] usb 1-1: New USB device found, idVendor=154b, idProduct=005b [ 24.808806] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 24.816009] usb 1-1: Product: USB 2.0 FD [ 24.820888] usb 1-1: Manufacturer: PNY Technologies [ 24.825823] usb 1-1: SerialNumber: AA00000000000575 [ 24.850936] scsi0 : usb-storage 1-1:1.0 [ 35.261666] scsi 0:0:0:0: Direct-Access PNY USB 2.0 FD 1100 PQ: 0 ANSI: 4 [ 35.292982] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 35.311946] sd 0:0:0:0: [sda] 63901440 512-byte logical blocks: (32.7 GB/30.4 GiB) [ 35.359428] sd 0:0:0:0: [sda] Write Protect is off [ 35.366147] sd 0:0:0:0: [sda] No Caching mode page present [ 35.399308] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 35.447868] sd 0:0:0:0: [sda] No Caching mode page present [ 35.453422] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 35.469913] sda: sda1 [ 35.501162] sd 0:0:0:0: [sda] No Caching mode page present [ 35.506723] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 35.545873] sd 0:0:0:0: [sda] Attached SCSI removable disk udevd[499]: worker [517] unexpectedly returned with status 0x0100 udevd[499]: worker [517] failed while handling '/devices/platform/musb-da8xx/musb-hdrc/usb1/1-1/1-1:1.0/host0/target0:0:0/0:0:0:0/block/sda' root@arago:~# ls /dev autofs mtd2ro mtdblock7 tty11 tty36 tty60 block mtd3 mtdblock8 tty12 tty37 tty61 bus mtd3ro mtdblock9 tty13 tty38 tty62 char mtd4 null tty14 tty39 tty63 console mtd4ro pktcdvd tty15 tty4 tty7 fd mtd5 ptmx tty16 tty40 tty8 full mtd5ro pts tty17 tty41 tty9 initctl mtd6 ptyp0 tty18 tty42 ttyS0 kmem mtd6ro ptyp1 tty19 tty43 ttyS1 kmsg mtd7 ptyp2 tty2 tty44 ttyS2 log mtd7ro ptyp3 tty20 tty45 ttyp0 mem mtd8 ptyp4 tty21 tty46 ttyp1 mtd0 mtd8ro ptyp5 tty22 tty47 ttyp2 mtd0ro mtd9 ptyp6 tty23 tty48 ttyp3 mtd1 mtd9ro ptyp7 tty24 tty49 ttyp4 mtd10 mtdblock0 ram0 tty25 tty5 ttyp5 mtd10ro mtdblock1 random tty26 tty50 ttyp6 mtd11 mtdblock10 sg0 tty27 tty51 ttyp7 mtd11ro mtdblock11 shm tty28 tty52 ubi_ctrl mtd12 mtdblock12 stderr tty29 tty53 urandom mtd12ro mtdblock13 stdin tty3 tty54 vcs mtd13 mtdblock14 stdout tty30 tty55 vcs1 mtd13ro mtdblock2 tgt tty31 tty56 vcsa mtd14 mtdblock3 tty tty32 tty57 vcsa1 mtd14ro mtdblock4 tty0 tty33 tty58 zero mtd1ro mtdblock5 tty1 tty34 tty59 mtd2 mtdblock6 tty10 tty35 tty6 root@arago:~#
