When Im trying built the recipe "packagegroup-qt5-toolchain-target" Im getting the following error. What could be the problem.? Im trying add qt support to my DRA7xx board using glsdk7.00.
medha@C528:~/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers$ ./build-specific-recipe.sh dra7xx-evm -f -c package_write_ipk packagegroup-qt5-toolchain-target
[GLSDK]>
[GLSDK]> Current Directory is /home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers
[GLSDK]> PATH is /usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin
[GLSDK]> Building on C528 running Linux C528 3.8.0-29-generic #42~precise1-Ubuntu SMP Wed Aug 14 15:31:16 UTC 2013 i686 i686 i386 GNU/Linux
[GLSDK]> Starting Yocto build at Tue Apr 21 08:59:22 IST 2015
[GLSDK]>
[GLSDK]> cd build
[GLSDK]> cp conf/local.conf conf/local.conf.pristine
[GLSDK]> echo ARAGO_BRAND = "glsdk" >> conf/local.conf
[GLSDK]> . conf/setenv
[GLSDK]> MACHINE=dra7xx-evm bitbake -f -c package_write_ipk packagegroup-qt5-toolchain-target
Loading cache: 100% |#############################################################################################| ETA: 00:00:00
Loaded 2197 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.22.0"
BUILD_SYS = "i686-linux"
NATIVELSBSTRING = "Ubuntu-12.04"
TARGET_SYS = "arm-oe-linux-gnueabi"
MACHINE = "dra7xx-evm"
DISTRO = "arago"
DISTRO_VERSION = "2013.10"
TUNE_FEATURES = "armv7a vfp thumb neon callconvention-hard cortexa15"
TARGET_FPU = "vfp-neon"
meta-glsdk = "(nobranch):49b46bdd3a35feeb0859dee918175a1045e75fe3"
meta-arago-distro
meta-arago-extras = "(nobranch):da343b0eab696e314a1a8a446c566ecef905c69d"
meta-qt5 = "(nobranch):dc277b5a52e3da6b7b50c9f5f2e185f841788e33"
toolchain-layer
meta-networking
meta-ruby
meta-oe = "(nobranch):d3d14d3fcca7fcde362cf0b31411dc4eea6d20aa"
meta-ti = "(nobranch):9aa966a6ae0d43b6e78ee6817f619af33b4876f8"
meta-linaro-toolchain = "(nobranch):06008235ca752fea678953e85adaa29a491d246b"
meta = "(nobranch):40e395696f1edc4337910c0a0a16e95b434a4f75"
NOTE: Preparing runqueue
NOTE: Tainting hash to force rebuild of task /home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/sources/meta-qt5/recipes-qt/packagegroups/packagegroup-qt5-toolchain-target.bb, do_package_write_ipk
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Function failed: do_configure (log file is located at /home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15t2hf-vfp-neon-3.14-oe-linux-gnueabi/qtbase/5.2.1-r0-arago3/temp/log.do_configure.15673)
ERROR: Logfile of failure stored in: /home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15t2hf-vfp-neon-3.14-oe-linux-gnueabi/qtbase/5.2.1-r0-arago3/temp/log.do_configure.15673
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function qmake5_base_preconfigure
| DEBUG: Shell function qmake5_base_preconfigure finished
| DEBUG: Executing shell function do_configure
| This is the Qt Open Source Edition.
| You are licensed to use this software under the terms of
| the Lesser GNU General Public License (LGPL) versions 2.1.
| You have already accepted the terms of the license.
| Performing shadow build...
| Preparing build tree...
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -fvisibility=hidden fvisibility.c
| Symbol visibility control enabled.
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -o libtest.so -shared -Wl,-Bsymbolic-functions -fPIC bsymbolic_functions.c
| Symbolic function binding enabled.
| DEFAULT_INCDIRS="/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include
| /home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/lib/gcc/arm-linux-gnueabihf/include/c++/4.7.3
| /home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/lib/gcc/arm-linux-gnueabihf/include/c++/4.7.3/arm-linux-gnueabihf
| /home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/lib/gcc/arm-linux-gnueabihf/include/c++/4.7.3/backward
| /home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/lib/gcc/arm-linux-gnueabihf/4.7.3/include
| /home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/lib/gcc/arm-linux-gnueabihf/4.7.3/include-fixed
| /home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/include
| DEFAULT_LIBDIRS="/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/lib/gcc/arm-linux-gnueabihf/lib
| /home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/lib
| /home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/lib
| <srcbase> = /home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15t2hf-vfp-neon-3.14-oe-linux-gnueabi/qtbase/5.2.1-r0-arago3/qtbase-opensource-src-5.2.1
| <outbase> = /home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15t2hf-vfp-neon-3.14-oe-linux-gnueabi/qtbase/5.2.1-r0-arago3/build
| Running configuration tests...
| Determining architecture... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -g -Wall -W -fPIE -I../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../qtbase-opensource-src-5.2.1/config.tests/arch -I. -o arch.o ../../../qtbase-opensource-src-5.2.1/config.tests/arch/arch.cpp
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -L/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-rpath-link,/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu -o arch arch.o
| Found architecture in binary
| CFG_ARCH="arm"
| CFG_CPUFEATURES=" neon"
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -g -Wall -W -fPIE -I../../../../../../../sysroots/i686-linux/usr/lib/qt5/mkspecs/linux-oe-g++ -I../../../qtbase-opensource-src-5.2.1/config.tests/arch -I. -o arch.o ../../../qtbase-opensource-src-5.2.1/config.tests/arch/arch.cpp
| CFG_HOST_ARCH="arm"
| CFG_HOST_CPUFEATURES=" neon"
| System architecture: 'arm'
| Host architecture: 'arm'
| C++11 auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -O2 -std=c++0x -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/common/c++11 -I. -o c++11.o ../../../../qtbase-opensource-src-5.2.1/config.tests/common/c++11/c++11.cpp
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -L/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-rpath-link,/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu -Wl,-O1 -o c++11 c++11.o
| C++11 enabled.
| floatmath auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/unix/floatmath -I. -o floatmath.o ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/floatmath/floatmath.cpp
| ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/floatmath/floatmath.cpp:44:5: warning: unused parameter 'argc' [-Wunused-parameter]
| ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/floatmath/floatmath.cpp:44:5: warning: unused parameter 'argv' [-Wunused-parameter]
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -L/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-rpath-link,/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu -Wl,-O1 -o floatmath floatmath.o
| floatmath enabled.
| sse2 auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -msse2 -g -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/common/sse2 -I. -o sse2.o ../../../../qtbase-opensource-src-5.2.1/config.tests/common/sse2/sse2.cpp
| arm-linux-gnueabihf-g++: error: unrecognized command line option '-msse2'
| make: *** [sse2.o] Error 1
| sse2 disabled.
| neon auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -mfpu=neon -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/unix/neon -I. -o neon.o ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/neon/neon.cpp
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -L/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-rpath-link,/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu -Wl,-O1 -o neon neon.o
| neon enabled.
| Cups auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/unix/cups -I. -o cups.o ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/cups/cups.cpp
| ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/cups/cups.cpp:42:23: fatal error: cups/cups.h: No such file or directory
| compilation terminated.
| make: *** [cups.o] Error 1
| Cups disabled.
| D-Bus auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/unix/dbus -I../../../../../../../../sysroots/dra7xx-evm/usr/include/dbus-1.0 -I../../../../../../../../sysroots/dra7xx-evm/usr/lib/dbus-1.0/include -I. -o dbus.o ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/dbus/dbus.cpp
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -L/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-rpath-link,/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu -Wl,-O1 -o dbus dbus.o -ldbus-1
| D-Bus enabled.
| PulseAudio auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -D_REENTRANT -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/unix/pulseaudio -I../../../../../../../../sysroots/dra7xx-evm/usr/include/glib-2.0 -I../../../../../../../../sysroots/dra7xx-evm/usr/lib/glib-2.0/include -I. -o pulseaudio.o ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/pulseaudio/pulseaudio.cpp
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -L/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-rpath-link,/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu -Wl,-O1 -o pulseaudio pulseaudio.o -lpulse-mainloop-glib -lpulse -lglib-2.0
| PulseAudio enabled.
| OpenGL auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/unix/opengldesktop -I. -o opengldesktop.o ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/opengldesktop/opengldesktop.cpp
| ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/opengldesktop/opengldesktop.cpp:45:19: fatal error: GL/gl.h: No such file or directory
| make: *** [opengldesktop.o] Error 1
| OpenGL disabled.
| OpenGL ES 2.x auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/unix/opengles2 -I. -o opengles2.o ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/opengles2/opengles2.cpp
| ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/opengles2/opengles2.cpp:45:25: fatal error: GLES2/gl2.h: No such file or directory
| make: *** [opengles2.o] Error 1
| OpenGL ES 2.x disabled.
| libudev auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/unix/libudev -I. -o libudev.o ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/libudev/libudev.cpp
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -L/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-rpath-link,/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu -Wl,-O1 -o libudev libudev.o -lrt -ludev
| libudev enabled.
| evdev auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/unix/evdev -I. -o evdev.o ../../../../qtbase-opensource-src-5.2.1/config.tests/unix/evdev/evdev.cpp
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -L/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-rpath-link,/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu -Wl,-O1 -o evdev evdev.o
| evdev enabled.
| XLib auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/x11/xlib -I. -o xlib.o ../../../../qtbase-opensource-src-5.2.1/config.tests/x11/xlib/xlib.cpp
| ../../../../qtbase-opensource-src-5.2.1/config.tests/x11/xlib/xlib.cpp:42:22: fatal error: X11/Xlib.h: No such file or directory
| make: *** [xlib.o] Error 1
| XLib disabled.
| EGL auto-detection... ()
| arm-linux-gnueabihf-g++ -march=armv7-a -marm -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a15 --sysroot=/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm -c -pipe -isystem/home/medha/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/arm-linux-gnueabihf/include -fstack-protector -O2 -pipe -g -feliminate-unused-debug-types -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.2.1/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.2.1/config.tests/qpa/egl -I. -o egl.o ../../../../qtbase-opensource-src-5.2.1/config.tests/qpa/egl/egl.cpp
| ../../../../qtbase-opensource-src-5.2.1/config.tests/qpa/egl/egl.cpp:42:21: fatal error: EGL/egl.h: No such file or directory
| make: *** [egl.o] Error 1
| EGL disabled.
| Warning: Disabling Accessibility. This version of Qt is unsupported.
| No QPA platform plugin enabled!
| If you really want to build without a QPA platform plugin you must pass
| -no-qpa-platform-guard to configure. Doing this will
| produce a Qt that can not run GUI applications.
| The dependencies needed for xcb to build are listed in
| src/plugins/platforms/xcb/README
| WARNING: exit code 1 from a shell command.
ERROR: Task 95 (/home/medha/ti-glsdk_dra7xx-evm_7_00_00_04/yocto-layers/sources/meta-qt5/recipes-qt/qt5/qtbase_5.2.1.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1359 tasks of which 1357 didn't need to be rerun and 1 failed.
No currently running tasks (1359 of 1464)
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
[GLSDK]>
[GLSDK]> Completed Yocto build at Tue Apr 21 08:59:49 IST 2015
[GLSDK]>
Plz help me in this regard.
Thanks.
Vijay
