I am using Vayu EVM booted with file system of GLSDK 6.04 and my hwclock shows error. I can't figure it out!. Please provide with ideas!
Following are the bootlogs,
5055888 bytes read in 887 ms (5.4 MiB/s)
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Linux-3.8.13-53394-g2c871a8-dirt
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 5055824 Bytes = 4.8 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 825f0000
Booting using the fdt blob at 0x825f0000
Loading Kernel Image ... OK
OK
reserving fdt memory region: addr=8e000000 size=1000000
reserving fdt memory region: addr=a0000000 size=1800000
Loading Device Tree to 83ff3000, end 83fff669 ... OK
Starting kernel ...
[ 0.301208] OMAP GPIO hardware version 0.1
[ 0.341308] No ATAGs?
[ 0.341339] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.341339] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.344482] OMAP DMA hardware revision 0.0
[ 0.349029] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
[ 0.392456] bio: create slab <bio-0> at 0
[ 0.394165] omap_i2c 48070000.i2c: did not get pins for i2c error: -19
[ 0.395111] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.397216] pcf857x 0-0020: probed
[ 0.398345] pcf857x 0-0021: probed
[ 0.400634] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[ 0.401611] pcf857x 1-0026: probed
[ 0.403198] i2c i2c-1: of_i2c: invalid reg on /ocp/i2c@48072000/camera_ov10633
[ 0.403747] i2c i2c-1: of_i2c: invalid reg on /ocp/i2c@48072000/camera_ov10635
[ 0.407531] omap_i2c 48060000.i2c: did not get pins for i2c error: -19
[ 0.407958] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.408081] omap_i2c 4807a000.i2c: did not get pins for i2c error: -19
[ 0.408508] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.408630] omap_i2c 4807c000.i2c: did not get pins for i2c error: -19
[ 0.409057] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.409454] Linux video capture interface: v2.00
[ 0.411895] palmas 0-0058: Muxing GPIO e, PWM 0, LED 0
[ 0.412414] palmas 0-0058: Product ID 9039
[ 0.412658] palmas 0-0058: Product Design Rev 1
[ 0.412841] palmas 0-0058: Product SW Rev 44
[ 0.414062] edma-dma-engine edma-dma-engine.0: Can't allocate PaRAM dummy slot
[ 0.414093] edma-dma-engine: probe of edma-dma-engine.0 failed with error -5
[ 0.450225] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[ 0.451690] vmmc2_fixed: 3000 mV
[ 0.452392] vmmcwl_fixed: 1800 mV
[ 0.453430] vdac_fixed: 1800 mV
[ 0.453887] vdac_fixed: 3300 mV
[ 0.453948] vdac_fixed: Failed to create debugfs directory
[ 0.456542] smps123: 600 <--> 1500 mV at 1040 mV
[ 0.458221] smps45: 600 <--> 1310 mV at 1010 mV
[ 0.459960] smps6: 600 <--> 1310 mV at 1010 mV
[ 0.462158] smps7: 1030 mV
[ 0.463836] smps8: 600 <--> 1310 mV at 990 mV
[ 0.465911] smps9: 1800 mV
[ 0.467437] ldo1: 3300 mV
[ 0.469329] ldo2: 2900 mV
[ 0.471038] ldo3: 1800 mV
[ 0.473022] ldo4: 2200 mV
[ 0.475036] ldo5: 1800 mV
[ 0.477020] ldo6: 1500 mV
[ 0.479034] ldo7: 1500 mV
[ 0.481018] ldo8: 1500 mV
[ 0.482757] ldo9: 1050 mV
[ 0.484466] ldoln: 1800 mV
[ 0.486328] ldousb: 3250 mV
[ 0.494506] SCSI subsystem initialized
[ 0.496093] usbcore: registered new interface driver usbfs
[ 0.496307] usbcore: registered new interface driver hub
[ 0.496582] usbcore: registered new device driver usb
[ 0.498504] pps_core: LinuxPPS API ver. 1 registered
[ 0.498504] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.498687] PTP clock support registered
[ 0.500366] omap-iommu omap-iommu.0: mmu0_dsp1 registered
[ 0.500457] omap-iommu omap-iommu.1: mmu1_dsp1 registered
[ 0.500518] omap-iommu omap-iommu.2: mmu0_dsp2 registered
[ 0.500610] omap-iommu omap-iommu.3: mmu1_dsp2 registered
[ 0.500701] omap-iommu omap-iommu.4: mmu_ipu1 registered
[ 0.500762] omap-iommu omap-iommu.5: mmu_ipu2 registered
[ 0.501739] Advanced Linux Sound Architecture Driver Initialized.
[ 0.503509] Bluetooth: Core ver 2.16
[ 0.503723] NET: Registered protocol family 31
[ 0.503723] Bluetooth: HCI device and connection manager initialized
[ 0.503784] Bluetooth: HCI socket layer initialized
[ 0.503814] Bluetooth: L2CAP socket layer initialized
[ 0.503875] Bluetooth: SCO socket layer initialized
[ 0.504028] Switching to clocksource arch_sys_counter
[ 0.575592] NET: Registered protocol family 2
[ 0.576660] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.576934] TCP bind hash table entries: 8192 (order: 6, 294912 bytes)
[ 0.579589] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.579681] TCP: reno registered
[ 0.579711] UDP hash table entries: 512 (order: 3, 40960 bytes)
[ 0.580047] UDP-Lite hash table entries: 512 (order: 3, 40960 bytes)
[ 0.580780] NET: Registered protocol family 1
[ 0.581542] RPC: Registered named UNIX socket transport module.
[ 0.581542] RPC: Registered udp transport module.
[ 0.581542] RPC: Registered tcp transport module.
[ 0.581542] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.582885] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.584381] platform omap-rproc.0: platform_device for rproc dsp1 created
[ 0.584686] platform omap-rproc.1: platform_device for rproc ipu2 created
[ 0.584991] platform omap-rproc.2: platform_device for rproc dsp2 created
[ 0.585296] platform omap-rproc.3: platform_device for rproc ipu1 created
[ 0.705139] bounce pool size: 64 pages
[ 0.705535] VFS: Disk quotas dquot_6.5.2
[ 0.705688] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.707366] NFS: Registering the id_resolver key type
[ 0.707611] Key type id_resolver registered
[ 0.707611] Key type id_legacy registered
[ 0.707702] jffs2: version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 0.708099] msgmni has been set to 1374
[ 0.710052] io scheduler noop registered (default)
[ 0.710052] io scheduler deadline registered
[ 0.710144] io scheduler cfq registered
[ 0.714569] OMAP DSS rev 6.1
[ 0.721405] omapdss HDMI: init_sel_i2c_hdmi: CM_L4PER2_CLKSTCTRL 0xc0010002
[ 0.721771] ldo3: operation not allowed
[ 0.721771] omapdss HDMI error: can't set the voltage regulator
[ 0.722625] omapdss: hdmi_panel_probe x_res= 640 y_res = 480
[ 0.746643] tlc59108 0-0040: Successfully initialized tlc59108
[ 0.748443] dserlink 1-002c: probe error 0 for 'ds90uh928q'
[ 0.748779] serlink 1-001b: probe error 0 for 'ds90uh925q'
[ 0.749023] lg101 display3: lg101_probe probe
[ 0.749084] lg101 display3: child device populate
[ 0.749114] lg101 display3: Serial I2C ID 1b
[ 0.749145] lg101 display3: DeSerial I2C ID 2c
[ 0.749420] lg101 display3: Serializer Reset done...
[ 0.749450] serlink 1-001b: 1. client ptr eac85c00 i2c addr 1b
[ 0.749572] serlink 1-001b: config 0 : 0xab
[ 0.749725] serlink 1-001b: config 1 : 0x8a
[ 0.749877] serlink 1-001b: datacontol 1 : 0x40
[ 0.749877] lg101 display3: Serializer configuration done...
[ 0.750061] lg101 display3: PCLK detection done...
[ 0.750274] lg101 display3: Serializer i2c addr 1b ...
[ 0.750488] lg101 display3: link not preset ...
[ 0.750488] omapdss CORE error: driver probe failed: -22
[ 0.750518] lg101: probe of display3 failed with error -22
[ 0.750701] i2c /dev entries driver
[ 0.753784] ov1063x 1-0037: No deserializer node found
[ 0.753936] ov1063x 1-0037: No serializer node found
[ 0.754058] ov1063x 1-0037: Failed writing register 0x0103!
[ 0.754089] ov1063x: probe of 1-0037 failed with error -121
[ 0.754486] ov1063x 1-0030: No deserializer node found
[ 0.754791] ov1063x 1-0030: No serializer node found
[ 0.754913] ov1063x 1-0030: Failed writing register 0x0103!
[ 0.754974] ov1063x: probe of 1-0030 failed with error -121
[ 0.756958] tvp5158 1-0058: Camera not connected
[ 0.757324] fpdlink 1-0020: Camera sensor driver registered
[ 0.758361] vpe vpe.12: Device registered as /dev/video0
[ 0.758789] vpe vpe.12: loading firmware vpdma-1b8.fw
[ 0.759918] dra7xx-vip vip1-0: Waiting for I2C subdevice 37
[ 0.759948] dra7xx-vip vip1-0: Waiting for I2C subdevice 30dra7xx-vip vip1-0: Waiting for I2C subdevice 38
[ 0.760040] dra7xx-vip vip1-0: Waiting for I2C subdevice 58dra7xx-vip vip1-0: Waiting for I2C subdevice 20
[ 0.760803] dra7xx-vip vip1-0: dra7xx-vip Device registered as /dev/video1
[ 0.760833] dra7xx-vip vip1-0: Using sensor i2c addr 20 for capture
[ 0.760955] dra7xx-vip vip1-1: Waiting for I2C subdevice 39
[ 0.761322] dra7xx-vip vip3-0: Waiting for I2C subdevice 3b
[ 0.761383] dra7xx-vip vip3-1: Waiting for I2C subdevice 3d[ 0.776428] brd: module loaded
[ 0.784698] loop: module loaded
[ 0.785217] (stk) :sysfs entries created
[ 0.785308] (stk) : debugfs entries created
[ 0.785583] (hci_tty): inside hci_tty_init
[ 0.786193] (hci_tty): allocated 250, 0
[ 0.786346] gccore gccore.0: opp_get_opp_count: device OPP not found (-19)
[ 0.805999] platform 4ae07ddc.regulator-abb-mpu: Driver ti_abb requests probe deferral
[ 0.806091] platform 4ae07e24.regulator-abb-ivahd: Driver ti_abb requests probe deferral
[ 0.806182] platform 4ae07e20.regulator-abb-dspeve: Driver ti_abb requests probe deferral
[ 0.806243] platform 4ae07de4.regulator-abb-gpu: Driver ti_abb requests probe deferral
[ 0.807678] 4a003b18.regulator-avs: 1090 <--> 1280 mV at 1090 mV
[ 0.808441] tiavs_class0 4a0025ec.regulator-avs: No match regulator V=1030000
[ 0.808624] tiavs_class0: probe of 4a0025ec.regulator-avs failed with error -22
[ 0.809600] 4a003b00.regulator-avs: 1090 <--> 1280 mV at 1090 mV
[ 0.810577] 4a0025d8.regulator-avs: 1055 <--> 1250 mV at 1055 mV
[ 0.811614] 4a0025c4.regulator-avs: 1055 <--> 1250 mV at 1055 mV
[ 0.812438] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.815704] omap_uart 4806a000.serial: did not get pins for uart0 error: -19
[ 0.815917] 4806a000.serial: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 1.224426] omapdss: in hpd work 1, state=0
[ 1.235839] hpd 0
[ 1.248046] omapdss: hdmi_hotplug_detect_worker state = 1
[ 1.248229] omapdss HDMI: hdmi_read_valid_edid: CM_DSS_CLKSTCTRL 62b02
[ 1.376800] omapdss HDMI: failed to read E-EDID: wrong header
[ 1.376831] omapdss: in hpd work 0, state=0
[ 1.376831] omapdss: hdmi_hotplug_detect_worker state = 0
[ 1.749511] console [ttyO0] enabled
[ 1.753936] omap_uart 4806c000.serial: did not get pins for uart1 error: -19
[ 1.761535] 4806c000.serial: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[ 1.770111] omap_uart 48020000.serial: did not get pins for uart2 error: -19
[ 1.777740] 48020000.serial: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 1.786254] omap_uart 4806e000.serial: did not get pins for uart3 error: -19
[ 1.793975] 4806e000.serial: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[ 1.802490] omap_uart 48066000.serial: did not get pins for uart4 error: -19
[ 1.810180] 48066000.serial: ttyO4 at MMIO 0x48066000 (irq = 137) is a OMAP UART4
[ 1.818664] omap_uart 48068000.serial: did not get pins for uart5 error: -19
[ 1.826385] 48068000.serial: ttyO5 at MMIO 0x48068000 (irq = 138) is a OMAP UART5
[ 1.835968] [drm] Initialized drm 1.1.0 20060810
[ 1.842773] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.850311] OneNAND driver initializing
[ 1.858032] m25p80 spi32766.0: s25fl256s1 (32768 Kbytes)
[ 1.867980] CAN device driver interface
[ 1.872497] c_can_platform 4ae3c000.d_can: flags recorded (0x5)
[ 1.887542] omap_hwmod: dcan1: _wait_target_disable failed
[ 1.893585] c_can_platform 4ae3c000.d_can: c_can_platform device registered (regs=fce3c000, irq=113)
[ 1.903442] c_can_platform 48480000.d_can: flags recorded (0x6)
[ 1.910919] c_can_platform 48480000.d_can: c_can_platform device registered (regs=f01bc000, irq=114)
[ 1.923217] usbcore: registered new interface driver asix
[ 1.929199] usbcore: registered new interface driver cdc_ether
[ 1.935668] usbcore: registered new interface driver smsc95xx
[ 1.942016] usbcore: registered new interface driver net1080
[ 1.948181] usbcore: registered new interface driver cdc_subset
[ 1.954711] usbcore: registered new interface driver zaurus
[ 1.960937] usbcore: registered new interface driver cdc_ncm
[ 1.967590] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.974578] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.981109] usbcore: registered new interface driver cdc_wdm
[ 1.987060] Initializing USB Mass Storage driver...
[ 1.992492] usbcore: registered new interface driver usb-storage
[ 1.998901] USB Mass Storage support registered.
[ 2.004028] usbcore: registered new interface driver usbtest
[ 2.011047] mousedev: PS/2 mouse device common for all mice
[ 2.018554] atmel_mxt_ts 0-004a: __mxt_read_reg: i2c transfer failed (-121)
[ 2.026000] atmel_mxt_ts: probe of 0-004a failed with error -121
[ 2.035736] Driver for 1-wire Dallas network protocol.
[ 2.043426] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 2.054718] (stc): chnl_id list empty :4
[ 2.058898] (stk) : st_kim_start[ 2.061218] omap-dma-engine 4a056000.dma-controller: allocating channel for 62
[ 2.061279] omap-dma-engine 4a056000.dma-controller: allocating channel for 61
[ 2.078430] omap_hsmmc 4809c000.mmc: pins are not configured from the driver
[ 2.129699] omap-dma-engine 4a056000.dma-controller: allocating channel for 48
[ 2.137390] omap-dma-engine 4a056000.dma-controller: allocating channel for 47
[ 2.148315] omap_hsmmc 480b4000.mmc: pins are not configured from the driver
[ 2.182891] (stk) :ldisc_install = 1[ 2.199768] omap-dma-engine 4a056000.dma-controller: allocating channel for 58
[ 2.207458] omap-dma-engine 4a056000.dma-controller: allocating channel for 57
[ 2.215301] omap_hsmmc 480d1000.mmc: pins are not configured from the driver
[ 2.250366] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 2.262451] mmc0: new high speed SD card at address e624
[ 2.269195] mmcblk0: mmc0:e624 SU02G 1.84 GiB
[ 2.277069] mmcblk0: p1 p2
[ 2.333343] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.338348] mmc1: BKOPS_EN bit is not set
[ 2.341796] mmc1: new high speed DDR MMC card at address 0001
[ 2.350097] mmcblk1: mmc1:0001 MMC08G 7.25 GiB
[ 2.350830] usbcore: registered new interface driver usbhid
[ 2.350830] usbhid: USB HID core driver
[ 2.351440] platform 4a0021e0.bandgap: Driver ti-soc-thermal requests probe deferral
[ 2.373229] mmcblk1boot0: mmc1:0001 MMC08G partition 1 8.00 MiB
[ 2.374389] omap_rproc_probe: ioremap_nocache(0x40800000, 0x40000)
[ 2.374420] omap_rproc_probe: ioremap_nocache(0x40e00000, 0x8000)
[ 2.374450] omap_rproc_probe: ioremap_nocache(0x40f00000, 0x8000)
[ 2.374511] remoteproc0: dsp1 is available
[ 2.374511] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 2.374511] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 2.375213] remoteproc1: ipu2 is available
[ 2.375213] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 2.375244] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 2.375457] omap_rproc_probe: ioremap_nocache(0x41000000, 0x40000)
[ 2.375488] omap_rproc_probe: ioremap_nocache(0x41600000, 0x8000)
[ 2.375488] omap_rproc_probe: ioremap_nocache(0x41700000, 0x8000)
[ 2.375549] remoteproc2: dsp2 is available
[ 2.375549] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 2.375549] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 2.375762] remoteproc3: ipu1 is available
[ 2.375793] remoteproc3: Note: remoteproc is still under development and considered experimental.
[ 2.375793] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 2.517303] davinci-mcasp 48468000.mcasp: data port resource not defined, cfg port will be used
[ 2.517517] mmcblk1boot1: mmc1:0001 MMC08G partition 2 8.00 MiB
[ 2.533966] mmcblk1: unknown partition table
[ 2.540496] mmcblk1boot1: unknown partition table
[ 2.547210] mmcblk1boot0: unknown partition table
[ 2.574218] dra7-evm-sound sound.19: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[ 2.583770] dra7-evm-sound sound.19: 48474000.mcasp is shared with radio
[ 2.591766] dra7-evm-sound sound.19: multicodec <-> 48474000.mcasp mapping ok
[ 2.601013] dra7-evm-sound sound.19: snd-soc-dummy-dai <-> 48478000.mcasp mapping ok
[ 2.617706] omap-hdmi-audio-card sound_hdmi.20: omap-hdmi-hifi <-> omap-hdmi-audio mapping ok
[ 2.629486] oprofile: no performance counters
[ 2.635070] oprofile: using timer interrupt.
[ 2.639984] TCP: cubic registered
[ 2.643463] Initializing XFRM netlink socket
[ 2.648040] NET: Registered protocol family 17
[ 2.652832] NET: Registered protocol family 15
[ 2.657501] can: controller area network core (rev 20120528 abi 9)
[ 2.664184] NET: Registered protocol family 29
[ 2.668914] can: raw protocol (rev 20120528)
[ 2.673461] can: broadcast manager protocol (rev 20120528 t)
[ 2.679656] Bluetooth: RFCOMM TTY layer initialized
[ 2.684875] Bluetooth: RFCOMM socket layer initialized
[ 2.690307] Bluetooth: RFCOMM ver 1.11
[ 2.694305] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.699920] Bluetooth: BNEP socket layer initialized
[ 2.705169] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.711456] Bluetooth: HIDP socket layer initialized
[ 2.716888] 8021q: 802.1Q VLAN Support v1.8
[ 2.721435] Key type dns_resolver registered
[ 2.725982] NET: Registered protocol family 40
[ 2.731018] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 2.739685] cpufreq-cpu0 cpufreq-cpu0.0: cpu0 regulator not ready, retry
[ 2.746826] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[ 2.754730] Power Management for TI OMAP4PLUS devices.
[ 2.760345] ThumbEE CPU extension supported.
[ 2.768035] abb_mpu: 1090 <--> 1280 mV
[ 2.773864] abb_ivahd: 1055 <--> 1250 mV
[ 2.779632] abb_dspeve: 1055 <--> 1250 mV
[ 2.785522] abb_gpu: 1090 <--> 1280 mV
[ 2.790863] platform 4a0021e0.bandgap: Driver ti-soc-thermal requests probe deferral
[ 2.807128] dmm 4e000000.dmm: initialized all PAT entries
[ 2.816192] omapdrm omapdrm.0: fpdlink has no driver.. skipping it
[ 2.823638] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 2.830657] [drm] No driver support for vblank timestamp query.
[ 2.841857] [drm] Enabling DMM ywrap scrolling
[ 2.850280] Console: switching to colour frame buffer device 100x30
[ 2.858581] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[ 2.864837] omapdrm omapdrm.0: registered panic notifier
[ 2.870452] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 2.933868] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 2.940307] davinci_mdio 48485000.mdio: detected phy mask fffffff3
[ 2.948394] libphy: 48485000.mdio: probed
[ 2.952667] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver unknown
[ 2.961181] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver unknown
[ 2.969787] Missing dual_emac_res_vlan in DT.
[ 2.974456] Using 1 as Reserved VLAN for 0 slave
[ 2.979400] Missing dual_emac_res_vlan in DT.
[ 2.984039] Using 2 as Reserved VLAN for 1 slave
[ 2.988983] Detected MACID = 7c:66:9d:f1:b6:14
[ 2.995239] Failed to clk_get cpsw_cpts_rft_clk
[ 3.000274] cpsw: Detected MACID = 7c:66:9d:f1:b6:15
[ 3.006896] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 3.013854] ALSA device list:
[ 3.016967] #0: dra7evm
[ 3.019744] #1: OMAP5HDMI
[ 3.025604] EXT3-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
[ 3.036590] EXT2-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (244)
[ 3.183898] (stk) :ldisc installation timeout
[ 3.188323] (stk) :ldisc_install = 0[ 3.268554] EXT4-fs (mmcblk0p2): recovery complete
[ 3.275451] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.284057] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.292083] devtmpfs: mounted
[ 3.295471] Freeing init memory: 380K
INIT: version 2.88 booting
Starting udev
[ 3.857391] udevd[1147]: starting version 182
[ 4.191833] (stk) : timed out waiting for ldisc to be un-installed
[ 4.305358] (stk) :ldisc_install = 1[ 4.636871] dra7xx-vip 48970000.vip: loading firmware vpdma-1b8.fw
[ 5.223907] remoteproc2: failed to load dra7-dsp2-fw.xe66
[ 5.257995] remoteproc3: failed to load dra7-ipu1-fw.xem4
[ 5.308898] (stk) :ldisc installation timeout
[ 5.313354] (stk) :ldisc_install = 0 remoteproc0: powering up dsp1
[ 5.345367] remoteproc0: Booting fw image dra7-dsp1-fw.xe66, size 930703
[ 5.395141] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 5.401519] omap-iommu omap-iommu.0: mmu0_dsp1: version 3.0
[ 5.407531] omap-iommu omap-iommu.1: mmu1_dsp1: version 3.0
[ 5.557098] HDCP: failed to load keys
[ 5.557098]
[ 5.942779] remoteproc1: powering up ipu2
[ 5.947113] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3357588
[ 5.965759] omap-iommu omap-iommu.5: mmu_ipu2: version 2.1
[ 6.034545] omap mailbox rev 0x400
[ 6.042907] remoteproc0: remote processor dsp1 is now up
[ 6.070159] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 6.076202] remoteproc0: registered virtio0 (type 7)
[ 6.081695] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x36
[ 6.094604] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x37
[ 6.110443] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x3b
[ 6.119873] rpmsg_rpc rpmsg2: probing service rpmsg-dce-dsp with src 1024 dst 59
[ 6.133911] rpmsg_rpc rpmsg2: publised functions = 8
[ 6.174224] omap mailbox rev 0x400
[ 6.178253] remoteproc1: remote processor ipu2 is now up
[ 6.184600] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 6.190399] remoteproc1: registered virtio1 (type 7)
[ 6.316741] (stk) : timed out waiting for ldisc to be un-installed
[ 6.430084] (stk) :ldisc_install = 1[ 6.581573] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x32
[ 6.590423] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x33
[ 6.601409] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x3b
[ 6.614746] rpmsg_rpc rpmsg5: probing service rpmsg-dce with src 1024 dst 59
[ 6.624237] rpmsg_rpc rpmsg5: publised functions = 8
UIM SYSFS Node Found at /sys/./devices/kim.22/install
Starting uim-sysfs daemon.
uim:@ main
uim:install = /sys/./devices/kim.22/install
uim:dev_name = /sys/./devices/kim.22/dev_name
uim:baud_rate = /sys/./devices/kim.22/baud_rate
uim:flow_cntrl = /sys/./devices/kim.22/flow_cntrl
uim:install set previously...
uim:@ st_uart_config
uim: signal received, opening /dev/ttyO2
uim:@ set_baud_rate
uim:set_baud_rate() done
uim:Setting speed to 3686400
uim:@ read_command_complete
uim: Command complete started
uim:@ read_hci_event
uim: read_hci_event
Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
[ 7.395324] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
uim:Invalid response
[ 7.433898] (stk) :ldisc installation timeout
[ 7.438323] (stk) :ldisc_install = 0uim:begin polling...
uim:poll broke due to event 10(PRI:2/ERR:8)
uim:read 0 from install
uim:Un-Installed N_TI_WL Line displine
ALSA: Restoring mixer settings...
Configuring network interfaces... [ 8.004333] net eth0: initializing cpsw version 1.15 (0)
[ 8.013519] net eth0: phy found : id is : 0x20005c7a
[ 8.023620] 8021q: adding VLAN 0 to HW filter on device eth0
udhcpc (v1.20.2) started
[ 8.116577] omap_hwmod: dcan1: _wait_target_disable failed
Sending discover...
[ 8.441711] (stk) : timed out waiting for ldisc to be un-installed
[ 8.555053] (stk) :ldisc_install = 1uim:poll broke due to event 10(PRI:2/ERR:8)
uim:read 1 from install
uim:@ set_baud_rate
uim: read_hci_event
[ 9.561920] (stk) :ldisc_install = 0[ 10.013214] libphy: 48485000.mdio:02 - Link is Up - 100/Full
[ 10.558898] (stk) : timed out waiting for ldisc to be un-installed
[ 10.672271] (stk) :ldisc_install = 1Sending discover...
Sending select for 172.16.7.121...
Lease of 172.16.7.121 obtained, lease time 14400
[ 11.415710] omap_hwmod: dcan1: _wait_target_disable failed
/etc/udhcpc.d/50default: Adding DNS 172.16.4.100
done.
Starting rpcbind daemon...rpcbind: cannot create socket for udp6
rpcbind: cannot create socket for tcp6
done.
[ 11.593719] omap_hwmod: dcan1: _wait_target_disable failed
hwclock: can't open '/dev/misc/rtc': No such file or directory
Tue Apr 15 03:12:00 UTC 2014
INIT: Entering runlevel: 5
[ 11.676086] (stk) :ldisc installation timeout
[ 11.680511] (stk) :ldisc_install = 0Starting system message bus: dbus.
Starting OpenBSD Secure Shell server: sshd
done.
Starting telnet daemon.
creating NFS state directory: done
starting 8 nfsd kernel threads: rpc.nfsd: Unable to access /proc/fs/nfsd errno 2 (No such file or directory).
Please try, as root, 'mount -t nfsd nfsd /proc/fs/nfsd' and then restart rpc.nfsd to correct the problem
done
starting mountd: [ 12.140228] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.154998] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.168914] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.182830] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.201385] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.217590] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.231597] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.245544] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.259429] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.273345] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.287200] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.301147] omap_hwmod: dcan1: _wait_target_disable failed
done
starting statd: [ 12.361053] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.375885] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.390686] omap_hwmod: dcan1: _wait_target_disable failed
[ 12.405487] omap_hwmod: dcan1: _wait_target_disable failed
done
Starting syslogd/klogd: done
Starting thttpd.
Stopping Bootlog daemon: bootlogd.
[ 12.683898] (stk) : timed out waiting for ldisc to be un-installed
[ 12.797271] (stk) :ldisc_install = 1
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dra7xx-evm ttyO0
I could not figure out the error, As I am new to It !
Thanks in Advance !
Sarah Blessie.
