When I try to load cmemk.ko module, it errors saying,
[ 365.654621] CMEMK module: built on Jun 11 2015 at 18:47:18
[ 365.660443] Reference Linux version 3.14.31
[ 365.666279] CMEMK Error: Failed to request_mem_region(0x99000000, 0x4000000)
I am not getting the Kernel memory overlap error and I have some memory reserved for dsp cma. This is from my dmesg output,
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: CMA: reserved 64 MiB at ab800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Kernel command line: console=ttyO7,115200n8 elevator=noop bootconf=main bootdev=0:1 confdev=0:2 fixrtc omapdrm.num_crtc=2 consoleblank=0 drm.universal_planes=1 cma=64M
[ 0.285681] platform 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[ 0.298248] platform 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
Any ideas on what is going on? Am I missing something here?
Thanks!
