Hi , we are getting some warning after boot up completely : i am posting the boot log - please any help us -- why we are getting this.
mmc-0 related address mismatch- which already assigned to other peripheral(which is not related to mmc0) -messages are occurred. please any one help us in this.
we removed MMC-2 -- those IO's are using for NAND in our custom board,
U-Boot SPL 2015.04-rc1-dirty (May 21 2015 - 18:32:42)
Timed out in wait_for_event: status=0000
Check if pads/pull-ups of bus 0 are properly configured
The Expected Linux image was not found. Please check your NAND configuration.
Trying to start u-boot now...
U-Boot 2015.04-rc1-dirty (May 21 2015 - 18:32:42)
Watchdog enabled
I2C: ready
DRAM: 256 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Viswa this is my Image
Net: Phy 0 not found
cpsw, usb_ether
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
** Unable to read file uEnv.txt **
4306152 bytes read in 617 ms (6.7 MiB/s)
36972 bytes read in 54 ms (668 KiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x41b4e8 ]
Loading Device Tree to 8e6f4000, end 8e70006b ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.14.26-g2489c02-dirty (vk29835@vk29835-HP-Compaq-6000-Pro-MT-PC) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.5
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM335x EVM-SK
[ 0.000000] cma: CMA: reserved 24 MiB at 8c800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64512
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 224264K/260096K available (5811K kernel code, 320K rwdata, 2132K rodata, 269K init, 231K bss, 35832K reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07ca054 (7945 kB)
[ 0.000000] .init : 0xc07cb000 - 0xc080e5a4 ( 270 kB)
[ 0.000000] .data : 0xc0810000 - 0xc0860220 ( 321 kB)
[ 0.000000] .bss : 0xc0860220 - 0xc089a1f8 ( 232 kB)
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000028] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns
[ 0.000071] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000676] Console: colour dummy device 80x30
[ 0.000739] Calibrating delay loop... 298.59 BogoMIPS (lpj=1492992)
[ 0.068460] pid_max: default: 32768 minimum: 301
[ 0.068688] Security Framework initialized
[ 0.068803] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.068830] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.087764] CPU: Testing write buffer coherency: ok
[ 0.088588] Setting up static identity map for 0x805b2aa0 - 0x805b2af8
[ 0.090674] devtmpfs: initialized
[ 0.094848] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.113794] omap_hwmod: tptc0 using broken dt data from edma
[ 0.114005] omap_hwmod: tptc1 using broken dt data from edma
[ 0.114195] omap_hwmod: tptc2 using broken dt data from edma
[ 0.120758] omap_hwmod: debugss: _wait_target_disable failed
[ 0.190785] pinctrl core: initialized pinctrl subsystem
[ 0.193064] regulator-dummy: no parameters
[ 0.197829] NET: Registered protocol family 16
[ 0.202730] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.208902] cpuidle: using governor ladder
[ 0.208939] cpuidle: using governor menu
[ 0.225936] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb] registered
[ 0.229662] platform 49000000.edma: alias fck already exists
[ 0.229721] platform 49000000.edma: alias fck already exists
[ 0.229758] platform 49000000.edma: alias fck already exists
[ 0.232505] OMAP GPIO hardware version 0.1
[ 0.260040] omap-gpmc 50000000.gpmc: could not find pctldev for node /pinmux@44e10800/nandflash_pins_default, deferring probe
[ 0.260113] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral
[ 0.269391] No ATAGs?
[ 0.269437] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.335439] bio: create slab <bio-0> at 0
[ 0.375199] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.377576] vbat: 5000 mV
[ 0.378550] lis3_reg: no parameters
[ 0.379725] vtt: 1500 mV
[ 0.387472] vgaarb: loaded
[ 0.388849] i2c-core: driver [palmas] using legacy suspend method
[ 0.388880] i2c-core: driver [palmas] using legacy resume method
[ 0.390614] SCSI subsystem initialized
[ 0.394218] usbcore: registered new interface driver usbfs
[ 0.394679] usbcore: registered new interface driver hub
[ 0.395161] usbcore: registered new device driver usb
[ 0.397465] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c0_pins, deferring probe
[ 0.397526] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
[ 0.397595] omap_i2c 4802a000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c1_pins, deferring probe
[ 0.397632] platform 4802a000.i2c: Driver omap_i2c requests probe deferral
[ 0.398673] pps_core: LinuxPPS API ver. 1 registered
[ 0.398703] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.399045] PTP clock support registered
[ 0.403831] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.405881] Advanced Linux Sound Architecture Driver Initialized.
[ 0.409677] Switched to clocksource timer1
[ 0.458743] NET: Registered protocol family 2
[ 0.460842] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.460931] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.461003] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.461157] TCP: reno registered
[ 0.461190] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.461239] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.461683] NET: Registered protocol family 1
[ 0.462514] RPC: Registered named UNIX socket transport module.
[ 0.462543] RPC: Registered udp transport module.
[ 0.462560] RPC: Registered tcp transport module.
[ 0.462577] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.464799] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.466679] omap_timer 48046000.timer: could not find pctldev for node /pinmux@44e10800/timer_5_pins_default, deferring probe
[ 0.466737] platform 48046000.timer: Driver omap_timer requests probe deferral
[ 0.466805] omap_timer 48048000.timer: could not find pctldev for node /pinmux@44e10800/timer_6_pins_default, deferring probe
[ 0.466842] platform 48048000.timer: Driver omap_timer requests probe deferral
[ 0.471494] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.910165] VFS: Disk quotas dquot_6.5.2
[ 0.910308] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.911440] NFS: Registering the id_resolver key type
[ 0.911654] Key type id_resolver registered
[ 0.911679] Key type id_legacy registered
[ 0.911767] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.912183] msgmni has been set to 486
[ 0.915751] NET: Registered protocol family 38
[ 0.915842] io scheduler noop registered
[ 0.915865] io scheduler deadline registered
[ 0.915913] io scheduler cfq registered (default)
[ 0.919976] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.923902] ecap_pwm_probe:
[ 0.928357] ecap_pwm_probe:
[ 0.939457] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.947078] omap_uart 44e09000.serial: no wakeirq for uart0
[ 0.947437] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a OMAP UART0
[ 1.678448] console [ttyO0] enabled
[ 1.683631] omap_uart 48024000.serial: no wakeirq for uart0
[ 1.689945] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 90, base_baud = 3000000) is a OMAP UART2
[ 1.702707] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 1.710696] [drm] Initialized drm 1.1.0 20060810
[ 1.742781] brd: module loaded
[ 1.760007] loop: module loaded
[ 1.764179] (hci_tty): inside hci_tty_init
[ 1.769558] (hci_tty): allocated 249, 0
[ 1.780370] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.797257] usbcore: registered new interface driver asix
[ 1.803531] usbcore: registered new interface driver ax88179_178a
[ 1.810437] usbcore: registered new interface driver cdc_ether
[ 1.817137] usbcore: registered new interface driver smsc95xx
[ 1.823576] usbcore: registered new interface driver net1080
[ 1.830042] usbcore: registered new interface driver cdc_subset
[ 1.836593] usbcore: registered new interface driver zaurus
[ 1.843079] usbcore: registered new interface driver cdc_ncm
[ 1.850241] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.857108] ehci-pci: EHCI PCI platform driver
[ 1.862316] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.868926] usbcore: registered new interface driver cdc_wdm
[ 1.875458] usbcore: registered new interface driver usb-storage
[ 1.884449] mousedev: PS/2 mouse device common for all mice
[ 1.895101] i2c-core: driver [rtc-ds1307] using legacy suspend method
[ 1.901974] i2c-core: driver [rtc-ds1307] using legacy resume method
[ 1.910461] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.919960] i2c /dev entries driver
[ 1.924023] Driver for 1-wire Dallas network protocol.
[ 1.934256] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.944954] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 1.957037] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 1.964591] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 1.977509] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 1.986534] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[ 1.993674] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[ 2.008926] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.016126] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 2.025016] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 2.034737] usbcore: registered new interface driver usbhid
[ 2.040694] usbhid: USB HID core driver
[ 2.045581] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral
[ 2.060910] davinci_mcasp_set_pdata_from_of:op-mode:0,
[ 2.066348] tdm-slots:2,
[ 2.069013] serial-dir:4,
[ 2.072013] dma_spec.args[0]:10,
[ 2.075432] tx-num-evt:32,
[ 2.078277] rx-num-evt:32,
[ 2.081164] sram-size-playback:32,
[ 2.084742] sram-size-capture:32,
[ 2.088319] rx-irq:83,
[ 2.091091] tx-irq:82,
[ 2.095170] davinci_evm sound.10: ASoC: CODEC (null) not registered
[ 2.102081] davinci_evm sound.10: snd_soc_register_card failed (-517)
[ 2.108910] platform sound.10: Driver davinci_evm requests probe deferral
[ 2.117943] oprofile: using arm/armv7
[ 2.122664] TCP: cubic registered
[ 2.126162] Initializing XFRM netlink socket
[ 2.130739] NET: Registered protocol family 17
[ 2.135494] NET: Registered protocol family 15
[ 2.140429] Key type dns_resolver registered
[ 2.146416] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 2.155672] cpu cpu0: cpu0 clock notifier not ready, retry
[ 2.161657] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[ 2.170875] PM: bootloader does not support rtc-only!
[ 2.176222] ThumbEE CPU extension supported.
[ 2.180997] Registering SWP/SWPB emulation handler
[ 2.189368] lis3_reg: disabling
[ 2.192945] vbat: disabling
[ 2.195894] regulator-dummy: disabling
[ 2.204332] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 2.209862] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 2.218473] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 2.225261] nand: Micron MT29F2G08ABAEAWP
[ 2.229482] nand: 256MiB, SLC, page size: 2048, OOB size: 64
[ 2.235462] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 2.241437] 10 ofpart partitions found on MTD device omap2-nand.0
[ 2.247847] Creating 10 MTD partitions on "omap2-nand.0":
[ 2.253578] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 2.263018] 0x000000020000-0x000000040000 : "NAND.SPL.backup1"
[ 2.273014] 0x000000040000-0x000000060000 : "NAND.SPL.backup2"
[ 2.282913] 0x000000060000-0x000000080000 : "NAND.SPL.backup3"
[ 2.292834] 0x000000080000-0x0000000c0000 : "NAND.u-boot-spl-os"
[ 2.302885] 0x0000000c0000-0x0000001c0000 : "NAND.u-boot"
[ 2.312856] 0x0000001c0000-0x0000001e0000 : "NAND.u-boot-env"
[ 2.322496] 0x0000001e0000-0x000000200000 : "NAND.u-boot-env.backup1"
[ 2.332897] 0x000000200000-0x000000a00000 : "NAND.kernel"
[ 2.348960] 0x000000a00000-0x000010000000 : "NAND.rootfs"
[ 2.572487] tlv320aic31xx-codec 0-0018: Failed to get supply 'HPVDD': -517
[ 2.579830] tlv320aic31xx-codec 0-0018: Failed to request supplies: -517
[ 2.587168] i2c 0-0018: Driver tlv320aic31xx-codec requests probe deferral
[ 2.594521] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 100 kHz
[ 2.604327] tps65910 1-002d: No interrupt support, no core IRQ
[ 2.617065] vrtc: 1800 mV
[ 2.620476] vrtc: supplied by vbat
[ 2.626699] vio: at 1500 mV
[ 2.629966] vio: supplied by vbat
[ 2.636242] vdd_mpu: 912 <--> 1375 mV at 1100 mV
[ 2.641419] vdd_mpu: supplied by vbat
[ 2.648064] vdd_core: 912 <--> 1150 mV at 1100 mV
[ 2.653321] vdd_core: supplied by vbat
[ 2.659558] vdd3: 5000 mV
[ 2.664658] vdig1: at 1800 mV
[ 2.668062] vdig1: supplied by vbat
[ 2.674020] vdig2: at 1800 mV
[ 2.677415] vdig2: supplied by vbat
[ 2.683364] vpll: at 1800 mV
[ 2.686685] vpll: supplied by vbat
[ 2.692570] vdac: at 1800 mV
[ 2.695880] vdac: supplied by vbat
[ 2.701693] vaux1: at 1800 mV
[ 2.705069] vaux1: supplied by vbat
[ 2.710954] vaux2: at 3300 mV
[ 2.714331] vaux2: supplied by vbat
[ 2.720273] vaux33: at 3300 mV
[ 2.723742] vaux33: supplied by vbat
[ 2.729766] vmmc: 1800 <--> 3300 mV at 3300 mV
[ 2.734706] vmmc: supplied by vbat
[ 2.740101] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 400 kHz
[ 2.748000] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 2.760090] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 2.767602] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 2.780512] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 2.790041] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 2.802083] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 2.809596] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 2.822521] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 2.830343] omap_hsmmc 48060000.mmc: pins are not configured from the driver
[ 2.872251] remoteproc0: wkup_m3 is available
[ 2.876951] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 2.886436] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 2.899656] remoteproc0: Direct firmware load failed with error -2
[ 2.906313] remoteproc0: Falling back to user helper
[ 2.912958] davinci_evm sound.10: ASoC: CODEC (null) not registered
[ 2.919630] davinci_evm sound.10: snd_soc_register_card failed (-517)
[ 2.927839] platform sound.10: Driver davinci_evm requests probe deferral
[ 2.941478] ## aic31xx_add_controls:
[ 2.945291] ## aic31xx_add_widgets:
[ 3.023124] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 3.051841] mmc0: new high speed SDHC card at address 59b4
[ 3.071418] mmcblk0: mmc0:59b4 MS 3.67 GiB
[ 3.081164] mmcblk0: p1 p2
[ 3.723735] ALSA sound/core/control.c:357 control 2:0:0:Speaker Driver Playback Switch:0 is already present
[ 3.734019] tlv320aic31xx-codec 0-0018: ASoC: Failed to add Speaker Driver Playback Switch: -16
[ 3.744196] davinci_evm sound.10: tlv320aic31xx-hifi <-> 4803c000.mcasp mapping ok
[ 3.752271] ## aic31xx_set_dai_fmt:
[ 3.755958] davinci_mcasp_set_dai_fmt:
[ 3.759924] davinci_mcasp_set_dai_fmt:SND_SOC_DAIFMT_I2S:
[ 3.765793] tlv320aic31xx-codec 0-0018: ASoC: Failed to create SPK debugfs file
[ 3.773639] tlv320aic31xx-codec 0-0018: ASoC: Failed to create SPK ClassD debugfs file
[ 3.782021] tlv320aic31xx-codec 0-0018: ASoC: Failed to create Speaker debugfs file
[ 3.790437] ## aic31xx_set_bias_level:
[ 3.794387] ## aic31xx_power_on:
[ 3.799157] ## aic31xx_dapm_power_event:event:8 w->reg:160 w->shift:7
[ 3.806065] ##PMD: reg:0x25:mask:16
[ 3.811795] ## aic31xx_dapm_power_event:event:8 w->reg:63 w->shift:6
[ 3.818574] ##PMD: reg:0x25:mask:8
[ 3.823090] ## aic31xx_dapm_power_event:event:8 w->reg:63 w->shift:7
[ 3.829897] ##PMD: reg:0x25:mask:128
[ 3.899742] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 3.906185] davinci_mdio 4a101000.mdio: no live phy, scanning all
[ 4.009670] davinci_mdio 4a101000.mdio: timed out waiting for user access
[ 4.017239] davinci_mdio: probe of 4a101000.mdio failed with error -5
[ 4.025223] cpsw 4a100000.ethernet: Missing slave[0] phy_id property
[ 4.031988] cpsw 4a100000.ethernet: cpsw: platform data missing
[ 4.041213] input: gpio_buttons.8 as /devices/gpio_buttons.8/input/input0
[ 4.049390] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:03 UTC (946684803)
[ 4.062648] ALSA device list:
[ 4.065804] #0: AM335x-EVMSK
[ 4.073026] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 4.080810] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 4.613611] EXT4-fs (mmcblk0p2): recovery complete
[ 4.631232] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.640531] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 4.654290] devtmpfs: mounted
[ 4.658594] Freeing unused kernel memory: 268K (c07cb000 - c080e000)
INIT: version 2.88 booting
Error opening /dev/fb0: No such file or directory
Starting udev
[ 5.619304] udevd[893]: starting version 182
[ 6.064778] remoteproc0: powering up wkup_m3
[ 6.114528] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 154420
[ 6.218977] PM: CM3 Firmware Version = 0x190
[ 6.224800] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 6.271847] remoteproc0: remote processor wkup_m3 is now up
[ 6.322061] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 6.338774] Error: Driver 'tlv320aic31xx-codec' is already registered, aborting...
[ 6.397858] Error: Driver 'davinci-mcasp' is already registered, aborting...
[ 6.480204] cryptodev: driver 1.6 loaded.
[ 6.912796] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
Starting Bootlog daemon: [ 7.243411] omap_hwmod: gfx: failed to hardreset
[ 7.248431] pvrsrvkm 56000000.sgx: Unable to reset SGX!
bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
[ 7.514778] Error: Driver 'davinci_evm' is already registered, aborting...
[ 7.651972] random: dd urandom read with 119 bits of entropy available
[ 7.965299] random: nonblocking pool is initialized
udevadm settle - timeout of 3 seconds reached, the event queue contains:
/sys/devices/ocp.3/48060000.mmc/mmc_host/mmc0/mmc0:59b4/block/mmcblk0/mmcblk0p1 (874)
/sys/devices/ocp.3/48060000.mmc/mmc_host/mmc0/mmc0:59b4/block/mmcblk0/mmcblk0p2 (875)
/sys/devices/virtual/block/loop0 (1029)
/sys/devices/virtual/block/loop1 (1030)
/sys/devices/virtual/block/ram0 (1037)
/sys/devices/virtual/block/ram1 (1038)
/sys/devices/virtual/block/ram10 (1039)
/sys/devices/virtual/block/ram11 (1040)
/sys/devices/virtual/block/ram12 (1041)
/sys/devices/virtual/block/ram13 (1042)
/sys/devices/virtual/block/ram14 (1043)
/sys/devices/virtual/block/ram15 (1044)
/sys/devices/virtual/block/ram2 (1045)
/sys/devices/virtual/block/ram3 (1046)
/sys/devices/virtual/block/ram4 (1047)
/sys/devices/virtual/block/ram5 (1048)
/sys/devices/virtual/block/ram6 (1049)
/sys/devices/virtual/block/ram7 (1050)
/sys/devices/virtual/block/ram8 (1051)
/sys/devices/virtual/block/ram9 (1052)
/sys/devices/virtual/mtd/mtd0/mtdblock0 (1060)
/sys/devices/virtual/mtd/mtd1/mtdblock1 (1063)
/sys/devices/virtual/mtd/mtd2/mtdblock2 (1066)
/sys/devices/virtual/mtd/mtd2ro (1067)
/sys/devices/virtual/mtd/mtd3/mtdblock3 (1069)
/sys/devices/virtual/mtd/mtd3ro (1070)
/sys/devices/virtual/mtd/mtd4/mtdblock4 (1072)
/sys/devices/virtual/mtd/mtd4ro (1073)
/sys/devices/virtual/mtd/mtd5 (1074)
[ 10.739053] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 10.860338] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[ 10.972228] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 10.979408] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.987096] usb usb1: Product: MUSB HDRC host driver
[ 10.992354] usb usb1: Manufacturer: Linux 3.14.26-g2489c02-dirty musb-hcd
[ 10.999502] usb usb1: SerialNumber: musb-hdrc.0.auto
[ 11.100140] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 11.269234] hub 1-0:1.0: USB hub found
[ 11.286729] hub 1-0:1.0: 1 port detected
[ 11.359966] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 11.382000] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2
[ 11.422650] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 11.429922] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.437529] usb usb2: Product: MUSB HDRC host driver
[ 11.442773] usb usb2: Manufacturer: Linux 3.14.26-g2489c02-dirty musb-hcd
[ 11.449935] usb usb2: SerialNumber: musb-hdrc.1.auto
[ 11.549638] hub 2-0:1.0: USB hub found
[ 11.569993] hub 2-0:1.0: 1 port detected
ALSA: Restoring mixer settings...
No state is present for card AM335xEVMSK
Found hardware: "AM335x-EVMSK" "" "" "" ""
Hardware is initialized using a generic method
Wed Feb 11 15:08:00 UTC 2015
INIT: [ 12.190059] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_vrise (80, <SessEnd), retry #3, port1 0008010c
Entering runlevel: 5
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
done.
Starting system message bus: dbus.
UIM SYSFS Node Not Found
Starting Dropbear SSH server: dropbear.
Starting telnet daemon.
Starting rpcbind daemon...rpcbind: cannot create socket for udp6
rpcbind: cannot create socket for tcp6
done.
creating NFS state directory: done
starting statd: done
Starting syslogd/klogd: done
Starting thttpd.
Starting Lighttpd Web Server: lighttpd.
2015-02-11 15:08:02: (/home/jenkins/amsdk-nightly-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8t2hf-vfp-neon-oe-linux-gnueabi/lighttpd/1.
Starting Matrix GUI application.
NOTICE: This file system contains the followin GPLv3 packages:
binutils
gdbserver
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
Stopping Bootlog daemon: bootlogd.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm /dev/ttyO0
Arago 2015.02 am335x-evm /dev/ttyO0
am335x-evm login:
[ 241.928914] SysRq : HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e)
[ 242.887773] SysRq : HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f)
���[ 242.921239] SysRq : HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(
[ 890.322039] SysRq : HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-
[ 890.517881] SysRq : HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-me
[ 890.567068] SysRq : HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-me
regards,
Viswanath K
