Dear all,
I am trying to connect my BeageBone Black board with a "fixed" code. By "fixed" codec, I mean this codec works at only one configuration with no control interface (neither two-wire I2C nor three-wire SPI). The sampling rate is set as only 8 Khz, data 8 bits (voice a-law). Data interface is completely the same as other normal voice codecs (BLCK, datain, dataout, framesyn-in DSP mode).
There is one more requirement that the sound ALSA model must be used, application must see the "fixed" codec as a ALSA sound device.
Could you all here have any suggestion to get this task done optimally together with steps' descriptions? If I start with a normal sound driver and try adapt to the new device, any stuff I have to pay attention due to the "fixed" configuration of the codec?
I would like to thank you in advance,
Brgs,
