Hello
We are migrating Appropho from 2.6.18 to 2.6.37 but we seem unable to start the streaming.
We have increased the frequency of the ARM core to 432Mhz and DDR2 to 340Mhz. What should be the VPSS setting, can it cross 270Mhz (We have tried this too)
Can some one help us review the log file.
DM36x initialization passed!
PARC TI UBL Version: GITDESCRIBE
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
DONE
Jumping to entry point at 0x81080000.zXPARC PLL1_PLLM = 55
PARC PLL1_PREDIV = 8005
PARC PLL1_POSTDIV = 8000
PARC PLL1_DIV4 = 3
PARC SYS_PERI_CLKCTL = 243f04fc
******PARC pll1_clk = 2a8
PARC gd->baudrate = 1c200
COM1 clock_divisor = 5c
DLL = 5c
DLM = 0
************com_port->rbr = 1c20000
com_port->ier = 1c20004
com_port->lcr = 1c2000c
com_port->mcr = 1c20010
com_port->lsr = 1c20014
com_port->msr = 1c20018
com_port->scr = 1c2001c
RDLL = d
RDLM = 0
U-Boot 1.3.4 (Aug 27 2015 - 08:45:00) DM368-IPNC-5.1.0
I2C: ready
DRAM: 128 MB
NAND: NAND device: Manufacturer ID: 0x2c, Chip ID: 0x38 (Micron NAND 1GiB 3,3V 8-bit)
Bad block table not found for chip 0
loop oob 81022618 Bad block table written to 0x3ffc0000, version 0x01
loop oob 81022618 Bad block table written to 0x3ff80000, version 0x01
1024 MiB
In: serial
Out: serial
Err: serial
ARM Clock :- 432MHz
DDR Clock :- 340MHz
Ethernet PHY: GENERIC @ 0x01
Hit any key to stop autoboot: 4 0
DM368 IPNC :>
DM368 IPNC :>tftp 0x80700000 uImageModule;bootm 0x80700000
TFTP from server 192.168.1.50; our IP address is 192.168.1.60
Filename 'uImageModule'.
Load address: 0x80700000
Loading: *#################################################################
done
Bytes transferred = 3712064 (38a440 hex)
## Booting kernel from Legacy Image at 80700000 ...
Image Name: Linux-2.6.37_IPNC_DM368_5.1.0
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3712000 Bytes = 3.5 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Z[ 0.000000] Linux version 2.6.37_IPNC_DM368_5.1.0 (root@asifparc1-300E4Z-300E5Z-300E7Z) (gcc version 4.3.3 (GCC) ) #1 PREEMPT Thu Aug 27 18:15:32 IST 2015
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x IPNC
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 12192
[ 0.000000] Kernel command line: mem=48M console=ttyS0,115200n8 noinitrd ip=192.168.1.60 rw ubi.mtd=3,4096 rootfstype=ubifs root=ubi0:rootfs cmemk.phys_start=0x83000000 cmemk.phys_end=0x88000000 cmemk.phys_start_1=0x00001000 cmemk.phys_end_1=0x00008000 cmemk.pools_1=1x28672 cmemk.allowOverlap=1 cmemk.useHeapIfPoolUnavailable=1 nohz=off highres=off clocksource=acpi_pm lpj=1077248 eth=$(ethaddr)
[ 0.000000] TI DaVinci EMAC: kernel boot params Ethernet address: $(ethaddr)
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44916k/44916k available, 4236k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB)
[ 0.000000] vmalloc : 0xc3800000 - 0xfea00000 ( 946 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3000000 ( 48 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc002a000 ( 136 kB)
[ 0.000000] .text : 0xc002a000 - 0xc036b000 (3332 kB)
[ 0.000000] .data : 0xc036c000 - 0xc0392400 ( 153 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptable hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000285] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[ 0.000340] pid_max: default: 32768 minimum: 301
[ 0.000551] Security Framework initialized
[ 0.000700] Mount-cache hash table entries: 512
[ 0.001516] CPU: Testing write buffer coherency: ok
[ 0.003191] devtmpfs: initialized
[ 0.006251] DaVinci: 8 gpio irqs
[ 0.006875] NET: Registered protocol family 16
[ 0.042444] dm365_rmd_cs_rdk_150_wl_init
[ 0.119542] bio: create slab <bio-0> at 0
[ 0.124949] SCSI subsystem initialized
[ 0.128807] usbcore: registered new interface driver usbfs
[ 0.130301] usbcore: registered new interface driver hub
[ 0.131196] usbcore: registered new device driver usb
[ 0.134546] vpss vpss: dm365_vpss vpss probed
[ 0.134608] vpss vpss: dm365_vpss vpss probe success
[ 0.138630] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.142445] Switching to clocksource timer0_1
[ 0.223481] NET: Registered protocol family 2
[ 0.223782] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.224554] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.224691] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.224778] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.224808] TCP reno registered
[ 0.224847] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.224907] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.225437] NET: Registered protocol family 1
[ 0.292436] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.295957] msgmni has been set to 87
[ 0.299893] io scheduler noop registered (default)
[ 0.301855] CSL: Module install successful, device major num = 254
[ 0.301898] CSL: Module version 0.10.00, built on Aug 27 2015 18:06:52
[ 0.301946] I2C: Module install successful, device major num = 253
[ 0.301985] DMA: Module install successful, device major num = 252
[ 0.302010] DRV: Module install successful
[ 0.302032] DRV: Module built on Aug 27 2015 18:06:54
[ 0.302058] DRV: EDMACC.QUEPRI = 00002777
[ 0.302079] DRV: SYSTEM.MSTPRI0 = 00440011
[ 0.302099] DRV: SYSTEM.MSTPRI1 = 00000444
[ 0.302120] DRV: ISP.BCR = 00000002
[ 0.302141] DRV: SYSTEM.MISC = 00000391
[ 0.302164] EDMAK module: built on Aug 27 2015 at 18:06:32
[ 0.302192] Reference Linux version 2.6.37
[ 0.302215] File /usr/local/ipnctop/ipnc-5-1/ipnc/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[ 0.303883] IRQK module: built on Aug 27 2015 at 18:06:26
[ 0.303932] Reference Linux version 2.6.37
[ 0.303957] File /usr/local/ipnctop/ipnc-5-1/ipnc/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 0.305638] irqk initialized
[ 0.307287] CMEMK module: built on Aug 27 2015 at 18:06:30
[ 0.307335] Reference Linux version 2.6.37
[ 0.307361] File /usr/local/ipnctop/ipnc-5-1/ipnc/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.312542] allocated heap buffer 0xc4000000 of size 0x5000000
[ 0.312582] heap fallback enabled - will try heap if pool buffer is not available
[ 0.312622] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 0.312655] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 0.312795] cmemk initialized
[ 0.312848] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.390220] PARC :port.uartclk = 16e3600
[ 0.390254] PARC :p->uartclk = 16e3600
[ 0.411408] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.411483] PARC : uart_get_divisor port->uartclk = 16e3600 quot = d baud = 115200
[ 0.411524] *****************PARC Serial = d
[ 0.955274] console [ttyS0] enabled
[ 0.990101] PARC :port.uartclk = a21fe80
[ 0.994221] PARC :p->uartclk = a21fe80
[ 1.019303] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 1.062882] brd: module loaded
[ 1.075107] ONFI flash detected
[ 1.078392] ONFI param page 0 valid
[ 1.082264] NAND device: Manufacturer ID: 0x2c, Chip ID: 0x38 (Micron NAND 1GiB 3,3V 8-bit)
[ 1.090809] PARC chunks = 8
[ 1.096350] Bad block table not found for chip 0
[ 1.104738] Creating 7 MTD partitions on "davinci_nand.0":
[ 1.110381] 0x000000000000-0x000000c00000 : "bootloader"
[ 1.120513] 0x000000c00000-0x000001400000 : "params"
[ 1.130420] 0x000001400000-0x000001800000 : "kernel"
[ 1.140459] 0x000001800000-0x000006800000 : "filesystem1"
[ 1.150978] 0x000006800000-0x000009000000 : "data1"
[ 1.160760] 0x000009000000-0x00000e000000 : "filesystem2"
[ 1.171058] 0x00000e000000-0x000040000000 : "data2"
[ 1.181392] davinci_nand davinci_nand.0: controller rev. 2.3
[ 1.190406] UBI: attaching mtd3 to ubi0
[ 1.194273] UBI: physical eraseblock size: 524288 bytes (512 KiB)
[ 1.200868] UBI: logical eraseblock size: 516096 bytes
[ 1.206287] UBI: smallest flash I/O unit: 4096
[ 1.211106] UBI: sub-page size: 1024
[ 1.215830] UBI: VID header offset: 4096 (aligned 4096)
[ 1.221955] UBI: data offset: 8192
[ 1.370299] UBI: max. sequence number: 0
[ 1.385312] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 1, need 2
[ 1.406974] UBI: volume 0 ("rootfs") re-sized from 155 to 155 LEBs
[ 1.415709] UBI: attached mtd3 to ubi0
[ 1.419482] UBI: MTD device name: "filesystem1"
[ 1.425095] UBI: MTD device size: 80 MiB
[ 1.429990] UBI: number of good PEBs: 160
[ 1.434722] UBI: number of bad PEBs: 0
[ 1.439180] UBI: number of corrupted PEBs: 0
[ 1.443687] UBI: max. allowed volumes: 128
[ 1.448317] UBI: wear-leveling threshold: 4096
[ 1.453090] UBI: number of internal volumes: 1
[ 1.457547] UBI: number of user volumes: 1
[ 1.462038] UBI: available PEBs: 0
[ 1.466495] UBI: total number of reserved PEBs: 160
[ 1.471426] UBI: number of PEBs reserved for bad PEB handling: 1
[ 1.477444] UBI: max/mean erase counter: 1/0
[ 1.481763] UBI: image sequence number: 413865148
[ 1.486602] UBI: background thread "ubi_bgt0d" started, PID 419
[ 1.501129] spi_davinci spi_davinci.0: Controller at 0xfec66000
[ 1.570151] davinci_mdio davinci_mdio.0: davinci mdio revision 1.4
[ 1.576364] davinci_mdio davinci_mdio.0: detected phy mask fffffffd
[ 1.601646] davinci_mdio.0: probed
[ 1.605094] davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
[ 1.630331] i2c /dev entries driver
[ 1.636125] Linux media interface: v0.10
[ 1.640945] Linux video capture interface: v2.00
[ 1.652651] vpbe-osd vpbe-osd: OSD sub device probe success
[ 1.659085] vpbe-venc vpbe-venc: VENC sub device probe success
[ 1.665888] vpbe-v4l2 vpbe-v4l2: vpbe v4l2 device registered
[ 1.672070] Setting default output to Composite
[ 1.676628] Setting default mode to ntsc
[ 1.680758] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
[ 1.687477] vpbe-v4l2 vpbe-v4l2: layer=c29b1a00,layer->video_dev=c29b1ae8
[ 1.695402] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
[ 1.702333] vpbe-v4l2 vpbe-v4l2: layer=c29b1200,layer->video_dev=c29b12e8
[ 1.711175] watchdog watchdog: heartbeat 60 sec
[ 1.721658] Error: Driver 'davinci-mcbsp' is already registered, aborting...
[ 1.731830] asoc: cq93vc-hifi <-> davinci-vcif mapping ok
[ 1.741594] ALSA device list:
[ 1.744593] #0: DaVinci DM365 EVM
[ 1.749404] nf_conntrack version 0.5.0 (701 buckets, 2804 max)
[ 1.757366] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.763300] TCP cubic registered
[ 1.766588] NET: Registered protocol family 17
[ 1.841834] net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=221556)
[ 1.910091] IP-Config: Guessing netmask 255.255.255.0
[ 1.915593] IP-Config: Complete:
[ 1.918672] device=eth0, addr=192.168.1.60, mask=255.255.255.0, gw=255.255.255.255,
[ 1.926817] host=192.168.1.60, domain=, nis-domain=(none),
[ 1.932810] bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
[ 1.941153] PARC : uart_get_divisor port->uartclk = 16e3600 quot = d baud = 115200
[ 1.948924] *****************PARC Serial = d
[ 2.285006] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 2.291136] UBIFS: file system size: 74317824 bytes (72576 KiB, 70 MiB, 144 LEBs)
[ 2.298817] UBIFS: journal size: 10452992 bytes (10208 KiB, 9 MiB, 21 LEBs)
[ 2.306369] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 2.312262] UBIFS: default compressor: lzo
[ 2.316372] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.324939] VFS: Mounted root (ubifs filesystem) on device 0:13.
[ 2.335072] devtmpfs: mounted
[ 2.338213] Freeing init memory: 136K
[ 2.512852] PARC : uart_get_divisor port->uartclk = 16e3600 quot = d baud = 115200
[ 2.520698] *****************PARC Serial = d
[ 2.527051] PARC : uart_get_divisor port->uartclk = 16e3600 quot = d baud = 115200
[ 2.534914] *****************PARC Serial = d
[ 2.560267] PARC : uart_get_divisor port->uartclk = 16e3600 quot = d baud = 115200
[ 2.568035] *****************PARC Serial = d
INIT: [ 2.590645] PARC : uart_get_divisor port->uartclk = 16e3600 quot = d baud = 115200
[ 2.598414] *****************PARC Serial = d
version 2.86 booting[ 2.620638] PARC : uart_get_divisor port->uartclk = 16e3600 quot = d baud = 115200
[ 2.628409] *****************PARC Serial = d
[ 2.690855] PARC : uart_get_divisor port->uartclk = 16e3600 quot = d baud = 115200
[ 2.698625] *****************PARC Serial = d
[ 3.040982] UBI: attaching mtd4 to ubi1
[ 3.044849] UBI: physical eraseblock size: 524288 bytes (512 KiB)
[ 3.051227] UBI: logical eraseblock size: 516096 bytes
[ 3.056642] UBI: smallest flash I/O unit: 4096
[ 3.061423] UBI: sub-page size: 1024
[ 3.066140] UBI: VID header offset: 4096 (aligned 4096)
[ 3.072204] UBI: data offset: 8192
[ 3.123725] UBI: empty MTD device detected
[ 3.127913] UBI: max. sequence number: 0
[ 3.132626] UBI: create volume table (copy #1)
[ 3.142622] UBI: create volume table (copy #2)
[ 3.154330] UBI: attached mtd4 to ubi1
[ 3.158104] UBI: MTD device name: "data1"
[ 3.163198] UBI: MTD device size: 40 MiB
[ 3.168091] UBI: number of good PEBs: 77
[ 3.172731] UBI: number of bad PEBs: 3
[ 3.177188] UBI: number of corrupted PEBs: 0
[ 3.181694] UBI: max. allowed volumes: 128
[ 3.186323] UBI: wear-leveling threshold: 4096
[ 3.191091] UBI: number of internal volumes: 1
[ 3.195548] UBI: number of user volumes: 0
[ 3.199996] UBI: available PEBs: 71
[ 3.204579] UBI: total number of reserved PEBs: 6
[ 3.209296] UBI: number of PEBs reserved for bad PEB handling: 2
[ 3.215362] UBI: max/mean erase counter: 0/0
[ 3.219642] UBI: image sequence number: 1167089469
[ 3.224609] UBI: background thread "ubi_bgt1d" started, PID 487
UBI device number 1, total 77 LEBs (39739392 bytes, 37.9 MiB), available 71 LEBs (36642816 bytes, 34.9 MiB), LEB size 516096 bytes (504.0 KiB)
Set volume size to 36642816
[ 3.840506] PHY: 0:01 - Link is Up - 100/Full
Volume ID 0, size 71 LEBs (36642816 bytes, 34.9 MiB), LEB size 516096 bytes (504.0 KiB), dynamic, name "ubifs_volume", alignment 1
[ 4.403507] UBIFS: default file-system created
[ 4.656970] UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 4.663624] UBIFS: file system size: 31997952 bytes (31248 KiB, 30 MiB, 62 LEBs)
[ 4.671276] UBIFS: journal size: 4128769 bytes (4032 KiB, 3 MiB, 6 LEBs)
[ 4.678518] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 4.684408] UBIFS: default compressor: lzo
[ 4.688521] UBIFS: reserved for root: 1511341 bytes (1475 KiB)
mknod: /dev/spidev0.0: File exists
Starting mounting local filesystems: mount Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
queue id:32769
mount: mounting /dev/root on / failed: No such file or directory
mount: mounting none on /dev/shm failed: No such file or directory
AlramThread created
Share memory init success
failed (2: ).
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
queue id:65538
net_search_gateway:eth0, 1A8C0, 0, 1
Check_device_version : DEVICE VER = 1 !!
CPU is DM368
Force CPU to DM368
IPNC BUILD VERSION: DM368 IPNC RDK V5.10.00.04
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
./av_server.out DM368 NTSC TI2A AEWB 720P H264 4000000 VBR AUTO MENUOFF &
ApproDrvInit: 7
Creat queue id:131076
queue id:131076
Starting internet superserver: inetd.
insmod: can't read '/opt/ipnc/modules/deflate.ko': No such file or directory
DM365MM Init Successful
AVSERVER UI: Initializing.
ApproDrvInit: 9
ApproDrvInit: 8
queue id:131076
ApproDrvInit: 2
queue id:131076
ApproDrvInit: 10
queue id:131076
ApproDrvInit: 6
queue id:131076
queue id:131076
insmod: can't read '/opt/ipnc/modules/mmc_core.ko': No such file or directory
CLK Hz,
ARM Hz = 432000000
DDR Hz = 340000000
VPSS Hz = 340000000
IMCOP Hz = 340000000
[ 6.591303] davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
[ 6.598536] davinci_mmc davinci_mmc.1: Using DMA, 4-bit mode
[OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR
IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter
[ 6.790276] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 6.820313] mmc0: new high speed SDHC card at address e624
[ 6.850762] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 6.871875] mmcblk0: p1
[ 6.881358] dm365_rmd_cs_rdk_150_wl_set_power
[ 6.885770] Powering on wifi
[ 6.930363] Loading iSCSI transport class v2.0-870.
DM365MM Init SuccessfulSYSTEM.MSTPRI0 value changed to 00440011
CONFIGURING AVSERVER FOR DM368 .....
queue id:65538
CAPTURE: Opening imager MICRON_MT9P031_5MP.
SENSOR FPS VALUE = 30
Sensor Mod[ 7.119671] mt9p031 1-0048: Detected a MT9P031 chip ID 1801
e Info,
Width [ 7.126864] mt9p031: mt9p031 sensor driver registered !!
= 1280
Height = 740
fps = 30
Bin Enable = 1
Sensor Frame Timing Info,
fps = 30
t_frame (ns) = 33333334.000000
t_row (ns) = 44250.000000
t_pclk (ns) = 15.625000
W = 1280
H = 740
SW = 753
SD = 0
HB = 776
VB = 13
HBmin = 776
VBmin = 9
f_pclk = 64000000
shutterOverhead (ns) = 13156.250000
col_size = 2559
row_size = 1479
col_skip = 1
row_skip = 1
col_bin = 1
row_bin = 1
c[ 7.194900] mmc1: host doesn't support card's voltages
ol_start = 16
row_start = 272
pll_M = 16
pll_N = 1
pll_DIV [ 7.210268] dm365_rmd_cs_rdk_150_wl_set_power
= 2
sett[ 7.215928] Powering off wifi
ing CMOS sensor....RESET... asif
[ 7.230261] mmc1: error -22 whilst initialising SDIO card
[ 7.237142] dm365_rmd_cs_rdk_150_wl_set_power
[ 7.253134] Powering on wifi
[ 7.474837] mmc1: host doesn't support card's voltages
[ 7.480008] dm365_rmd_cs_rdk_150_wl_set_power
[ 7.500275] Powering off wifi
[ 7.503401] mmc1: error -22 whilst initialising SDIO card
[ 7.531676] iscsi: registered transport (tcp)
[ 7.611431] musb-hdrc: version 6.0, peripheral, debug=0
[ 7.689622] musb-hdrc musb-hdrc: dma type: dma-cppi3
[ 7.711353] musb-hdrc musb-hdrc: USB Peripheral mode controller at fec64000 using DMA, IRQ 12
[ 7.831851] loop: module loaded
[ 7.902828] tun: Universal TUN/TAP device driver, 1.6
[ 7.907909] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 7.965728] console [netcon0] enabled
[ 7.969442] netconsole: network logging started
[ 8.062827] PPP generic driver version 2.4.2
[ 8.093737] PPP Deflate Compression module registered
CAPTURE: Opening ISIF.
CAPTURE: Opening H3A.
H3A Settings,
AEWB Win Start H = 0
AEWB Win Start V = 2
AEWB Win Num H = 12
AEWB Win Num V = 32
AEWB Win Width = 106
AEWB Win Height = 22
AEWB Win Inc H = 6
AEWB Win Inc V = 6
AEWB Win Pixels/Color = 72
CAPTURE: Opening IPIPE.
CAPTURE: Open DONE.
queue id:131076
Initializing...
Initializing...
Initializing...
Initializing...
IPNC AUTO_IRIS = 1
Initializing...
CAPTURE: Starting IPIPE.
CAPTURE: Starting ISIF.
CAPTURE: Starting imager.
...done initializing
Play this stream using the URL:
rtsp://192.168.1.168:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8303 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.168:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8304 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.168:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8301 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.168:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG
(We use port 8302 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.168:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8300 for optional RTSP-over-HTTP tunneling.)
mkdosfs 2.11 (12 Mar 2005)
unable to get drive geometry, using default 255/63/dev/ram0 has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 8192 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 6 sectors, and provides 2036 clusters.
Root directory contains 512 slots.
Volume ID is 00000009, no volume label.
queue id:0
TimeOut occure in boot_proc.
Program exit.
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
mount: mounting devpts on /dev/pts failed: No such file or direcINIT: Entering runlevel: 5
Starting telnet daemon.
Starting syslogd/klogd: done
getty: ioctl() TIOCSPGR[ 20.816606] PARC : uart_get_divisor port->uartclk = 16e3600 quot = d baud = 115200
[ 20.842618] *****************PARC Serial = d
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org 192.168.1.60 console
Arago 2009.11 192.168.1.60 console
192.168.1.60 login: root
-sh: can't access tty; job control turned off
root@192:~#
root@192:~# ApproDrvExit: 7
Error: WaitStreamReady Fail.
sycOnvif Profile 1
SystemInit success
Schedule manager init success
Dmva Schedule manager init success
umount: /mnt/mmc: not mounted
mount: mounting /dev/mmcblk0 on /mnt/mmc failed: Invalid argument
mount: mounting /dev/mmcblk0p1 on /mnt/mmc failed: Invalid argument
dns=192.168.1.1
net_search_gateway:eth0, FEA9, 0, 1
net_search_gateway:eth0, 0, FE01A8C0, 3
dns=192.168.1.1
ERROR: Module g_file_storage does not exist in /proc/modules
[ 110.274266] g_file_storage gadget: No serial-number string provided!
[ 110.283031] g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
[ 110.292006] g_file_storage gadget: Number of LUNs=1
[ 110.296971] g_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/ram0
[01/Jan/1970:00:00:19 +0000] boa: server version Boa/0.94.13
[01/Jan/1970:00:00:19 +0000] boa: server built Aug 27 2015 at 18:10:11.
[01/Jan/1970:00:00:19 +0000] boa: starting server pid=692, port 80
queue id:0
<UDN>uuid:Upnp-TVEmulator-00:e0:0a:dd:00:00</UDN>
Upnp port is 0
UPnP Initialized OK ip=192.168.1.168, port=49152
desc_doc_url = 192.168.1.168/tvdevicedesc.xml
UpnpRegisterRootDevice failure.
error code = -119
device advertisement failure.
root@192:~#
root@192:~#
root@192:~#
root@192:~#
root@192:~#
root@192:~# ps
PID USER VSZ STAT COMMAND
1 root 1624 S init [5]
2 root 0 SW [kthreadd]
3 root 0 SW [ksoftirqd/0]
4 root 0 SW [kworker/0:0]
5 root 0 SW [kworker/u:0]
6 root 0 SW< [khelper]
7 root 0 SW [kworker/u:1]
149 root 0 SW [sync_supers]
151 root 0 SW [bdi-default]
153 root 0 SW< [kblockd]
167 root 0 SW [khubd]
170 root 0 SW [kseriod]
176 root 0 SW< [kmmcd]
275 root 0 SW [kswapd0]
334 root 0 SW [fsnotify_mark]
336 root 0 SW< [aio]
342 root 0 SW< [crypto]
380 root 0 SW [mtdblock0]
385 root 0 SW [mtdblock1]
390 root 0 SW [mtdblock2]
395 root 0 SW [mtdblock3]
400 root 0 SW [mtdblock4]
405 root 0 SW [mtdblock5]
410 root 0 SW [mtdblock6]
419 root 0 SW [ubi_bgt0d]
420 root 0 SW< [spi_davinci.0]
472 root 0 SW [kworker/0:1]
474 root 0 SW [ubifs_bgt0_0]
487 root 0 SW [ubi_bgt1d]
495 root 0 SW [ubifs_bgt1_0]
509 root 101m S ./system_server
541 root 24380 S ./wis-streamer -s -h
543 root 208m S ./av_server.out DM368 NTSC TI2A AEWB 720P H264 400000
548 root 2976 S /usr/sbin/inetd
566 root 24380 S ./wis-streamer -s -h
567 root 24380 S ./wis-streamer -s -h
568 root 24380 S ./wis-streamer -s -h
571 root 24380 S ./wis-streamer -s -h
578 root 0 SW [kworker/u:2]
584 root 0 SW [mmcqd/0]
594 root 0 SW< [iscsi_eh]
632 root 0 SW [flush-ubifs_0_0]
633 root 0 SW [flush-ubifs_1_0]
685 root 0 SW [flush-1:0]
692 root 42564 S ./boa -c /etc
695 root 1764 S avahi-autoipd: [eth0] bound 169.254.4.140
696 root 1764 S avahi-autoipd: [eth0] callout dispatcher
700 root 2704 S avahi-daemon: running [192.local]
703 root 1940 S /usr/sbin/avahi-dnsconfd -D
712 root 2900 S /usr/sbin/telnetd
717 root 2964 S /sbin/syslogd -n -C64 -m 20
719 root 2900 S /sbin/klogd -n
721 root 3080 S -sh
831 root 0 SW [file-storage-ga]
838 root 67624 S ./upnp-scanip
858 root 3080 R ps
root@192:~#
