Hi there,
I'm new to Embedded Linux,
I'm trying to instal LAMP (PHP 5.6) can anyone help me out here?
Manish
Hi there,
Manish
Hi Titus,
Thanks for you reply,
can I install Nginx and PHP >= 5.5.9 (fast-cgi) on OMAP-L138 LCDK Linux SDK?
I've setup NFS on ubuntu 16 LTS, so I need install this in /opt/ti/mcsdk_1_01_00_02/targetNFS/ instead of root /var
Manish
Hi Titus,
./configure --prefix=/opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/ -host=arm-arago-linux-gnueabi CC=arm-arago-linux-gnueabi-gcc RANLIB=arm-arago-linux-gnueabi-ranlib STRIP=arm-arago-linux-gnueabi-strip --without-zlib --without-bzip2 --without-pcre
I'm getting following error:
manish@ubuntu:~/build_pcre/pcre-8.21$ sudo make install
make[1]: Entering directory '/home/manish/build_pcre/pcre-8.21'
test -z "/opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/lib" || /bin/mkdir -p "/opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/lib"
/bin/bash ./libtool --mode=install /usr/bin/install -c libpcre.la libpcreposix.la libpcrecpp.la '/opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libpcre.so.0.0.1 /opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/lib/libpcre.so.0.0.1
libtool: install: (cd /opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/lib && { ln -s -f libpcre.so.0.0.1 libpcre.so.0 || { rm -f libpcre.so.0 && ln -s libpcre.so.0.0.1 libpcre.so.0; }; })
libtool: install: (cd /opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/lib && { ln -s -f libpcre.so.0.0.1 libpcre.so || { rm -f libpcre.so && ln -s libpcre.so.0.0.1 libpcre.so; }; })
libtool: install: /usr/bin/install -c .libs/libpcre.lai /opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/lib/libpcre.la
libtool: install: warning: relinking `libpcreposix.la'
libtool: install: (cd /home/manish/build_pcre/pcre-8.21; /bin/bash /home/manish/build_pcre/pcre-8.21/libtool --tag CC --mode=relink arm-arago-linux-gnueabi-gcc -march=armv5te -marm -mthumb-interwork -mtune=arm926ej-s --sysroot=/opt/ti/mcsdk_1_01_00_02/linux-devkit/sysroots/armv5te-3.3-oe-linux-gnueabi -version-info 0:0:0 --sysroot=/opt/ti/mcsdk_1_01_00_02/linux-devkit/sysroots/armv5te-3.3-oe-linux-gnueabi -o libpcreposix.la -rpath /opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/lib pcreposix.lo libpcre.la )
libtool: relink: arm-arago-linux-gnueabi-gcc -shared -fPIC -DPIC .libs/pcreposix.o -Wl,-rpath -Wl,/opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/lib -L/opt/ti/mcsdk_1_01_00_02/targetNFS/usr/local/lib -lpcre -march=armv5te -marm -mthumb-interwork -mtune=arm926ej-s --sysroot=/opt/ti/mcsdk_1_01_00_02/linux-devkit/sysroots/armv5te-3.3-oe-linux-gnueabi --sysroot=/opt/ti/mcsdk_1_01_00_02/linux-devkit/sysroots/armv5te-3.3-oe-linux-gnueabi -Wl,-soname -Wl,libpcreposix.so.0 -o .libs/libpcreposix.so.0.0.0
/home/manish/build_pcre/pcre-8.21/libtool: line 8964: arm-arago-linux-gnueabi-gcc: command not found
libtool: install: error: relink `libpcreposix.la' with the above command before installing it
Makefile:712: recipe for target 'install-libLTLIBRARIES' failed
make[1]: *** [install-libLTLIBRARIES] Error 1
make[1]: Leaving directory '/home/manish/build_pcre/pcre-8.21'
Makefile:1465: recipe for target 'install-am' failed
make: *** [install-am] Error 2
but make works fine... at least I think it works fine with no errors.
Manish
I tried samarthparikh.blogspot.co.uk/.../cross-compile-lighttpd-php-for-arm.html PHP & XML2 works on target box (OMAP L138 LCDK) but not lighttpd
Can you also help me find a cross compile for PHP 5.6?
