Hi :
I want to display simultaneously dual LCD1 and LCD2 with the same source , LCD1 signal is from DR745 Vout1 pin ,LCD2 signal is from Vout3 Pin via FPD3 cable, set CONFIG_DRM_OMAP_NUM_CRTCS=2 , only one LCD can work if I enable display0 or display1 at DTS file , but two display are enable, log show error information : 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSS (Read): At Address: 0x00001630 : Data Access in User mode during Functional acces. both do not work.
How can I resolve this issue? and expect your answer ,thank you!
DTS part file:
/ { aliases {
display0 = &max9263;
//display1 = &tlc59108;
#if 0
/* 7" display and tsc hooked to i2c1 */
&i2c1 {
/* TLC chip for LCD panel power and backlight */
tlc59108: tlc59108@40 {
compatible = "ti,tlc59108-tfcs9700";
reg = <0x40>;
/* Display timings setting */
x_res = <1920>;
y_res = <720>;
pixelclock = <96000000>;
hfp = <60>;
hsw = <8>;
hbp = <16>;
vfp = <64>;
vsw = <7>;
vbp = <8>;
port@lcd {
tlc_in: endpoint {
remote-endpoint = <&dpi_out>;
&dss {
ports {
#address-cells = <1>;
#size-cells = <0>;
/* VOUT1 */
port@lcd {
reg = <0>;
dpi_out: endpoint {
remote-endpoint = <&tlc_in>;
data-lines = <24>;
#else
&i2c1 {
max9263: tlc59108@40 {
compatible = "ti,tlc59108-lp101";
reg = <0x40>;
x_res = <800>;
y_res = <480>;
pixelclock = <33300000>;
hfp = <158>;
hsw = <10>;
hbp = <88>;
vfp = <10>;
vsw = <3>;
vbp = <32>;
lvds_in: endpoint {
remote-endpoint = <&lvds_out>;
&dss {
ports {
#size-cells = <0>;
/* VOUT3 */
reg = <2>;
lvds_out: endpoint {
remote-endpoint = <&lvds_in>;
data-lines = <24>;
#endif
