Hi Champs,
We used to set RGB888 parallel output.
However, only R2(GIO81) signal is not being output signal.
So, when we check the reason , we found strange behavor on
linux-2.6.32.17-psp03.01.01.39/drivers/media/video/davinci/davinci_platform.c (Line 893)
before davinci_cfg_reg(DM365_VOUT_FIELD_G81); , register for R2 set PINMUX1[19:18]=2.
but, after line893, this register change to PINMUX1[19:18]=0.
I think this R2 output issue was caused by this driver setting.
So, usually, these setting must be work without driver modification. because, this is normal operation.
So, If we would like to realize RGB888 parallel output, how do we set up it ? Tell us correct guidline for RGB888 parallel output.
Kz777
