Dear Codec team,
Could you please help with the below questions:
1. We want to know when exactly the functions Videnc1_process or Videnc1_control of the codec H264FHDVENC return an “extendedError” set to 1. Member “extendedError” is declared in the structure IVIDENC1_OutArgs for function Videnc1_process, and in the structure IVIDENC1_Status for the function Videnc1_control.
A value set to 1 (bit 0) is in the reserved internal error bits (bits 0-7), and is described in the pdf SPRUGN8D from May 2010 (Codec version 1.00.00.10) and SPRUGN8E from Oct 2010 (codec version 1.10.02.06 ) as meaning: “There is an overflow of the output buffer allocated by the application”. (Note: rateControlPreset is set in IVIDEO_LOW_DELAY mode).
Question: When does this overflow can occur?
2. Using H.264 ENC v01.10.02.03:
After approximately 4 to 5hours, H264FHDVENC codec sends incorrect slice headers. We can see out of range values, like a value set 67454 in idr_pic_id field. Standard specifies that idr_pic_id field is encoded with Exp-Golomb code which technically allows value higher than 2^16 but the standard forbid value greater than 65535 for idr_pic_id. If needed, we can send you a capture of the video stream with this kind of error.
Is it a know issue?
3. When we activate the “checked” parameter defined in the Settings.xdc file at the following place of the codec engine:
codec_engine_2_26_02_11/packages/ti/sdo/ce/Settings.xdc
We can see logs telling that read-only members in structures used in ARM/DSP communication are overwritten by the codecs. We are refreshing our configuration parameters to be sure that we do not use a damaged structure, but we want to know if there are no side effects with theses overwrittings.
The DVSDK used is 3.10.00.19:
- Codec Engine version 2.26.02.11,
- Codec Server DM6467 version 1.00.00.10
- Dsplink driver version 1.65.02.09,
- Cmemk driver from linuxutils version 3.23.00.01,
- Framework components version 2.26.00.01
- DSPBIOS version 5.42.01.09
- XDAIS version 7.24.00.04
- XDCTOOLS version 3.24.07.73
- CGT version 7.4.5
Thanks in advance,
Anthony
