Dear Experts,
We are using DVR_RDK 3.5.
Our system flow is:
Camcorder output SDI signal-->DM8148. We try to use H264 codec to encode SDI signal.
We meet a special video.
When we playback this video and pause it ('pause' means video is static, no moving action), the encoded bitstream size is large.
If we set encode ouput format is 1280x720/GOP 60/9Mbps: I=670kB P=4kB.
If we set encode ouput format is HD 1080/GOP 60/9Mbps : I=270kB P=46kB.
This might be an abnormal situation.
In RDK setting,
#define UTILS_ENCDEC_GET_BITBUF_SIZE(width,height,bitrate,framerate) should be (((width) * (height))/2).
But in this case, The encoded bitstream is larger then BITBUF_SIZE.
We have to increase this size.
My question is:
1) Which situation will cause the large encoded bitstream even if video is static??
2) Why does the output format affect I/P frame encoded size? Is it correct behavior??
Below is my encode parameter:
[ 1781.920] [m3video]
[ 1781.920] [m3video] --------- CH 1 : H264 ENC : enclink_h264_print_status ( Dynamic Params ) -------
[ 1781.920] [m3video] videnc2DynamicParams -> inputHeight : 720
[ 1781.920] [m3video] videnc2DynamicParams -> inputWidth : 1280
[ 1781.920] [m3video] videnc2DynamicParams -> refFrameRate : 30000
[ 1781.920] [m3video] videnc2DynamicParams -> targetFrameRate : 30000
[ 1781.920] [m3video] videnc2DynamicParams -> targetBitRate : 9000000
[ 1781.920] [m3video] videnc2DynamicParams -> intraFrameInterval : 60
[ 1781.920] [m3video] videnc2DynamicParams -> generateHeader : 0
[ 1781.920] [m3video] videnc2DynamicParams -> captureWidth : 1920
[ 1781.920] [m3video] videnc2DynamicParams -> forceFrame : -1
[ 1781.920] [m3video] videnc2DynamicParams -> interFrameInterval : 1
[ 1781.920] [m3video] videnc2DynamicParams -> mvAccuracy : 2
[ 1781.920] [m3video] videnc2DynamicParams -> sampleAspectRatioHeight : 1
[ 1781.920] [m3video] videnc2DynamicParams -> sampleAspectRatioWidth : 1
[ 1781.920] [m3video] videnc2DynamicParams -> ignoreOutbufSizeFlag : 1
[ 1781.920] [m3video] videnc2DynamicParams -> lateAcquireArg : -1
[ 1781.920] [m3video] rateControlParams -> rateControlParamsPreset : 1
[ 1781.921] [m3video] rateControlParams -> scalingMatrixPreset : 0
[ 1781.921] [m3video] rateControlParams -> rcAlgo : 0
[ 1781.921] [m3video] rateControlParams -> qpI : -1
[ 1781.921] [m3video] rateControlParams -> qpMaxI : 49
[ 1781.921] [m3video] rateControlParams -> qpMinI : 10
[ 1781.921] [m3video] rateControlParams -> qpP : -1
[ 1781.921] [m3video] rateControlParams -> qpMaxP : 49
[ 1781.921] [m3video] rateControlParams -> qpMinP : 10
[ 1781.921] [m3video] rateControlParams -> qpOffsetB : 0
[ 1781.921] [m3video] rateControlParams -> qpMaxB : 49
[ 1781.921] [m3video] rateControlParams -> qpMinB : 49
[ 1781.921] [m3video] rateControlParams -> allowFrameSkip : 1
[ 1781.921] [m3video] rateControlParams -> removeExpensiveCoeff : 0
[ 1781.921] [m3video] rateControlParams -> chromaQPIndexOffset : 0
[ 1781.921] [m3video] rateControlParams -> IPQualityFactor : 0
[ 1781.921] [m3video] rateControlParams -> initialBufferLevel : 18000000
[ 1781.921] [m3video] rateControlParams -> HRDBufferSize : 18000000
[ 1781.921] [m3video] rateControlParams -> minPicSizeRatioI : 0
[ 1781.921] [m3video] rateControlParams -> maxPicSizeRatioI : 640
[ 1781.921] [m3video] rateControlParams -> minPicSizeRatioP : 0
[ 1781.921] [m3video] rateControlParams -> maxPicSizeRatioP : 0
[ 1781.921] [m3video] rateControlParams -> minPicSizeRatioB : 0
[ 1781.922] [m3video] rateControlParams -> maxPicSizeRatioB : 0
[ 1781.922] [m3video] rateControlParams -> enablePRC : 1
[ 1781.922] [m3video] rateControlParams -> enablePartialFrameSkip : 1
[ 1781.922] [m3video] rateControlParams -> discardSavedBits : 1
[ 1781.922] [m3video] rateControlParams -> VBRDuration : 8
[ 1781.922] [m3video] rateControlParams -> VBRsensitivity : 0
[ 1781.922] [m3video] rateControlParams -> skipDistributionWindowLength : 5
[ 1781.922] [m3video] rateControlParams -> numSkipInDistributionWindow : 2
[ 1781.922] [m3video] rateControlParams -> enableHRDComplianceMode : 1
[ 1781.922] [m3video] rateControlParams -> frameSkipThMulQ5 : 0
[ 1781.922] [m3video] rateControlParams -> vbvUseLevelThQ5 : 0
[ 1781.922] [m3video] interCodingParams -> interCodingPreset : 0
[ 1782.258] [m3video] interCodingParams -> searchRangeHorP : 144
[ 1782.258] [m3video] interCodingParams -> searchRangeVerP : 32
[ 1782.258] [m3video] interCodingParams -> searchRangeHorB : 144
[ 1782.259] [m3video] interCodingParams -> searchRangeVerB : 16
[ 1782.259] [m3video] interCodingParams -> interCodingBias : 1
[ 1782.259] [m3video] interCodingParams -> skipMVCodingBias : 1
[ 1782.259] [m3video] interCodingParams -> minBlockSizeP : 0
[ 1782.259] [m3video] interCodingParams -> minBlockSizeB : 0
[ 1782.259] [m3video] interCodingParams -> meAlgoMode : 0
[ 1782.259] [m3video] intraCodingParams -> intraCodingPreset : 0
[ 1782.259] [m3video] intraCodingParams -> lumaIntra4x4Enable : 255
[ 1782.259] [m3video] intraCodingParams -> lumaIntra8x8Enable : 0
[ 1782.259] [m3video] intraCodingParams -> lumaIntra16x16Enable : 15
[ 1782.259] [m3video] intraCodingParams -> chromaIntra8x8Enable : 15
[ 1782.259] [m3video] intraCodingParams -> chromaComponentEnable : 1
[ 1782.259] [m3video] intraCodingParams -> intraRefreshMethod : 0
[ 1782.259] [m3video] intraCodingParams -> intraRefreshRate : 0
[ 1782.259] [m3video] intraCodingParams -> gdrOverlapRowsBtwFrames : 0
[ 1782.259] [m3video] intraCodingParams -> constrainedIntraPredEnable : 0
[ 1782.259] [m3video] intraCodingParams -> intraCodingBias : 0
[ 1782.259] [m3video] sliceCodingParams -> sliceCodingPreset : 0
[ 1782.259] [m3video] sliceCodingParams -> sliceMode : 0
[ 1782.259] [m3video] sliceCodingParams -> sliceUnitSize : 0
[ 1782.259] [m3video] sliceCodingParams -> sliceStartOffset : [0 0 0]
[ 1782.259] [m3video] sliceCodingParams -> streamFormat : 0
[ 1782.260] [m3video] searchCenter : 32767
[ 1782.260] [m3video] enableStaticMBCount : 0
[ 1782.260] [m3video] enableROI : 0
[ 1782.260] [m3video] --------- H264 ENC : Static Params -------
[ 1782.260] [m3video] videnc2Params -> encodingPreset : 3
[ 1782.260] [m3video] videnc2Params -> rateControlPreset : 5
[ 1782.260] [m3video] videnc2Params -> maxHeight : 720
[ 1782.260] [m3video] videnc2Params -> maxWidth : 1280
[ 1782.260] [m3video] videnc2Params -> maxInterFrameInterval : 1
[ 1782.260] [m3video] videnc2Params -> maxBitRate : 9000000
[ 1782.260] [m3video] videnc2Params -> minBitRate : 0
[ 1782.260] [m3video] videnc2Params -> inputChromaFormat : 9
[ 1782.260] [m3video] videnc2Params -> inputContentType : 0
[ 1782.260] [m3video] videnc2Params -> operatingMode : 1
[ 1782.260] [m3video] videnc2Params -> profile : 77
[ 1782.260] [m3video] videnc2Params -> level : 40
[ 1782.260] [m3video] videnc2Params -> inputDataMode : 3
[ 1782.260] [m3video] videnc2Params -> outputDataMode : 3
[ 1782.260] [m3video] videnc2Params -> numInputDataUnits : 1
[ 1782.260] [m3video] videnc2Params -> numOutputDataUnits : 1
[ 1782.261] [m3video] videnc2Params -> metadataType : 965422528
[ 1782.261] [m3video] videnc2Params -> fmoCodingParams.fmoCodingPreset : 0
[ 1782.261] [m3video] videnc2Params->interlaceCodingType : 3
[ 1782.261] [m3video] videnc2Params->bottomFieldIntra : 0
[ 1782.261] [m3video] videnc2Params->gopStructure : 0
[ 1782.261] [m3video] videnc2Params->entropyCodingMode : 1
[ 1782.261] [m3video] videnc2Params->transformBlockSize : 0
[ 1782.597] [m3video] videnc2Params->log2MaxFNumMinus4 : 10
[ 1782.597] [m3video] videnc2Params->picOrderCountType : 0
[ 1782.597] [m3video] videnc2Params->enableWatermark : 0
[ 1782.597] [m3video] videnc2Params->IDRFrameInterval : 1
[ 1782.597] [m3video] videnc2Params->pConstantMemory : 0
[ 1782.597] [m3video] videnc2Params->maxIntraFrameInterval : 2147483640
[ 1782.597] [m3video] videnc2Params->debugTraceLevel : 0
[ 1782.597] [m3video] videnc2Params->lastNFramesToLog : 0
[ 1782.597] [m3video] videnc2Params->enableAnalyticinfo : 0
[ 1782.597] [m3video] videnc2Params->enableGMVSei : 0
[ 1782.597] [m3video] videnc2Params->constraintSetFlags : 0
[ 1782.597] [m3video] videnc2Params->enableRCDO : 0
[ 1782.597] [m3video] videnc2Params->enableLongTermRefFrame : 0
[ 1782.597] [m3video] videnc2Params->LTRPPeriod : 0
[ 1782.597] [m3video] videnc2Params->numTemporalLayer : 1
[ 1782.597] [m3video] videnc2Params->referencePicMarking : 1
[ 1782.598] [m3video] videnc2Params->nalUnitControlParams.naluControlPreset :1
[ 1782.598] [m3video] videnc2Params->nalUnitControlParams.naluPresentMaskEndOfSequence :3072
[ 1782.598] [m3video] videnc2Params->nalUnitControlParams.naluPresentMaskIDRPicture :9184
[ 1782.598] [m3video] videnc2Params->nalUnitControlParams.naluPresentMaskIntraPicture :8962
[ 1782.598] [m3video] videnc2Params->nalUnitControlParams.naluPresentMaskNonIntraPicture :578
[ 1782.598] [m3video] videnc2Params->nalUnitControlParams.naluPresentMaskStartOfSequence :9120
[ 1782.598] [m3video] videnc2Params->vuiCodingParams.vuiCodingPreset :1
[ 1782.598] [m3video] videnc2Params->vuiCodingParams.hrdParamsPresentFlag :0
[ 1782.598] [m3video] videnc2Params->vuiCodingParams.timingInfoPresentFlag :0
This is my video image: (This is first video frame)
this is last video frame
Plz help ~ thx ~
HB
