Hi all,
I have a simple muxing Gstreamer pipe:
gst-launch-1.0 -e v4l2src chain-ipipe=true ! 'video/x-raw, format=(string)NV12, width=640, height=480' ! ce_h264enc headers=true vui-enable=1 ! queue ! qtmux ! filesink location=/tmp/prog_vui4_3.mp4 sync=false async=false
The vui-enable property in the ce gstreamer plugin does the following:
h264_params->enableVUIparams = 1;
Then I perform a recording exercise, extract the h264 from the mp4 and use an h264 bitstream tool to analyze the content:
======= SPS =======
profile_idc : 100
constraint_set0_flag : 0
constraint_set1_flag : 0
constraint_set2_flag : 0
constraint_set3_flag : 0
constraint_set4_flag : 0
constraint_set5_flag : 0
reserved_zero_2bits : 0
level_idc : 40
seq_parameter_set_id : 0
chroma_format_idc : 1
residual_colour_transform_flag : 0
bit_depth_luma_minus8 : 0
bit_depth_chroma_minus8 : 0
qpprime_y_zero_transform_bypass_flag : 0
seq_scaling_matrix_present_flag : 1
log2_max_frame_num_minus4 : 41
pic_order_cnt_type : 4
log2_max_pic_order_cnt_lsb_minus4 : 0
delta_pic_order_always_zero_flag : 0
offset_for_non_ref_pic : 0
offset_for_top_to_bottom_field : 0
num_ref_frames_in_pic_order_cnt_cycle : 0
num_ref_frames : 2
gaps_in_frame_num_value_allowed_flag : 0
pic_width_in_mbs_minus1 : 4
pic_height_in_map_units_minus1 : 2
frame_mbs_only_flag : 1
mb_adaptive_frame_field_flag : 0
direct_8x8_inference_flag : 0
frame_cropping_flag : 0
frame_crop_left_offset : 0
frame_crop_right_offset : 0
frame_crop_top_offset : 0
frame_crop_bottom_offset : 0
vui_parameters_present_flag : 0
=== VUI ===
aspect_ratio_info_present_flag : 0
aspect_ratio_idc : 0
sar_width : 0
sar_height : 0
overscan_info_present_flag : 0
overscan_appropriate_flag : 0
video_signal_type_present_flag : 0
video_format : 0
video_full_range_flag : 0
colour_description_present_flag : 0
colour_primaries : 0
transfer_characteristics : 0
matrix_coefficients : 0
chroma_loc_info_present_flag : 0
chroma_sample_loc_type_top_field : 0
chroma_sample_loc_type_bottom_field : 0
timing_info_present_flag : 0
num_units_in_tick : 0
time_scale : 0
fixed_frame_rate_flag : 0
nal_hrd_parameters_present_flag : 0
vcl_hrd_parameters_present_flag : 0
low_delay_hrd_flag : 0
pic_struct_present_flag : 0
bitstream_restriction_flag : 0
motion_vectors_over_pic_boundaries_flag : 0
max_bytes_per_pic_denom : 0
max_bits_per_mb_denom : 0
log2_max_mv_length_horizontal : 0
log2_max_mv_length_vertical : 0
num_reorder_frames : 0
max_dec_frame_buffering : 0
There are no sights of the VUI, I have been following the h264 encoder dm365 user guide (SPRUEU9B) and the dm36x h264x encoder FAQ but still there is no VUI in my output.
Am I missing some configuration or any other step ??, here is my hw/sw setup:
Board: LeopardBoard dm368
Kernel: Linux dm365 2.6.32-1
dvsdk-4_02_00_06/codec-engine_2_26_02_11
dvsdk-4_02_00_06/codecs-dm365_4_02_00_00
gst-ce-plugins v1.0.5
- JoseLopez
