Does decoder accept slices of frames to decode or must it receive only full frames ?
What about the encoder ? Does it accept also slices of frames to encode ?
Thank you,
Ran
Hi Ran,
Yes, Decoder do accept slice of frame and start decoding, if this feature is supported.
Similar is true for encoder also.
Kuladeepak
Hi Kuladeepak,
In the terms "slice" I mean any some piece of the packet (like pakets in network stream for the video), not the common "Slice" definition.
Is this supported ? What did you mean by "if this feature is supported". Do you mean that encoder/decoder need to know that it is only peice of packet and not a complete frame ?
I also see Gajanan answer and it seems to answer the question.
I will now go over the datasheet you've mentioned.
If I may, I would like to ask one more: Is the timestamp/timing info any relevant to decoder/encoder process, i.e. does encoder need to know the time of frame ?
Thank you a lot!
Ran
I just seen now Gajanan answer and it seems to answer the question.
Thank you a lot,
Ran
If I may, I would like to ask one more: Is the timestamp/timing info any relevant to decoder/encoder process, i.e. does decoder need to know the time of encoded frame (decoder or encoder) ?
Thank you a lot,
Ran
