• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Multimedia Software Codecs » Multimedia Software Codecs forum » Question on cs1omapl138_1_00_00 - jpegenc
Share
  • Forum
Options
  • Subscribe via RSS
This question is answered
James McGloin
Posted by James McGloin
on Apr 20 2010 11:16 AM
Prodigy120 points
Hi Guys,
Hope you can help, my hardware is a LogicPd L138EVM and I am testing the jpegenc server in the cs.x64p dsp server (part of the EVM package) using Codec Engine and DSPLink, I am able to open the Engine and create the algorithm, when I set the dynamic params an error is returned. When I debug the issue it seams that the VISA interface tries to allocate memory at size 0 and an error occurs.
CV - VISA_allocMsg> Allocating message for messageId=0x0002cc03
OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x401805e8, size=0)
OM - Memory_getBufferPhysicalAddress> invalid buffer size provided (0)
Below is my settings and debug output
All advice is welcome
regards
James
/* reset, load, and start DSP Engine */
if ((ce = Engine_open(engineName, NULL, NULL)) == NULL) {
fprintf(stderr, "%s: error: can't open engine %s\n",
progName, engineName);
goto end;
printf("Engine Opened\n");
/* allocate and initialize image encoder on the engine */
encParams.size = sizeof(IMGENC1_Params);
encParams.maxWidth = 720;
encParams.maxHeight = 480;
encParams.maxScans = 0;
encParams.dataEndianness = XDM_BYTE;
encParams.forceChromaFormat = XDM_YUV_422P;
enc = IMGENC1_create(ce, encoderName, &encParams);
if (enc == NULL) {
fprintf(stderr, "%s: error: can't open codec %s\n",
progName, encoderName);
goto end;
printf("Encoder Created\n");
/* set the parameters for encoding */
dynParams.size = sizeof(IMGENC1_DynamicParams);
dynParams.numAU = 1;
dynParams.inputChromaFormat = XDM_YUV_422P;
dynParams.inputHeight = 480;
dynParams.inputWidth = 720;
dynParams.captureWidth = 720;
dynParams.generateHeader = XDM_ENCODE_AU;
dynParams.qValue = 86;
imgStatus.size = sizeof(imgStatus);
if (IMGENC1_control(enc, XDM_SETPARAMS, &dynParams, &imgStatus) ==
XDM_EFAIL) {
fprintf(stderr, "%s: error: could not set PARAMS: 0x%x\n", progName,
imgStatus.extendedError);
goto end;
root@da850-omapl138-evm:/# ./loadmodules.sh\par
CMEMK module: built on Dec 14 2009 at 14:36:38\par
  Reference Linux version 2.6.32\par
  File /db/rtree/install/trees/products/freon/freon-a08x/imports/linuxutils_2_25_01_06/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c\par
allocated heap buffer 0xc3000000 of size 0xea000\par
cmemk initialized\par
DSPLINK Module (1.65.00.01) created on Date: Dec 14 2009 Time: 14:38:20\par
root@da850-omapl138-evm:/# CE_DEBUG=3 ./app\par
@0,481,273us: [+4 T:0x4001e320 S:0xbea7bc4c] OG - Global_init> This program was built with the following packages:\par
@0,482,487us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package gnu.targets.arm.rtsv5T (/home/valeo/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/gnu/targets/arm/rtsv5T/) [1, 0, 0, 0]\par
@0,482,805us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.aachedec (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/aachedec/) [1, 0, 0]\par
@0,483,005us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.g711dec (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/g711dec/) [1, 0, 0]\par
@0,483,323us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.g711enc (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/g711enc/) [1, 0, 0]\par
@0,483,517us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.h264dec (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/h264dec/) [1, 0, 0]\par
@0,483,906us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.h264enc (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/h264enc/) [1, 0, 0]\par
@0,484,178us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.jpegdec (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/jpegdec/) [1, 0, 0]\par
@0,484,373us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.jpegenc (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/jpegenc/) [1, 0, 0]\par
@0,484,562us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.mpeg2dec (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0]\par
@0,484,743us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.mpeg4dec (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg4dec/) [1, 0, 0]\par
@0,484,925us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.mpeg4enc (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0]\par
@0,485,159us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.global (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/global/) [1, 0, 0]\par
@0,485,345us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.xdais.dm (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/cetools/packages/ti/xdais/dm/) [1, 0, 5]\par
@0,485,524us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.utils.trace (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/cetools/packages/ti/sdo/utils/trace/) [1, 0, 0]\par
@0,485,699us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.utils.xdm (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]\par
@0,485,875us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.xdais (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/cetools/packages/ti/xdais/) [1, 2.0, 1]\par
@0,486,053us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.node (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/node/) [1, 0, 0]\par
@0,486,233us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.fc.global (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/cetools/packages/ti/sdo/fc/global/) [1, 0, 0]\par
@0,486,447us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.linuxutils.cmem (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/cetools/packages/ti/sdo/linuxutils/cmem/) [2, 2, 0]\par
@0,486,636us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.fc.memutils (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/cetools/packages/ti/sdo/fc/memutils/) [1, 0, 0]\par
@0,486,820us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.fc.utils (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/cetools/packages/ti/sdo/fc/utils/) [1, 0, 2]\par
@0,486,999us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.fc.dman3 (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/cetools/packages/ti/sdo/fc/dman3/) [1, 0, 4]\par
@0,818,331us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.fc.acpy3 (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/cetools/packages/ti/sdo/fc/acpy3/) [1, 0, 4]\par
@0,818,565us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package gnu.targets (/home/valeo/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/gnu/targets/) [1, 0, 1]\par
@0,818,753us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package gnu.targets.arm (/home/valeo/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/gnu/targets/arm/) [1, 0, 0, 0]\par
@0,818,934us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package dsplink.gpp (/home/valeo/OMAP_L138_arm_1_00_00_08/dsplink_linux_1_65_00_01/dsplink/gpp/) [5, 0, 0]\par
@0,819,110us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.catalog.arm (/home/valeo/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/ti/catalog/arm/) [1, 0, 1, 0]\par
@0,819,289us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.catalog (/home/valeo/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/ti/catalog/) [1, 0, 0]\par
@0,819,467us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.catalog.c6000 (/home/valeo/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/ti/catalog/c6000/) [1, 0, 0, 0]\par
@0,819,697us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.platforms.evmOMAPL138 (/home/valeo/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/ti/platforms/evmOMAPL138/) [1, 0, 0]\par
@0,819,880us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.osal (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/osal/) [2, 0, 2]\par
@0,820,059us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.ipc (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/ipc/) [2, 0, 1]\par
@0,820,242us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.osal.linux (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/osal/linux/) [2, 0, 1]\par
@0,820,423us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.ipc.dsplink (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/ipc/dsplink/) [2, 0, 1]\par
@0,820,599us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.alg (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/alg/) [1, 0, 1]\par
@0,820,773us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/) [1, 0, 6]\par
@0,820,985us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.audio1 (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/audio1/) [1, 0, 1]\par
@0,821,175us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.aachedec.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/aachedec/ce/) [1, 0, 0]\par
@0,821,361us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.speech1 (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/speech1/) [1, 0, 1]\par
@0,821,536us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.g711dec.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/g711dec/ce/) [1, 0, 0]\par
@0,821,714us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.g711enc.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/g711enc/ce/) [1, 0, 0]\par
@0,821,894us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.video2 (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/video2/) [1, 0, 2]\par
@0,822,070us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.h264dec.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/h264dec/ce/) [1, 0, 0]\par
@0,822,255us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.video1 (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/video1/) [1, 0, 2]\par
@1,154,321us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.h264enc.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0]\par
@1,154,572us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.image1 (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/image1/) [1, 0, 1]\par
@1,154,762us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.jpegdec.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/jpegdec/ce/) [1, 0, 0]\par
@1,154,950us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.jpegenc.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/jpegenc/ce/) [1, 0, 0]\par
@1,155,132us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.mpeg2dec.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0]\par
@1,155,312us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.mpeg4dec.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg4dec/ce/) [1, 0, 0]\par
@1,155,540us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.codecs.mpeg4enc.ce (/home/valeo/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0]\par
@1,155,734us: [+4 T:0x4001e320 S:0xbea7bc4c] OG -     package ti.sdo.ce.examples.apps.image1_copy (/home/valeo/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/examples/ti/sdo/ce/examples/apps/image1_copy/) [1, 0, 0]\par
@1,156,068us: [+0 T:0x4001e320 S:0xbea7bc54] OG - Global_atexit> enter (fxn=0x1ffd8)\par
@1,156,294us: [+0 T:0x4001e320 S:0xbea7bc54] OG - Global_atexit> enter (fxn=0x1f424)\par
@1,156,558us: [+0 T:0x4001e320 S:0xbea7bc24] OM - Memory_alloc> Enter(0x18)\par
@1,156,824us: [+0 T:0x4001e320 S:0xbea7bc24] OM - Memory_alloc> return (0x4b0f0)\par
@1,157,444us: [+0 T:0x4001e320 S:0xbea7bc44] OG - Global_atexit> enter (fxn=0x1d354)\par
@1,157,818us: [+0 T:0x4001e320 S:0xbea7bc1c] OM - Memory_alloc> Enter(0x18)\par
@1,158,031us: [+0 T:0x4001e320 S:0xbea7bc1c] OM - Memory_alloc> return (0x4b140)\par
@1,158,258us: [+0 T:0x4001e320 S:0xbea7bc3c] OG - Global_atexit> enter (fxn=0x1c1f0)\par
@1,158,593us: [+0 T:0x4001e320 S:0xbea7bc44] OG - Global_atexit> enter (fxn=0x1ea88)\par
@1,158,916us: [+0 T:0x4001e320 S:0xbea7bc3c] ti.sdo.ce.osal.Sem - Sem_create> count: 0\par
@1,159,112us: [+0 T:0x4001e320 S:0xbea7bc24] OM - Memory_alloc> Enter(0x14)\par
@1,159,294us: [+0 T:0x4001e320 S:0xbea7bc24] OM - Memory_alloc> return (0x4b1c0)\par
@1,159,510us: [+0 T:0x4001e320 S:0xbea7bc3c] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x4b1c0]\par
@1,159,746us: [+0 T:0x4001e320 S:0xbea7bc3c] ti.sdo.ce.osal.Sem - Sem_create> count: 0\par
@1,159,913us: [+0 T:0x4001e320 S:0xbea7bc24] OM - Memory_alloc> Enter(0x14)\par
@1,160,087us: [+0 T:0x4001e320 S:0xbea7bc24] OM - Memory_alloc> return (0x4b1d8)\par
@1,160,260us: [+0 T:0x4001e320 S:0xbea7bc3c] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x4b1d8]\par
@1,160,430us: [+0 T:0x4001e320 S:0xbea7bc24] OM - Memory_alloc> Enter(0x18)\par
@1,160,601us: [+0 T:0x4001e320 S:0xbea7bc24] OM - Memory_alloc> return (0x4b1f0)\par
@1,160,773us: [+0 T:0x4001e320 S:0xbea7bc1c] OT - Thread_create> Enter (fxn=0x1a9ec, attrs=0x0)\par
@1,160,946us: [+0 T:0x4001e320 S:0xbea7bc04] OM - Memory_alloc> Enter(0x64)\par
@1,161,167us: [+0 T:0x4001e320 S:0xbea7bc04] OM - Memory_alloc> return (0x4b210)\par
@1,162,100us: [+0 T:0x4001e320 S:0xbea7bc1c] OT - Thread_create> Exit (task=0x4b210)\par
@1,162,390us: [+0 T:0x4001e320 S:0xbea7bc54] OG - Global_atexit> enter (fxn=0x1a404)\par
@1,162,628us: [+0 T:0x4001e320 S:0xbea7bc54] OG - Global_atexit> enter (fxn=0x1c73c)\par
@1,162,927us: [+0 T:0x4001e320 S:0xbea7bc3c] ti.sdo.ce.alg - ALG_init> Enter\par
@1,163,121us: [+0 T:0x4001e320 S:0xbea7bc2c] OG - Global_atexit> enter (fxn=0x17ecc)\par
@1,494,392us: [+0 T:0x4001e320 S:0xbea7bc5c] ti.sdo.ce.alg - ALG_init> Exit\par
@1,494,617us: [+0 T:0x4001e320 S:0xbea7bc54] OG - Global_atexit> enter (fxn=0x17094)\par
@1,494,836us: [+0 T:0x4001e320 S:0xbea7bc2c] OM - Memory_alloc> Enter(0x18)\par
@1,495,030us: [+0 T:0x4001e320 S:0xbea7bc2c] OM - Memory_alloc> return (0x4b3f0)\par
@1,495,216us: [+0 T:0x4001e320 S:0xbea7bc54] OG - Global_atexit> enter (fxn=0x1ef78)\par
@1,495,563us: [+6 T:0x4001e320 S:0xbea7bc4c] CE - Engine_init> CE debugging on (CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)\par
@1,495,781us: [+0 T:0x4001e320 S:0xbea7bc3c] OG - Global_atexit> enter (fxn=0x14368)\par
@1,495,967us: [+0 T:0x4001e320 S:0xbea7bc1c] OM - Memory_alloc> Enter(0x18)\par
@1,496,151us: [+0 T:0x4001e320 S:0xbea7bc1c] OM - Memory_alloc> return (0x4b430)\par
@1,496,332us: [+0 T:0x4001e320 S:0xbea7bc1c] OM - Memory_alloc> Enter(0x18)\par
@1,496,515us: [+0 T:0x4001e320 S:0xbea7bc1c] OM - Memory_alloc> return (0x4b450)\par
@1,496,694us: [+0 T:0x4001e320 S:0xbea7bc1c] OM - Memory_alloc> Enter(0x18)\par
@1,496,871us: [+0 T:0x4001e320 S:0xbea7bc1c] OM - Memory_alloc> return (0x4b470)\par
@1,497,183us: [+0 T:0x4001e320 S:0xbea7bc64] CS - Server_init()\par
@1,497,373us: [+0 T:0x4001e320 S:0xbea7bc64] CS - Server_init> Global_useLinkArbiter = 0\par
@1,497,554us: [+0 T:0x4001e320 S:0xbea7bc64] OG - Global_atexit> enter (fxn=0x1263c)\par
@1,497,780us: [+2 T:0x4001e320 S:0xbea7bc74] ti.sdo.ce.examples.apps.image1_copy - main> ti.sdo.ce.examples.apps.image1_copy\par
@1,498,680us: [+1 T:0x40983490 S:0x40982d64] OP - daemon> thread created.\par
@1,499,953us: [+1 T:0x4001e320 S:0xbea7b754] ti.sdo.ce.examples.apps.image1_copy - App-> Application started.\par
@1,500,694us: [+0 T:0x40983490 S:0x40982d64] OP - getCmd_d> Enter (proc=0x40982dd8)\par
@1,501,925us: [+0 T:0x40983490 S:0x40982d44] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x4b1c0] timeout[0xffffffff]\par
@1,555,939us: [+0 T:0x4001e320 S:0xbea7b6f4] CE - Engine_open> Enter('image1_copy', 0x0, 0xbea7b764)\par
@1,556,206us: [+0 T:0x4001e320 S:0xbea7b6dc] OM - Memory_alloc> Enter(0x2c)\par
@1,556,454us: [+0 T:0x4001e320 S:0xbea7b6dc] OM - Memory_alloc> return (0x4b7d8)\par
@1,556,656us: [+0 T:0x4001e320 S:0xbea7b6f4] CE - rserverOpen('cs.x64P'), count = 0\par
@1,556,835us: [+0 T:0x4001e320 S:0xbea7b6bc] OP - Processor_create> Enter(imageName='cs.x64P', linkCfg='(null)', attrs=0xbea7b748)\par
@1,558,462us: [+0 T:0x4001e320 S:0xbea7b6a4] OM - Memory_alloc> Enter(0x24)\par
@1,558,803us: [+0 T:0x4001e320 S:0xbea7b6a4] OM - Memory_alloc> return (0x4b808)\par
@1,559,002us: [+0 T:0x4001e320 S:0xbea7b69c] OP - doCmd> Enter (cmdId=1, proc=0x4b808)\par
@1,559,237us: [+0 T:0x4001e320 S:0xbea7b68c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x4b1c0]\par
@1,559,526us: [+0 T:0x4001e320 S:0xbea7b69c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x4b1c0]\par
@1,559,737us: [+0 T:0x4001e320 S:0xbea7b67c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x4b1d8] timeout[0xffffffff]\par
@1,560,004us: [+0 T:0x40983490 S:0x40982d44] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x4b1c0] status[0]\par
@1,560,230us: [+0 T:0x40983490 S:0x40982d64] OP - getCmd_d> Exit (result=1)\par
@1,560,411us: [+0 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Enter(proc=0x4b808)\par
@1,560,638us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Initializing DSP PROC...\par
@1,560,834us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'cs.x64P']\par
@1,561,027us: [+0 T:0x40983490 S:0x40982d4c] OM - Memory_alloc> Enter(0xe0)\par
@1,561,226us: [+0 T:0x40983490 S:0x40982d4c] OM - Memory_alloc> return (0x4b830)\par
@1,561,476us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0xc3c00000, sizeInBytes=0x300000, shared=1, syncd=0\par
@1,561,716us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0xc3f01000, sizeInBytes=0xff000, shared=1, syncd=0\par
@1,561,979us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0xc3f00000, sizeInBytes=0x1000, shared=1, syncd=0\par
@1,562,211us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0xc3200000, sizeInBytes=0xa00000, shared=0, syncd=0\par
@1,562,428us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> DODSPCTRL was=1; now=1\par
@1,562,678us: [+3 T:0x40983490 S:0x40982d04] OP - LINKCFG_Object generated for PROC_setup(0x49ed4) ...\par
@1,568,755us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->gppObject->\par
@1,570,346us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "ARM9"\par
@1,902,129us: [+3 T:0x40983490 S:0x40982d04] OP -   maxMsgqs = 0x82\par
@1,902,346us: [+3 T:0x40983490 S:0x40982d04] OP -   maxChnlQueue = 0x10\par
@1,902,520us: [+3 T:0x40983490 S:0x40982d04] OP -   poolTableId = 0xffffffff\par
@1,902,692us: [+3 T:0x40983490 S:0x40982d04] OP -   numPools = 0x0\par
@1,902,859us: [+3 T:0x40983490 S:0x40982d04] OP - \par
@1,903,013us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->dspConfigs[0]->dspObject->\par
@1,903,187us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "DA8XXGEM"\par
@1,903,394us: [+3 T:0x40983490 S:0x40982d04] OP -   dspArch = 0x2\par
@1,903,690us: [+3 T:0x40983490 S:0x40982d04] OP -   loaderName = "COFF"\par
@1,903,892us: [+3 T:0x40983490 S:0x40982d04] OP -   autoStart = FALSE\par
@1,904,070us: [+3 T:0x40983490 S:0x40982d04] OP -   execName = "DEFAULT.OUT"\par
@1,904,244us: [+3 T:0x40983490 S:0x40982d04] OP -   doDspCtrl = DSP_BootMode_Boot_Pwr\par
@1,904,424us: [+3 T:0x40983490 S:0x40982d04] OP -   resumeAddr = 0xc3f00020\par
@1,904,590us: [+3 T:0x40983490 S:0x40982d04] OP -   resetVector = 0xc3f00000\par
@1,904,789us: [+3 T:0x40983490 S:0x40982d04] OP -   resetCodeSize = 0x1000\par
@1,904,969us: [+3 T:0x40983490 S:0x40982d04] OP -   maduSize = 0x1\par
@1,905,132us: [+3 T:0x40983490 S:0x40982d04] OP -   cpuFreq = 0xffffffff\par
@1,905,294us: [+3 T:0x40983490 S:0x40982d04] OP -   endian = 0x3\par
@1,905,457us: [+3 T:0x40983490 S:0x40982d04] OP -   wordSwap = 0x0\par
@1,905,623us: [+3 T:0x40983490 S:0x40982d04] OP -   memTableId = 0x0\par
@1,905,785us: [+3 T:0x40983490 S:0x40982d04] OP -   memEntries = 0x4\par
@1,905,945us: [+3 T:0x40983490 S:0x40982d04] OP -   linkDrvId = 0x0\par
@1,906,132us: [+3 T:0x40983490 S:0x40982d04] OP -   arg1 = 0x0\par
@1,906,306us: [+3 T:0x40983490 S:0x40982d04] OP -   arg2 = 0x0\par
@1,906,469us: [+3 T:0x40983490 S:0x40982d04] OP -   arg3 = 0x0\par
@1,906,628us: [+3 T:0x40983490 S:0x40982d04] OP -   arg4 = 0x0\par
@1,906,788us: [+3 T:0x40983490 S:0x40982d04] OP -   arg5 = 0x0\par
@1,906,948us: [+3 T:0x40983490 S:0x40982d04] OP - \par
@1,907,100us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->dspConfigs[0]->linkDrvObjects->\par
@1,907,267us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "SHMDRV"\par
@1,907,429us: [+3 T:0x40983490 S:0x40982d04] OP -   hshkPollCount = 0x5f5e100\par
@1,907,638us: [+3 T:0x40983490 S:0x40982d04] OP -   memEntry = 0x1\par
@1,907,807us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsTableId = 0x0\par
@1,907,976us: [+3 T:0x40983490 S:0x40982d04] OP -   numIpsEntries = 0x2\par
@1,908,133us: [+3 T:0x40983490 S:0x40982d04] OP -   poolTableId = 0x0\par
@1,908,296us: [+3 T:0x40983490 S:0x40982d04] OP -   numPools = 0x1\par
@1,908,456us: [+3 T:0x40983490 S:0x40982d04] OP -   dataTableId = 0x0\par
@1,908,615us: [+3 T:0x40983490 S:0x40982d04] OP -   numDataDrivers = 0x1\par
@1,908,776us: [+3 T:0x40983490 S:0x40982d04] OP -   mqtId = 0x0\par
@1,908,977us: [+3 T:0x40983490 S:0x40982d04] OP -   ringIoTableId = 0x0\par
@1,909,151us: [+3 T:0x40983490 S:0x40982d04] OP -   mplistTableId = 0x0\par
@1,909,318us: [+3 T:0x40983490 S:0x40982d04] OP -   mpcsTableId = 0x0\par
@1,909,477us: [+3 T:0x40983490 S:0x40982d04] OP - \par
@1,909,628us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->dspConfigs[0]->memTables[0][i].\par
@1,909,794us: [+3 T:0x40983490 S:0x40982d04] OP - entry #0:\par
@1,909,955us: [+3 T:0x40983490 S:0x40982d04] OP -   entry = 0x0\par
@1,910,117us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "DDR2"\par
@1,910,306us: [+3 T:0x40983490 S:0x40982d04] OP -   physAddr = 0xc3c00000\par
@1,910,478us: [+3 T:0x40983490 S:0x40982d04] OP -   dspVirtAddr = 0xc3c00000\par
@1,910,644us: [+3 T:0x40983490 S:0x40982d04] OP -   gppVirtAddr = 0xffffffff\par
@1,910,812us: [+3 T:0x40983490 S:0x40982d04] OP -   size = 0x300000\par
@1,910,970us: [+3 T:0x40983490 S:0x40982d04] OP -   shared = TRUE\par
@1,911,128us: [+3 T:0x40983490 S:0x40982d04] OP -   syncd = FALSE\par
@1,911,286us: [+3 T:0x40983490 S:0x40982d04] OP - entry #1:\par
@1,911,442us: [+3 T:0x40983490 S:0x40982d04] OP -   entry = 0x1\par
@1,911,607us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "DSPLINKMEM"\par
@1,911,812us: [+3 T:0x40983490 S:0x40982d04] OP -   physAddr = 0xc3f01000\par
@2,243,677us: [+3 T:0x40983490 S:0x40982d04] OP -   dspVirtAddr = 0xc3f01000\par
@2,243,899us: [+3 T:0x40983490 S:0x40982d04] OP -   gppVirtAddr = 0xffffffff\par
@2,244,079us: [+3 T:0x40983490 S:0x40982d04] OP -   size = 0xff000\par
@2,244,251us: [+3 T:0x40983490 S:0x40982d04] OP -   shared = TRUE\par
@2,244,411us: [+3 T:0x40983490 S:0x40982d04] OP -   syncd = FALSE\par
@2,244,578us: [+3 T:0x40983490 S:0x40982d04] OP - entry #2:\par
@2,244,740us: [+3 T:0x40983490 S:0x40982d04] OP -   entry = 0x2\par
@2,244,958us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "RESET_VECTOR"\par
@2,245,128us: [+3 T:0x40983490 S:0x40982d04] OP -   physAddr = 0xc3f00000\par
@2,245,296us: [+3 T:0x40983490 S:0x40982d04] OP -   dspVirtAddr = 0xc3f00000\par
@2,245,460us: [+3 T:0x40983490 S:0x40982d04] OP -   gppVirtAddr = 0xffffffff\par
@2,245,620us: [+3 T:0x40983490 S:0x40982d04] OP -   size = 0x1000\par
@2,245,781us: [+3 T:0x40983490 S:0x40982d04] OP -   shared = TRUE\par
@2,245,939us: [+3 T:0x40983490 S:0x40982d04] OP -   syncd = FALSE\par
@2,246,102us: [+3 T:0x40983490 S:0x40982d04] OP - entry #3:\par
@2,246,305us: [+3 T:0x40983490 S:0x40982d04] OP -   entry = 0x3\par
@2,246,471us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "DDRALGHEAP"\par
@2,246,639us: [+3 T:0x40983490 S:0x40982d04] OP -   physAddr = 0xc3200000\par
@2,246,802us: [+3 T:0x40983490 S:0x40982d04] OP -   dspVirtAddr = 0xc3200000\par
@2,246,965us: [+3 T:0x40983490 S:0x40982d04] OP -   gppVirtAddr = 0xffffffff\par
@2,247,130us: [+3 T:0x40983490 S:0x40982d04] OP -   size = 0xa00000\par
@2,247,288us: [+3 T:0x40983490 S:0x40982d04] OP -   shared = FALSE\par
@2,247,449us: [+3 T:0x40983490 S:0x40982d04] OP -   syncd = FALSE\par
@2,247,645us: [+3 T:0x40983490 S:0x40982d04] OP - \par
@2,247,809us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->dspConfigs[0]->ipsTables[0][i].\par
@2,247,981us: [+3 T:0x40983490 S:0x40982d04] OP - entry #0:\par
@2,248,145us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "IPS"\par
@2,248,310us: [+3 T:0x40983490 S:0x40982d04] OP -   numIpsEvents = 0x20\par
@2,248,474us: [+3 T:0x40983490 S:0x40982d04] OP -   memEntry = 0x1\par
@2,248,635us: [+3 T:0x40983490 S:0x40982d04] OP -   gppIntId = 0x1c\par
@2,248,796us: [+3 T:0x40983490 S:0x40982d04] OP -   dspIntId = 0x5\par
@2,248,991us: [+3 T:0x40983490 S:0x40982d04] OP -   dspIntVectorId = 0x4\par
@2,249,166us: [+3 T:0x40983490 S:0x40982d04] OP -   arg1 = 0x2faf080\par
@2,249,330us: [+3 T:0x40983490 S:0x40982d04] OP -   arg2 = 0x0\par
@2,249,494us: [+3 T:0x40983490 S:0x40982d04] OP - entry #1:\par
@2,249,658us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "IPS"\par
@2,249,817us: [+3 T:0x40983490 S:0x40982d04] OP -   numIpsEvents = 0x20\par
@2,249,980us: [+3 T:0x40983490 S:0x40982d04] OP -   memEntry = 0x1\par
@2,250,141us: [+3 T:0x40983490 S:0x40982d04] OP -   gppIntId = 0x1d\par
@2,250,327us: [+3 T:0x40983490 S:0x40982d04] OP -   dspIntId = 0x43\par
@2,250,504us: [+3 T:0x40983490 S:0x40982d04] OP -   dspIntVectorId = 0x5\par
@2,250,671us: [+3 T:0x40983490 S:0x40982d04] OP -   arg1 = 0x2faf080\par
@2,250,836us: [+3 T:0x40983490 S:0x40982d04] OP -   arg2 = 0x0\par
@2,251,000us: [+3 T:0x40983490 S:0x40982d04] OP - \par
@2,251,162us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->dspConfigs[0]->poolTables[0][i].\par
@2,251,329us: [+3 T:0x40983490 S:0x40982d04] OP - \par
@2,251,490us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->dspConfigs[0]->dataTables[0][i].\par
@2,251,661us: [+3 T:0x40983490 S:0x40982d04] OP - entry #0:\par
@2,251,864us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "ZCPYDATA"\par
@2,252,035us: [+3 T:0x40983490 S:0x40982d04] OP -   baseChnlId = 0x0\par
@2,252,204us: [+3 T:0x40983490 S:0x40982d04] OP -   numChannels = 0x10\par
@2,252,367us: [+3 T:0x40983490 S:0x40982d04] OP -   maxBufSize = 0x4000\par
@2,252,530us: [+3 T:0x40983490 S:0x40982d04] OP -   memEntry = 0x1\par
@2,252,694us: [+3 T:0x40983490 S:0x40982d04] OP -   poolId = 0x0\par
@2,252,857us: [+3 T:0x40983490 S:0x40982d04] OP -   queuePerChnl = 0x1\par
@2,253,017us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsId = 0x1\par
@2,585,043us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsEventNo = 0x1\par
@2,585,266us: [+3 T:0x40983490 S:0x40982d04] OP -   arg1 = 0x0\par
@2,585,439us: [+3 T:0x40983490 S:0x40982d04] OP -   arg2 = 0x0\par
@2,585,606us: [+3 T:0x40983490 S:0x40982d04] OP - \par
@2,585,763us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->dspConfigs[0]->mqtObjects->\par
@2,585,930us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "ZCPYMQT"\par
@2,586,092us: [+3 T:0x40983490 S:0x40982d04] OP -   memEntry = 0x1\par
@2,586,292us: [+3 T:0x40983490 S:0x40982d04] OP -   maxMsgSize = 0xffffffff\par
@2,586,468us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsId = 0x1\par
@2,586,634us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsEventNo = 0x0\par
@2,586,800us: [+3 T:0x40983490 S:0x40982d04] OP -   arg1 = 0x0\par
@2,586,961us: [+3 T:0x40983490 S:0x40982d04] OP -   arg2 = 0x0\par
@2,587,119us: [+3 T:0x40983490 S:0x40982d04] OP - \par
@2,587,271us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->dspConfigs[0]->ringIoObjects->\par
@2,587,435us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "RINGIOTABLE"\par
@2,587,598us: [+3 T:0x40983490 S:0x40982d04] OP -   memEntry = 0x1\par
@2,587,800us: [+3 T:0x40983490 S:0x40982d04] OP -   maxEntries = 0x40\par
@2,587,966us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsId = 0x0\par
@2,588,128us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsEventNo = 0x0\par
@2,588,289us: [+3 T:0x40983490 S:0x40982d04] OP - \par
@2,588,444us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->dspConfigs[0]->mplistObjects->\par
@2,588,613us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "MPLISTTABLE"\par
@2,588,777us: [+3 T:0x40983490 S:0x40982d04] OP -   memEntry = 0x1\par
@2,588,935us: [+3 T:0x40983490 S:0x40982d04] OP -   maxEntries = 0x40\par
@2,589,139us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsId = 0xffffffff\par
@2,589,312us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsEventNo = 0xffffffff\par
@2,589,474us: [+3 T:0x40983490 S:0x40982d04] OP - \par
@2,589,627us: [+3 T:0x40983490 S:0x40982d04] OP - linkCfg->dspConfigs[0]->mpcsObjects->\par
@2,589,791us: [+3 T:0x40983490 S:0x40982d04] OP -   name = "MPCS"\par
@2,589,953us: [+3 T:0x40983490 S:0x40982d04] OP -   memEntry = 0x1\par
@2,590,115us: [+3 T:0x40983490 S:0x40982d04] OP -   maxEntries = 0x100\par
@2,590,275us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsId = 0xffffffff\par
@2,590,467us: [+3 T:0x40983490 S:0x40982d04] OP -   ipsEventNo = 0xffffffff\par
@2,596,006us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Attaching to DSP PROC...\par
@2,617,982us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Opening MSGQ pool...\par
@2,619,200us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Loading cs.x64P on DSP (1 args)...\par
@3,590,856us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Starting DSP PROC...\par
@3,656,435us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> Opening remote transport...\par
@3,658,976us: [+2 T:0x40983490 S:0x40982d64] OP - Processor_create_d> return (1)\par
@3,659,240us: [+0 T:0x40983490 S:0x40982d54] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x4b1d8]\par
@3,659,520us: [+0 T:0x4001e320 S:0xbea7b67c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x4b1d8] status[0]\par
@3,659,745us: [+0 T:0x4001e320 S:0xbea7b69c] OP - doCmd> Exit (result=1)\par
@3,659,918us: [+0 T:0x4001e320 S:0xbea7b6bc] OP - Processor_create> return (0x4b808)\par
@3,660,091us: [+0 T:0x4001e320 S:0xbea7b6f4] CE - rserverOpen('cs.x64P'): 0x4a654 done.\par
@3,660,282us: [+0 T:0x4001e320 S:0xbea7b6dc] OM - Memory_alloc> Enter(0x29)\par
@3,660,470us: [+0 T:0x4001e320 S:0xbea7b6dc] OM - Memory_alloc> return (0x4ba68)\par
@3,660,849us: [+0 T:0x4001e320 S:0xbea7b6cc] OC - Comm_create> Enter(queueName='image1_copy_796_0', queue=0x4b7e8, attrs=0x0)\par
@3,661,075us: [+0 T:0x4001e320 S:0xbea7b6b4] OM - Memory_alloc> Enter(0x4)\par
@3,661,277us: [+0 T:0x4001e320 S:0xbea7b6b4] OM - Memory_alloc> return (0x4ba98)\par
@3,662,970us: [+0 T:0x4001e320 S:0xbea7b6cc] OC - Comm_create> return (0x4ba98)\par
@3,663,231us: [+0 T:0x4001e320 S:0xbea7b6d4] OM - Memory_free> Enter(0x4ba68, 0x29)\par
@3,663,501us: [+0 T:0x4001e320 S:0xbea7b6d4] OM - Memory_free> return (0x1)\par
@3,663,923us: [+0 T:0x4001e320 S:0xbea7b6d4] OC - Comm_alloc> Enter(poolId=0x0, msg=0x4b7f4, size=576)\par
@3,664,174us: [+0 T:0x4001e320 S:0xbea7b6d4] OC - Comm_alloc> msg=0x41190c80, returning (0)\par
@3,664,367us: [+0 T:0x4001e320 S:0xbea7b6bc] OC - Comm_locate> Enter(queueName='rmsq', queue=0x4b7e4)\par
@3,665,457us: [+0 T:0x4001e320 S:0xbea7b6bc] OC - Comm_locate> return (0)\par
@3,665,718us: [+0 T:0x4001e320 S:0xbea7b6f4] CE - checkServer(0x4b7d8)\par
@3,665,997us: [+0 T:0x4001e320 S:0xbea7b6c4] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@3,666,294us: [+0 T:0x4001e320 S:0xbea7b6c4] OC - Comm_put> return (0)\par
@3,666,806us: [+0 T:0x4001e320 S:0xbea7b6bc] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b760, timeout=-1)\par
@3,667,050us: [+0 T:0x4001e320 S:0xbea7b6bc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
@3,667,275us: [+0 T:0x4001e320 S:0xbea7b6f4] CE - rmsInit> RMS initialized(0x4b7d8); CE_DEBUG on, setting DSP trace mask to *+01234567,GT_prefix=12345,GT_time=3\par
@3,667,483us: [+0 T:0x4001e320 S:0xbea7b6cc] CE - Engine_setTrace> Enter(engine=0x4b7d8, mask='*+01234567,GT_prefix=12345,GT_time=3')\par
@3,667,693us: [+1 T:0x4001e320 S:0xbea7b6cc] CE - Engine_setTrace> Requesting DSP set trace ...\par
@3,667,861us: [+0 T:0x4001e320 S:0xbea7b69c] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@3,668,115us: [+0 T:0x4001e320 S:0xbea7b69c] OC - Comm_put> return (0)\par
@3,668,305us: [+0 T:0x4001e320 S:0xbea7b694] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b714, timeout=-1)\par
@3,668,585us: [+0 T:0x40983490 S:0x40982d64] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x4b1d8]\par
@3,668,806us: [+0 T:0x40983490 S:0x40982d64] OP - getCmd_d> Enter (proc=0x40982dd8)\par
@3,668,985us: [+0 T:0x40983490 S:0x40982d44] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x4b1c0] timeout[0xffffffff]\par
@3,671,905us: [+0 T:0x4001e320 S:0xbea7b694] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
@3,672,152us: [+0 T:0x4001e320 S:0xbea7b6cc] CE - Engine_setTrace> return(0)\par
@3,672,357us: [+0 T:0x4001e320 S:0xbea7b65c] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@3,672,615us: [+0 T:0x4001e320 S:0xbea7b65c] OC - Comm_put> return (0)\par
@3,672,884us: [+0 T:0x4001e320 S:0xbea7b654] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b6f4, timeout=-1)\par
@3,673,322us: [+0 T:0x4001e320 S:0xbea7b654] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
[DSP] @0x00000112:[T:0x00000000] codec_unitserver - main> Welcome to CS1OMAPL138 Ver: 1.00.00 DSP server's main()\par
[DSP] @0,014,290tk: [+0 T:0xc3db5c2c S:0xc3db6ba4] OG - Global_setSpecialTrace> enter(mask='*+01234567,GT_prefix=12345,GT_time=3')\par
[DSP] @0,014,348tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG - Global_setSpecialTrace> This program was built with the following packages:\par
[DSP] @0,014,401tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.targets.rts6000 (/storage/dvsdk/aravind/sdk_freon/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/ti/targets/rts6000/) [1, 0, 0, 0]\par
[DSP] @0,014,468tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.aachedec (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/aachedec/) [1, 0, 0]\par
[DSP] @0,014,538tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.g711dec (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/g711dec/) [1, 0, 0]\par
[DSP] @0,014,606tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.g711enc (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/g711enc/) [1, 0, 0]\par
[DSP] @0,014,675tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.h264dec (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/h264dec/) [1, 0, 0]\par
[DSP] @0,014,744tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.h264enc (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/h264enc/) [1, 0, 0]\par
[DSP] @0,014,813tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.jpegdec (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/jpegdec/) [1, 0, 0]\par
[DSP] @0,014,882tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.jpegenc (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/jpegenc/) [1, 0, 0]\par
[DSP] @0,014,951tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.mpeg2dec (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0]\par
[DSP] @0,015,020tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.mpeg4dec (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg4dec/) [1, 0, 0]\par
[DSP] @0,015,089tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.mpeg4enc (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0]\par
[DSP] @0,015,158tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.fc.global (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/framework_components_2_25_00_04/packages/ti/sdo/fc/global/) [1, 0, 0]\par
[DSP] @0,015,227tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.utils.trace (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/framework_components_2_25_00_04/packages/ti/sdo/utils/trace/) [1, 0, 0]\par
[DSP] @0,015,298tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.xdais (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/xdais_6_25_01_08/packages/ti/xdais/) [1, 2.0, 1]\par
[DSP] @0,015,360tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.rtdx (/storage/dvsdk/aravind/sdk_freon/OMAP_L138_arm_1_00_00_08/bios_5_41_02_14/packages/ti/rtdx/) [2, 0, 0, 5]\par
[DSP] @0,015,420tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.psl (/storage/dvsdk/aravind/sdk_freon/OMAP_L138_arm_1_00_00_08/bios_5_41_02_14/packages/ti/psl/) [5, 0, 0, 0]\par
[DSP] @0,015,481tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.pmi (/storage/dvsdk/aravind/sdk_freon/OMAP_L138_arm_1_00_00_08/bios_5_41_02_14/packages/ti/pmi/) [1, 0, 0, 0]\par
[DSP] @0,015,541tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.pscl (/storage/dvsdk/aravind/sdk_freon/OMAP_L138_arm_1_00_00_08/bios_5_41_02_14/packages/ti/pscl/) [1, 0, 0, 0]\par
[DSP] @0,015,604tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG@4,139,703us: [+0 T:0x4001e320 S:0xbea7b65c] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@4,140,022us: [+0 T:0x4001e320 S:0xbea7b65c] OC - Comm_put> return (0)\par
@4,471,457us: [+0 T:0x4001e320 S:0xbea7b654] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b6f4, timeout=-1)\par
@4,471,740us: [+0 T:0x4001e320 S:0xbea7b654] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
 -     package ti.bios (/storage/dvsdk/aravind/sdk_freon/OMAP_L138_arm_1_00_00_08/bios_5_41_02_14/packages/ti/bios/) [5, 2, 5, 25]\par
[DSP] @0,015,665tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.fc.dskt2 (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/framework_components_2_25_00_04/packages/ti/sdo/fc/dskt2/) [1, 0, 4]\par
[DSP] @0,015,734tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.fc.dman3 (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/framework_components_2_25_00_04/packages/ti/sdo/fc/dman3/) [1, 0, 4]\par
[DSP] @0,015,803tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.global (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/global/) [1, 0, 0]\par
[DSP] @0,015,870tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.xdais.dm (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/xdais_6_25_01_08/packages/ti/xdais/dm/) [1, 0, 5]\par
[DSP] @0,015,933tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.utils.xdm (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]\par
[DSP] @0,016,002tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.node (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/node/) [1, 0, 0]\par
[DSP] @0,016,067tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.ipc.dsplink.dsp (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2, 0, 1]\par
[DSP] @0,016,139tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.fc.memutils (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/framework_components_2_25_00_04/packages/ti/sdo/fc/memutils/) [1, 0, 0]\par
[DSP] @0,016,209tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.fc.acpy3 (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/framework_components_2_25_00_04/packages/ti/sdo/fc/acpy3/) [1, 0, 4]\par
[DSP] @0,016,278tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package dsplink.dsp (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/dsplink_linux_1_65_00_01/dsplink/dsp/) [1, 4, 0]\par
[DSP] @0,016,341tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.bios.utils (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/biosutils_1_02_02/packages/ti/bios/utils/) [2, 0, 2, 02]\par
[DSP] @0,016,406tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.catalog.c6000 (/storage/dvsdk/aravind/sdk_freon/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/ti/catalog/c6000/) [1, 0, 0, 0]\par
[DSP] @0,016,472tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.catalog (/storage/dvsdk/aravind/sdk_freon/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/ti/catalog/) [1, 0, 0]\par
[DSP] @0,016,535tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.catalog.arm (/storage/dvsdk/aravind/sdk_freon/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/ti/catalog/arm/) [1, 0, 1, 0]\par
[DSP] @0,016,600tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.platforms.evmOMAPL138 (/storage/dvsdk/aravind/sdk_freon/OMAP_L138_arm_1_00_00_08/xdctools_3_16_01_27/packages/ti/platforms/evmOMAPL138/) [1, 0, 0]\par
[DSP] @0,016,669tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.osal (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/osal/) [2, 0, 2]\par
[DSP] @0,016,738tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.osal.bios (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/osal/bios/) [2, 0, 1]\par
[DSP] @0,016,807tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.ipc (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/ipc/) [2, 0, 1]\par
[DSP] @0,016,872tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.ipc.bios (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/ipc/bios/) [2, 0, 1]\par
[DSP] @0,016,941tk: [+4 T:0xc3db5c2c S:0xc3db6ba4]@4,809,481us: [+0 T:0x4001e320 S:0xbea7b65c] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@4,809,793us: [+0 T:0x4001e320 S:0xbea7b65c] OC - Comm_put> return (0)\par
@4,810,272us: [+0 T:0x4001e320 S:0xbea7b654] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b6f4, timeout=-1)\par
@4,810,545us: [+0 T:0x4001e320 S:0xbea7b654] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
 OG -     package ti.sdo.ce.alg (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/alg/) [1, 0, 1]\par
[DSP] @0,017,006tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/) [1, 0, 6]\par
[DSP] @0,017,070tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.bioslog (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/bioslog/) [1, 0, 1]\par
[DSP] @0,017,137tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.audio1 (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/audio1/) [1, 0, 1]\par
[DSP] @0,017,205tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.aachedec.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/aachedec/ce/) [1, 0, 0]\par
[DSP] @0,017,275tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.speech1 (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/speech1/) [1, 0, 1]\par
[DSP] @0,017,343tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.g711dec.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/g711dec/ce/) [1, 0, 0]\par
[DSP] @0,017,413tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.g711enc.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/g711enc/ce/) [1, 0, 0]\par
[DSP] @0,017,484tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.video2 (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/video2/) [1, 0, 2]\par
[DSP] @0,017,551tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.h264dec.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/h264dec/ce/) [1, 0, 0]\par
[DSP] @0,017,622tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.video1 (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/video1/) [1, 0, 2]\par
[DSP] @0,017,689tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.h264enc.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0]\par
[DSP] @0,017,759tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.ce.image1 (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/codec_engine_2_25_00_05/packages/ti/sdo/ce/image1/) [1, 0, 1]\par
[DSP] @0,017,826tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.jpegdec.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/jpegdec/ce/) [1, 0, 0]\par
[DSP] @0,017,897tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.jpegenc.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/jpegenc/ce/) [1, 0, 0]\par
[DSP] @0,017,970tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.mpeg2dec.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0]\par
[DSP] @0,018,040tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.mpeg4dec.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg4dec/ce/) [1, 0, 0]\par
[DSP] @0,018,111tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.codecs.mpeg4enc.ce (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0]\par
[DSP] @0,018,182tk: [+4 T:0xc3db5c2c S:0xc3db6ba4] OG -     package ti.sdo.server.cs (/storage/dvsdk/aravind/sdk_freon/tmp/OMAP_L138_arm_1_00_00_08/cs1omapl138_1_00_00/packages/ti/sdo/server/cs/) [1, 0, 0]\par
[DSP] @0,018,248tk: [+0 T:0xc3db5c2c S:0xc3db6ba4] OG - Global_setSpecialTrace> return\par
[DSP] @0,019,548t@5,149,036us: [+0 T:0x4001e320 S:0xbea7b65c] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@5,149,346us: [+0 T:0x4001e320 S:0xbea7b65c] OC - Comm_put> return (0)\par
@5,149,802us: [+0 T:0x4001e320 S:0xbea7b654] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b6f4, timeout=-1)\par
@5,150,098us: [+0 T:0x4001e320 S:0xbea7b654] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
k: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - processRmsCmd(0xc3f06ca8, 4056): cmd = 5\par
[DSP] @0,019,594tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - remote time = 0x0, trace buffer size = 4032\par
[DSP] @0,567,290tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - processRmsCmd(0xc3f06ca8, 4056): cmd = 5\par
[DSP] @0,567,335tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - remote time = 0x0, trace buffer size = 4032\par
[DSP] @1,352,180tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - processRmsCmd(0xc3f06ca8, 4056): cmd = 5\par
[DSP] @1,352,225tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - remote time = 0x0, trace buffer size = 4032\par
[DSP] @1,750,096tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - processRmsCmd(0xc3f06ca8, 4056): cmd = 5\par
[DSP] @1,750,141tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - remote time = 0x0, trace buffer size = 4032\par
@5,151,653us: [+0 T:0x4001e320 S:0xbea7b68c] CE - Engine_fwriteTrace> returning count [13239]\par
@5,151,848us: [+0 T:0x4001e320 S:0xbea7b6f4] CE - Engine_open> return(309208)\par
Engine Opened\par
@5,152,317us: [+0 T:0x4001e320 S:0xbea7b72c] ti.sdo.ce.image1.IMGENC1 - IMGENC1_create> Enter (engine=0x4b7d8, name='jpegenc', params=0xbea7bc44)\par
@5,152,639us: [+0 T:0x4001e320 S:0xbea7b6fc] CV - VISA_create(0x4b7d8, 'jpegenc', 0xbea7bc44, 0x460, 'ti.sdo.ce.image1.IIMGENC1')\par
@5,152,897us: [+0 T:0x4001e320 S:0xbea7b5fc] CV - VISA_create2(0x4b7d8, 'jpegenc', 0xbea7bc44, 0x18, 0x460, 'ti.sdo.ce.image1.IIMGENC1')\par
@5,153,138us: [+0 T:0x4001e320 S:0xbea7b5e4] OM - Memory_alloc> Enter(0x34)\par
@5,153,335us: [+0 T:0x4001e320 S:0xbea7b5e4] OM - Memory_alloc> return (0x4baf8)\par
@5,153,518us: [+0 T:0x4001e320 S:0xbea7b584] CE - Engine_createNode(0x4b7d8, 'jpegenc', 460, 0xbea7bc44, 0x18, 0xbea7b6f4)\par
@5,153,880us: [+0 T:0x4001e320 S:0xbea7b584] CE - Engine> allocNode Enter(engine=0x4b7d8, impId='jpegenc')\par
@5,154,066us: [+0 T:0x4001e320 S:0xbea7b56c] OM - Memory_alloc> Enter(0x20)\par
@5,154,298us: [+0 T:0x4001e320 S:0xbea7b56c] OM - Memory_alloc> return (0x4bb30)\par
@5,154,521us: [+0 T:0x4001e320 S:0xbea7b584] CE - Engine> allocNode(). Calling (Comm_create(gppfromnode_796_1, 0x4bb38, NULL)\par
@5,154,712us: [+0 T:0x4001e320 S:0xbea7b55c] OC - Comm_create> Enter(queueName='gppfromnode_796_1', queue=0x4bb38, attrs=0x0)\par
@5,154,897us: [+0 T:0x4001e320 S:0xbea7b544] OM - Memory_alloc> Enter(0x4)\par
@5,155,077us: [+0 T:0x4001e320 S:0xbea7b544] OM - Memory_alloc> return (0x4bb58)\par
@5,156,833us: [+0 T:0x4001e320 S:0xbea7b55c] OC - Comm_create> return (0x4bb58)\par
@5,157,162us: [+0 T:0x4001e320 S:0xbea7b564] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@5,489,005us: [+0 T:0x4001e320 S:0xbea7b564] OC - Comm_put> return (0)\par
@5,489,241us: [+0 T:0x4001e320 S:0xbea7b55c] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b60c, timeout=-1)\par
@5,490,725us: [+0 T:0x4001e320 S:0xbea7b55c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
@5,490,974us: [+0 T:0x4001e320 S:0xbea7b564] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@5,491,245us: [+0 T:0x4001e320 S:0xbea7b564] OC - Comm_put> return (0)\par
@5,491,728us: [+0 T:0x4001e320 S:0xbea7b55c] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b60c, timeout=-1)\par
@5,491,978us: [+0 T:0x4001e320 S:0xbea7b55c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
@5,492,174us: [+4 T:0x4001e320 S:0xbea7b584] CE - Engine_createNode> created node(stdIn=0x2, stdOut=0x10001, msgq=0x4bb58, algName='jpegenc', rmsNode=0xc3db8778, algHandle=0xc3db8860)\par
@5,492,412us: [+0 T:0x4001e320 S:0xbea7b4ec] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@5,492,672us: [+0 T:0x4001e320 S:0xbea7b4ec] OC - Comm_put> return (0)\par
@5,493,132us: [+0 T:0x4001e320 S:0xbea7b4e4] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b584, timeout=-1)\par
@5,493,393us: [+0 T:0x4001e320 S:0xbea7b4e4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
[DSP] @2,148,126tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - processRmsCmd(0xc3f06ca8, 4056): cmd = 0\par
[DSP] @2,148,179tk: [+0 T:0xc3db5c2c S:0xc3db6adc] OM - Memory_alloc> Enter(size=0x18)\par
[DSP] @2,148,219tk: [+0 T:0xc3db5c2c S:0xc3db6adc] OM - Memory_alloc> return (0xc3db8778)\par
[DSP] @2,148,263tk: [+0 T:0xc3db5c2c S:0xc3db6adc] OM - Memory_alloc> Enter(size=0xa)\par
[DSP] @2,148,302tk: [+0 T:0xc3db5c2c S:0xc3db6adc] OM - Memory_alloc> return (0xc3db8790)\par
[DSP] @2,148,348tk: [+0 T:0xc3db5c2c S:0xc3db6aa4] OM - Memory_alloc> Enter(size=0x20)\par
[DSP] @2,148,388tk: [+0 T:0xc3db5c2c S:0xc3db6aa4] OM - Memory_alloc> return (0xc3db87a0)\par
[DSP] @2,148,429tk: [+0 T:0xc3db5c2c S:0xc3db6a74] OM - Memory_alloc> Enter(size=0x24)\par
[DSP] @2,148,473tk: [+0 T:0xc3db5c2c S:0xc3db6a74] OM - Memory_alloc> return (0xc3db87c0)\par
[DSP] @2,148,529tk: [+0 T:0xc3db5c2c S:0xc3db6a8c] ti.sdo.ce.image1.IMGENC1 - IMGENC1_create> Enter (engine=0x0, name='jpegenc', params=0xc3f06cc0)\par
[DSP] @2,148,594tk: [+0 T:0xc3db5c2c S:0xc3db6a54] CV - VISA_create(0x0, 'jpegenc', 0xc3f06cc0, 0x460, 'ti.sdo.ce.image1.IIMGENC1')\par
[DSP] @2,148,652tk: [+0 T:0xc3db5c2c S:0xc3db6944] CV - VISA_create2(0x0, 'jpegenc', 0xc3f06cc0, 0x18, 0x460, 'ti.sdo.ce.image1.IIMGENC1')\par
[DSP] @2,148,719tk: [+0 T:0xc3db5c2c S:0xc3db68dc] CE - Engine_open> Enter('local', 0xc3db692c, 0xc3f06cc0)\par
[DSP] @2,148,771tk: [+0 T:0xc3db5c2c S:0xc3db68bc] OM - Memory_alloc> Enter(size=0x2c)\par
[DSP] @2,148,810tk: [+0 T:0xc3db5c2c S:0xc3db68bc] OM - Memory_alloc> return (0xc3db8830)\par
[DSP] @2,148,858tk: [+0 T:0xc3db5c2c S:0xc3db68dc] CE - Engine_open> return(-1009022928)\par
[DSP] @2,148,913tk: [+0 T:0xc3db5c2c S:0xc3db6924] OM - Memory_alloc> Enter(size=0x34)\par
[DSP] @2,148,953tk: [+0 T:0xc3db5c2c S:0xc3db6924] OM - Memory_alloc> return (0xc3db8860)\par
[DSP] @2,148,998tk: [+0 T:0xc3db5c2c S:0xc3db68fc] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0xc3d53f8c, idma3Fxns=0x0, iresFxns=0x0, params=0xc3f06cc0, attrs=0xc3db6a40)\par
[DSP] @2,149,072tk: [+0 T:0xc3db5c2c S:0xc3db68dc] OM - Memory_alloc> Enter(size=0x10)\par
[DSP] @2,149,111tk: [+0 T:0xc3db5c2c S:0xc3db68dc] OM - Memory_alloc> return (0xc3db8898)\par
[DSP] @2,149,395tk: [+0 T:0xc3db5c2c S:0xc3db68fc] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0xc3db8898)\par
[DSP] @2,149,443tk: [+5 T:0xc3db5c2c S:0xc3db6944] CV - VISA_create> local codec created (name='jpegenc', handle=0xc3db8898)\par
[DSP] @2,149,495tk: [+0 T:0xc3db5c2c S:0xc3db6a8c] ti.sdo.ce.image1.IMGENC1 - IMGENC_create> return (0xc3db8860)\par
[DSP] @2,149,546tk: [+4 T:0xc3db5c2c S:0xc3db6a4c] OT - Thread_create > name: "jpegenc#0", pri:  -1, stack size:  17192, stack seg: 0\par
[DSP] @2,150,767tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - processRmsCmd(0xc3f06ca8, 4056): cmd = 1\par
[DSP] @2,152,435tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - processRmsCmd(0xc3f06ca8, 4056): cmd = 5\par
[DSP] @2,152,481tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - remote time = 0x0, trace buffer size = 4032\par
@5,829,329us: [+0 T:0x4001e320 S:0xbea7b51c] CE - Engine_fwriteTrace> returning count [2916]\par
@5,829,550us: [+2 T:0x4001e320 S:0xbea7b584] CE - Engine_createNode> Returning 0x4bb30\par
@5,829,731us: [+0 T:0x4001e320 S:0xbea7b5e4] OM - Memory_alloc> Enter(0x4)\par
@5,829,920us: [+0 T:0x4001e320 S:0xbea7b5e4] OM - Memory_alloc> return (0x4bb68)\par
@5,830,100us: [+0 T:0x4001e320 S:0xbea7b5dc] OC - Comm_alloc> Enter(poolId=0x0, msg=0x4bb68, size=460)\par
@5,830,394us: [+0 T:0x4001e320 S:0xbea7b5dc] OC - Comm_alloc> msg=0x41191c80, returning (0)\par
@5,830,624us: [+5 T:0x4001e320 S:0xbea7b5fc] CV - VISA_create> remote codec created (name='jpegenc', localQueueID=0x10001, remoteQueueID=0x0002)\par
@5,830,842us: [+0 T:0x4001e320 S:0xbea7b72c] ti.sdo.ce.image1.IMGENC1 - IMGENC_create> return (0x4baf8)\par
Encoder Created\par
\cf1\f1 @5,831,090us: [+0 T:0x4001e320 S:0xbea7b6e4] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Enter (handle=0x4baf8, id=1, dynParams=0xbea7bc24 (size=0x44), status=0xbea7bb64 (size=0xa0)\par
@5,831,314us: [+4 T:0x4001e320 S:0xbea7b6a4] CV - VISA_getMaxMsgSize(0x4baf8): returning 0x1000\par
@5,831,496us: [+5 T:0x4001e320 S:0xbea7b6ac] CV - VISA_allocMsg> Allocating message for messageId=0x0002cc03\par
@5,831,736us: [+0 T:0x4001e320 S:0xbea7b67c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x401805e8, size=0)\par
@5,831,926us: [+6 T:0x4001e320 S:0xbea7b67c] OM - Memory_getBufferPhysicalAddress> invalid buffer size provided (0)\par
@5,832,104us: [+0 T:0x4001e320 S:0xbea7b67c] OM - Memory_getBufferPhysicalAddress> return (0x0)\par
@5,832,277us: [+5 T:0x4001e320 S:0xbea7b694] CV - VISA_freeMsg(0x4baf8, 0x41191c80): Freeing message with messageId=0x0002cc03\par
@5,832,461us: [+0 T:0x4001e320 S:0xbea7b6e4] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Exit (handle=0x4baf8, retVal=0xffffffff)\par
app: error: could not set PARAMS: 0x63333632\cf0\f0\par
@5,833,057us: [+0 T:0x4001e320 S:0xbea7b744] ti.sdo.ce.image1.IMGENC1 - IMGENC1_delete> Enter (handle=0x4baf8)\par
@5,833,274us: [+0 T:0x4001e320 S:0xbea7b71c] CV - VISA_delete(0x4baf8)\par
@5,833,444us: [+5 T:0x4001e320 S:0xbea7b71c] CV - VISA_delete> deleting codec (localQueue=0x10001, remoteQueue=0x2)\par
@5,833,769us: [+0 T:0x4001e320 S:0xbea7b6ec] OC - Comm_put> Enter(queue=0x2, msg=0x41191c80)\par
@5,834,069us: [+0 T:0x4001e320 S:0xbea7b6ec] OC - Comm_put> return (0)\par
@5,834,597us: [+0 T:0x4001e320 S:0xbea7b6f4] OC - Comm_get> Enter(queue=0x10001, msg=0x4bb68, timeout=-1)\par
@5,834,837us: [+0 T:0x4001e320 S:0xbea7b6f4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
@5,835,035us: [+0 T:0x4001e320 S:0xbea7b6d4] CE - Engine_deleteNode(0x4bb30)\par
@5,835,222us: [+0 T:0x4001e320 S:0xbea7b6b4] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@5,835,483us: [+0 T:0x4001e320 S:0xbea7b6b4] OC - Comm_put> return (0)\par
@5,835,676us: [+0 T:0x4001e320 S:0xbea7b6ac] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b72c, timeout=-1)\par
@5,837,058us: [+0 T:0x4001e320 S:0xbea7b6ac] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
@5,837,337us: [+5 T:0x4001e320 S:0xbea7b6d4] CE - Engine_deleteNode(0x4bb30): algName = jpegenc, algHandle = 0xc3db8860, stack size = 17192, stack used = 247(2%)\par
@5,837,554us: [+0 T:0x4001e320 S:0xbea7b6ac] OC - Comm_delete> Enter (comm=0x4bb58)\par
@5,838,586us: [+0 T:0x4001e320 S:0xbea7b68c] OM - Memory_free> Enter(0x4bb58, 0x4)\par
@5,838,859us: [+0 T:0x4001e320 S:0xbea7b68c] OM - Memory_free> return (0x1)\par
@5,839,052us: [+0 T:0x4001e320 S:0xbea7b6cc] OC - Comm_delete> return\par
@5,839,233us: [+0 T:0x4001e320 S:0xbea7b6b4] OM - Memory_free> Enter(0x4bb30, 0x20)\par
@5,839,415us: [+0 T:0x4001e320 S:0xbea7b6b4] OM - Memory_free> return (0x1)\par
@5,839,595us: [+0 T:0x4001e320 S:0xbea7b70c] OC - Comm_free> Enter (msg=0x41191c80)\par
@6,170,514us: [+0 T:0x4001e320 S:0xbea7b70c] OC - Comm_free> return (0)\par
@6,170,748us: [+0 T:0x4001e320 S:0xbea7b6fc] OM - Memory_free> Enter(0x4bb68, 0x4)\par
@6,170,947us: [+0 T:0x4001e320 S:0xbea7b6fc] OM - Memory_free> return (0x1)\par
@6,171,121us: [+0 T:0x4001e320 S:0xbea7b6fc] OM - Memory_free> Enter(0x4baf8, 0x34)\par
@6,171,299us: [+0 T:0x4001e320 S:0xbea7b6fc] OM - Memory_free> return (0x1)\par
@6,171,470us: [+0 T:0x4001e320 S:0xbea7b754] ti.sdo.ce.image1.IMGENC1 - IMGENC1_delete> return\par
@6,171,691us: [+0 T:0x4001e320 S:0xbea7b734] CE - Engine_close(0x4b7d8)\par
@6,171,889us: [+0 T:0x4001e320 S:0xbea7b69c] OC - Comm_put> Enter(queue=0x0, msg=0x41190c80)\par
@6,172,158us: [+0 T:0x4001e320 S:0xbea7b69c] OC - Comm_put> return (0)\par
@6,172,627us: [+0 T:0x4001e320 S:0xbea7b694] OC - Comm_get> Enter(queue=0x10000, msg=0xbea7b734, timeout=-1)\par
@6,172,890us: [+0 T:0x4001e320 S:0xbea7b694] OC - Comm_get> MSGQ_get() status=0x8000, return (0)\par
[DSP] @2,552,541tk: [+0 T:0xc3db8cdc S:0xc3dbcfcc] CN - NODE_EXECFXN(0xc3db87a0): jpegenc#0 exiting per request ...\par
[DSP] @2,554,167tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - processRmsCmd(0xc3f06ca8, 4056): cmd = 2\par
[DSP] @2,554,695tk: [+0 T:0xc3db5c2c S:0xc3db6ba4] CN - NODE_delete(0xc3db87a0): jpegenc#0\par
[DSP] @2,554,746tk: [+0 T:0xc3db5c2c S:0xc3db6b84] ti.sdo.ce.image1.IMGENC1 - IMGENC1_delete> Enter (handle=0xc3db8860)\par
[DSP] @2,554,797tk: [+0 T:0xc3db5c2c S:0xc3db6b54] CV - VISA_delete(0xc3db8860)\par
[DSP] @2,554,840tk: [+5 T:0xc3db5c2c S:0xc3db6b54] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)\par
[DSP] @2,554,890tk: [+5 T:0xc3db5c2c S:0xc3db6b54] CV - VISA_delete> deleting codec 0xc3db8898\par
[DSP] @2,554,935tk: [+0 T:0xc3db5c2c S:0xc3db6b34] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0xc3db8898)\par
[DSP] @2,555,013tk: [+0 T:0xc3db5c2c S:0xc3db6b04] OM - Memory_free> Enter(addr=0xc3db8898, size=16)\par
[DSP] @2,555,062tk: [+0 T:0xc3db5c2c S:0xc3db6b04] OM - Memory_free> return (0x1)\par
[DSP] @2,555,098tk: [+0 T:0xc3db5c2c S:0xc3db6b34] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Exit\par
[DSP] @2,555,143tk: [+0 T:0xc3db5c2c S:0xc3db6b24] OM - Memory_free> Enter(addr=0xc3db8860, size=52)\par
[DSP] @2,555,190tk: [+0 T:0xc3db5c2c S:0xc3db6b24] OM - Memory_free> return (0x1)\par
[DSP] @2,555,227tk: [+0 T:0xc3db5c2c S:0xc3db6b84] ti.sdo.ce.image1.IMGENC1 - IMGENC1_delete> return\par
[DSP] @2,555,268tk: [+0 T:0xc3db5c2c S:0xc3db6b6c] OM - Memory_free> Enter(addr=0xc3db87c0, size=36)\par
[DSP] @2,555,314tk: [+0 T:0xc3db5c2c S:0xc3db6b6c] OM - Memory_free> return (0x1)\par
[DSP] @2,555,351tk: [+0 T:0xc3db5c2c S:0xc3db6b74] OM - Memory_free> Enter(addr=0xc3db87a0, size=32)\par
[DSP] @2,555,396tk: [+0 T:0xc3db5c2c S:0xc3db6b74] OM - Memory_free> return (0x1)\par
[DSP] @2,555,433tk: [+0 T:0xc3db5c2c S:0xc3db6b94] OM - Memory_free> Enter(addr=0xc3db8790, size=10)\par
[DSP] @2,555,479tk: [+0 T:0xc3db5c2c S:0xc3db6b94] OM - Memory_free> return (0x1)\par
[DSP] @2,555,516tk: [+0 T:0xc3db5c2c S:0xc3db6b94] OM - Memory_free> Enter(addr=0xc3db8778, size=24)\par
[DSP] @2,555,561tk: [+0 T:0xc3db5c2c S:0xc3db6b94] OM - Memory_free> return (0x1)\par
[DSP] @2,948,708tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - processRmsCmd(0xc3f06ca8, 4056): cmd = 5\par
[DSP] @2,948,753tk: [+0 T:0xc3db5c2c S:0xc3db6bec] CR - remote time = 0x0, trace buffer size = 4032\par
@6,177,266us: [+0 T:0x4001e320 S:0xbea7b6cc] CE - Engine_fwriteTrace> returning count [2336]\par
@6,177,471us: [+0 T:0x4001e320 S:0xbea7b714] CS - Server_disconnectTrace('0x4b7d8', 0x0)\par
@6,177,650us: [+0 T:0x4001e320 S:0xbea7b714] CS - Server_connectTrace> return(0)\par
@6,177,822us: [+0 T:0x4001e320 S:0xbea7b724] OC - Comm_free> Enter (msg=0x41190c80)\par
@6,178,041us: [+0 T:0x4001e320 S:0xbea7b724] OC - Comm_free> return (0)\par
@6,178,223us: [+0 T:0x4001e320 S:0xbea7b714] OC - Comm_delete> Enter (comm=0x4ba98)\par
@6,179,232us: [+0 T:0x4001e320 S:0xbea7b6f4] OM - Memory_free> Enter(0x4ba98, 0x4)\par
@6,179,504us: [+0 T:0x4001e320 S:0xbea7b6f4] OM - Memory_free> return (0x1)\par
@6,510,496us: [+0 T:0x4001e320 S:0xbea7b734] OC - Comm_delete> return\par
@6,510,722us: [+0 T:0x4001e320 S:0xbea7b724] OC - Comm_release> Enter(queue=0x0)\par
@6,510,937us: [+0 T:0x4001e320 S:0xbea7b724] OC - Comm_release> return (0)\par
@6,511,122us: [+0 T:0x4001e320 S:0xbea7b734] CE - rserverClose(0x4a654), count = 1\par
@6,511,299us: [+0 T:0x4001e320 S:0xbea7b71c] OP - Processor_delete> Enter(proc=0x4b808)\par
@6,511,472us: [+0 T:0x4001e320 S:0xbea7b6fc] OP - doCmd> Enter (cmdId=2, proc=0x4b808)\par
@6,511,640us: [+0 T:0x4001e320 S:0xbea7b6ec] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x4b1c0]\par
@6,511,947us: [+0 T:0x40983490 S:0x40982d44] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x4b1c0] status[0]\par
@6,512,169us: [+0 T:0x40983490 S:0x40982d64] OP - getCmd_d> Exit (result=2)\par
@6,512,351us: [+0 T:0x40983490 S:0x40982d4c] OP - Processor_delete_d> Enter (proc=0x4b808)\par
@6,512,523us: [+2 T:0x40983490 S:0x40982d4c] OP - Processor_delete_d> Closing remote transport...\par
@6,513,507us: [+2 T:0x40983490 S:0x40982d4c] OP - Processor_delete_d> Stopping DSP...\par
@6,514,105us: [+0 T:0x4001e320 S:0xbea7b6fc] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x4b1c0]\par
@6,514,335us: [+0 T:0x4001e320 S:0xbea7b6dc] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x4b1d8] timeout[0xffffffff]\par
@6,514,757us: [+2 T:0x40983490 S:0x40982d4c] OP - Processor_delete_d> Closing pool...\par
@6,515,607us: [+2 T:0x40983490 S:0x40982d4c] OP - Processor_delete_d> Detaching from DSP...\par
@6,527,552us: [+2 T:0x40983490 S:0x40982d4c] OP - Processor_delete_d> Destroying DSP... (object, that is)\par
@6,529,630us: [+0 T:0x40983490 S:0x40982d2c] OM - Memory_free> Enter(0x4b830, 0x0)\par
@6,529,940us: [+0 T:0x40983490 S:0x40982d2c] OM - Memory_free> return (0x1)\par
@6,530,130us: [+0 T:0x40983490 S:0x40982d64] OP - Processor_delete_d> return\par
@6,530,305us: [+0 T:0x40983490 S:0x40982d54] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x4b1d8]\par
@6,530,582us: [+0 T:0x4001e320 S:0xbea7b6dc] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x4b1d8] status[0]\par
@6,530,804us: [+0 T:0x4001e320 S:0xbea7b6fc] OP - doCmd> Exit (result=1)\par
@6,530,978us: [+1 T:0x4001e320 S:0xbea7b71c] OP - Processor_delete(0x4b808) freeing object ...\par
@6,531,203us: [+0 T:0x4001e320 S:0xbea7b6fc] OM - Memory_free> Enter(0x4b808, 0x24)\par
@6,531,384us: [+0 T:0x4001e320 S:0xbea7b6fc] OM - Memory_free> return (0x1)\par
@6,531,555us: [+0 T:0x4001e320 S:0xbea7b734] OP - Processor_delete> return.\par
@6,531,719us: [+0 T:0x4001e320 S:0xbea7b734] CE - rserverClose(0x4a654) done.\par
@6,531,886us: [+0 T:0x4001e320 S:0xbea7b734] OM - Memory_free> Enter(0x4b7d8, 0x2c)\par
@6,532,060us: [+0 T:0x4001e320 S:0xbea7b734] OM - Memory_free> return (0x1)\par
@6,532,809us: [+0 T:0x40983490 S:0x40982d64] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x4b1d8]\par
@6,533,859us: [+1 T:0x4001e320 S:0xbea7b754] ti.sdo.ce.examples.apps.image1_copy - app done.\par
@6,534,170us: [+0 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> enter\par
@6,534,362us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x1263c()...\par
@6,534,550us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x14368()...\par
@6,534,786us: [+0 T:0x4001e320 S:0xbea7bc4c] OM - Memory_free> Enter(0x4b430, 0x18)\par
@6,534,993us: [+0 T:0x4001e320 S:0xbea7bc4c] OM - Memory_free> return (0x1)\par
@6,535,204us: [+0 T:0x4001e320 S:0xbea7bc4c] OM - Memory_free> Enter(0x4b450, 0x18)\par
@6,535,398us: [+0 T:0x4001e320 S:0xbea7bc4c] OM - Memory_free> return (0x1)\par
@6,535,573us: [+0 T:0x4001e320 S:0xbea7bc4c] OM - Memory_free> Enter(0x4b470, 0x18)\par
@6,535,746us: [+0 T:0x4001e320 S:0xbea7bc4c] OM - Memory_free> return (0x1)\par
@6,535,919us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x1ef78()...\par
@6,536,096us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x17094()...\par
@6,536,280us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x17ecc()...\par
@6,536,459us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x1c73c()...\par
@6,536,670us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x1a404()...\par
@6,536,853us: [+0 T:0x4001e320 S:0xbea7bc4c] OP - doCmd> Enter (cmdId=3, proc=0x0)\par
@6,868,578us: [+0 T:0x4001e320 S:0xbea7bc3c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x4b1c0]\par
@6,868,815us: [+0 T:0x4001e320 S:0xbea7bc4c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x4b1c0]\par
@6,868,998us: [+0 T:0x4001e320 S:0xbea7bc2c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x4b1d8] timeout[0xffffffff]\par
@6,869,243us: [+0 T:0x40983490 S:0x40982d64] OP - getCmd_d> Enter (proc=0x40982dd8)\par
@6,869,465us: [+0 T:0x40983490 S:0x40982d44] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x4b1c0] timeout[0xffffffff]\par
@6,869,661us: [+0 T:0x40983490 S:0x40982d44] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x4b1c0] status[0]\par
@6,869,899us: [+0 T:0x40983490 S:0x40982d64] OP - getCmd_d> Exit (result=3)\par
@6,870,075us: [+0 T:0x40983490 S:0x40982d54] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x4b1d8]\par
@6,870,339us: [+0 T:0x4001e320 S:0xbea7bc2c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x4b1d8] status[0]\par
@6,870,550us: [+0 T:0x4001e320 S:0xbea7bc4c] OP - doCmd> Exit (result=1)\par
@6,870,718us: [+0 T:0x4001e320 S:0xbea7bc54] OT - Thread_delete> Enter (task=0x4b210)\par
@6,871,017us: [+4 T:0x4001e320 S:0xbea7bc54] OT - Thread_delete> pthread_cancel (0x0)\par
@6,872,043us: [+4 T:0x4001e320 S:0xbea7bc54] OT - Thread_delete> pthread_join (0x0)\par
@6,872,309us: [+0 T:0x4001e320 S:0xbea7bc34] OM - Memory_free> Enter(0x4b210, 0x64)\par
@6,872,555us: [+0 T:0x4001e320 S:0xbea7bc34] OM - Memory_free> return (0x1)\par
@6,872,748us: [+0 T:0x4001e320 S:0xbea7bc6c] OT - Thread_delete> Exit (task=0x4b210)\par
@6,872,929us: [+0 T:0x4001e320 S:0xbea7bc5c] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x4b1c0]\par
@6,873,165us: [+0 T:0x4001e320 S:0xbea7bc3c] OM - Memory_free> Enter(0x4b1c0, 0x14)\par
@6,873,363us: [+0 T:0x4001e320 S:0xbea7bc3c] OM - Memory_free> return (0x1)\par
@6,873,539us: [+0 T:0x4001e320 S:0xbea7bc6c] ti.sdo.ce.osal.Sem - Leaving Sem_delete>\par
@6,874,098us: [+0 T:0x4001e320 S:0xbea7bc5c] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x4b1d8]\par
@6,874,304us: [+0 T:0x4001e320 S:0xbea7bc3c] OM - Memory_free> Enter(0x4b1d8, 0x14)\par
@6,874,490us: [+0 T:0x4001e320 S:0xbea7bc3c] OM - Memory_free> return (0x1)\par
@6,874,662us: [+0 T:0x4001e320 S:0xbea7bc6c] ti.sdo.ce.osal.Sem - Leaving Sem_delete>\par
@6,874,824us: [+0 T:0x4001e320 S:0xbea7bc4c] OM - Memory_free> Enter(0x4b1f0, 0x18)\par
@6,874,998us: [+0 T:0x4001e320 S:0xbea7bc4c] OM - Memory_free> return (0x1)\par
@6,875,167us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x1ea88()...\par
@6,875,438us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x1c1f0()...\par
@6,875,635us: [+0 T:0x4001e320 S:0xbea7bc5c] OM - Memory_free> Enter(0x4b140, 0x18)\par
@6,875,818us: [+0 T:0x4001e320 S:0xbea7bc5c] OM - Memory_free> return (0x1)\par
@6,875,990us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x1d354()...\par
@6,876,222us: [+0 T:0x4001e320 S:0xbea7bc4c] OM - Memory_free> Enter(0x4b0f0, 0x18)\par
@6,876,418us: [+0 T:0x4001e320 S:0xbea7bc4c] OM - Memory_free> return (0x1)\par
@6,876,589us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x1f424()...\par
@6,876,816us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x1ffd8()...\par
@6,876,999us: [+2 T:0x4001e320 S:0xbea7bc7c] OG - Global_exit> calling function *0x1f384()...\par
root@da850-omapl138-evm:/# \par
DaVinci Codec Engine C6747 Memory_getBufferPhysicalAddress omap l138 CMEM Linking CE OMAP-L138 OMAPl138 l138 cmemk l13x CMEM Framework Components OMAPL138 SDK Download CCSv4 XDS100 v2 OMAPL138 OMAP-L138 L138 OMAP RTSC DSP/BIOS dsplink
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Robert Tivy
    Posted by Robert Tivy
    on Apr 20 2010 13:37 PM
    Verified Answer
    Verified by James McGloin
    Genius11090 points
    James,
    The error you are getting will happen when the IMGENC1_control() parameter "status" (of type IIMGENC1_Status) structure contains a data.bufSize element of 0.  Here is the code causing your error:
        if (status->data.buf != NULL) {
            pMsgStatus->data.bufSize = status->data.bufSize;
            /* save it for later */
            virtAddr = status->data.buf;
            pMsgStatus->data.buf = (XDAS_Int8 *)Memory_getBufferPhysicalAddress(status->data.buf,
                    status->data.bufSize, NULL);
            if (pMsgStatus->data.buf == NULL) {
                retVal = IIMGENC1_EFAIL;
                goto exit;
        else {
            /* Place null into the msg so the skel knows it's invalid */
            pMsgStatus->data.buf = NULL;
    In your pasted source code I can't see the definition of your imgStatus structure, or possible assignments to it.  From what you included I can see just this:
        imgStatus.size = sizeof(imgStatus);
        if (IMGENC1_control(enc, XDM_SETPARAMS, &dynParams, &imgStatus) == XDM_EFAIL) {
    But this is different than the size being complained about, which is ImgStatus.data.bufSize.  It seems that you're setting imgStatus.data.buf to a non-NULL value, else the 'if' statement above would prevent the Memory_getBufferPhysicalAddress() call.  So, make sure you're setting imgStatus.data.bufSize to a non-zero value somewhere before the IMGENC1_control() call.
    - Rob
    Report Abuse
    • Reply
  • James McGloin
    Posted by James McGloin
    on Apr 21 2010 06:34 AM
    Prodigy120 points
    Thanks Rob,
    I memset imgStatus to 0 and all worked
    James
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
