  • Answer Suggested
Non-IDR start stream
Guru 20680 points
When using the decoder with non-IDR starting frame I get the following
[m3video] Sequence called number 13
[m3video] 3860369:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] ALGPROCESS FAILED:STATUS
[m3video] outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x1421
If only I compile with DEC_LINK_SUPRESS_ERROR_AND_RESET then it handles the stream without failure.
Is it the correct way of solving this issue ? Should I use the  DEC_LINK_SUPRESS_ERROR_AND_RESET flag ?
Tahnk you,
Ran
  • Hi Ran,
               This is just a workaround & not a solution. Since it will ignore all the error's reported by Codec. I guess proper solution will be waiting till IDR frame and then feed it to the codec.
    Gajanan
    www.pathpartnertech.com
