• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Multimedia Software Codecs » Multimedia Software Codecs forum » Help ! About dm368 1080p at 30fps ??
Share
  • Forum
Options
  • Subscribe via RSS
This question is answered
Jing C
Posted by Jing C
on May 10 2010 07:52 AM
Intellectual560 points
I used h264 encoder ( version 2.0) in the newest DVSDK to run my application at 1080p, but I found it did not reach 30fps , only at 20 - 21fps. It's really exhausted me .  My  h264 encode configurations are below:
params.size                        = sizeof(IH264VENC_Params);
params.rateControlPreset  = IVIDEO_STORAGE;
params.encodingPreset     = XDM_USER_DEFINED;   //XDM_HIGH_SPEED;
params.maxWidth             = 1920;
params.maxHeight            = 1072;
params.maxFrameRate         = 30000;
params.maxBitRate           = 10*1000*1000;
params.reconChromaFormat       = XDM_YUV_420SP;
params.inputChromaFormat        = XDM_YUV_420SP;
params.dataEndianness                = XDM_BYTE;
params.inputContentType            = IVIDEO_PROGRESSIVE;
params.maxInterFrameInterval     = 1;
extH264Params.levelIdc = 31;
extH264Params.profileIdc = 100;
extH264Params.entropyMode = 1;
extH264Params.transform8x8FlagIntraFrame = 1;
extH264Params.seqScalingFlag = 1;
extH264Params.transform8x8FlagInterFrame = 0;
extH264Params.aspectRatioX = 1;
extH264Params.aspectRatioY = 1;
extH264Params.pixelRange = 1;
extH264Params.timeScale = 60;
extH264Params.numUnitsInTicks = 1;
extH264Params.enableVUIparams = 1;
//extH264Params.resetHDVICPeveryFrame = 1;
extH264Params.disableHDVICPeveryFrame = 0;
extH264Params.meAlgo = 0;
extH264Params.unrestrictedMV = 0;
extH264Params.encQuality = 0                          //2: for LITE
extH264Params.enableARM926Tcm = 0;
extH264Params.enableDDRbuff    = 0;
extH264Params.sliceMode            = 0;        //0: for LITE
extH264Params.outputDataMode  = 1;
extH264Params.sliceFormat         = 1;
dynamicParams.size                  = sizeof(IH264VENC_DynamicParams);
dynamicParams.inputHeight         = 1072;
dynamicParams.inputWidth          = 1920;
dynamicParams.targetBitRate        = 4*1000*1000;
dynamicParams.intraFrameInterval    = 30;
dynamicParams.generateHeader      = XDM_ENCODE_AU;
dynamicParams.captureWidth        = 1920
dynamicParams.forceFrame                = IVIDEO_NA_FRAME;
dynamicParams.interFrameInterval = XDM_DEFAULT;
dynamicParams.mbDataFlag           = XDM_DEFAULT;
dynamicParams.targetFrameRate   = 30000;
dynamicParams.refFrameRate      = 30000;
extH264DynParams.intraFrameQP       = 28;
extH264DynParams.interPFrameQP     = 28;
extH264DynParams.initQ                    = 28;
extH264DynParams.rcQMax               = 45;
extH264DynParams.rcQMin                = 0;
extH264DynParams.rcQMaxI              = 42;
extH264DynParams.rcQMinI               = 0;
extH264DynParams.airRate                 = 0;        //0: for LITE
extH264DynParams.lfDisableIdc          = 0;
extH264DynParams.maxDelay            = 2000;// 1000;
extH264DynParams.meMultiPart          = 0;
extH264DynParams.perceptualRC       = 0;        //0: for LITE
extH264DynParams.idrFrameInterval   = 30;
extH264DynParams.mvSADoutFlag     = 0;
extH264DynParams.enableROI            = 0;
extH264DynParams.intraSliceNum       = 0;
extH264DynParams.enableBufSEI       = 1;
extH264DynParams.enablePicTimSEI = 1;
extH264DynParams.rcAlgo                 = 1;
extH264DynParams.metaDataGenerateConsume = 0;
extH264DynParams.resetHDVICPeveryFrame = 1;
extH264DynParams.sliceSize               = 0;
extH264DynParams.intraThrQF          = 5;
Can anybody tell me what's wrong with my application ????
By the way, I found the user guide of the newest h264enc introduce a LITE mode. can  the encode  reach 1080@30fps only by setting LITE mode?
However, when I open the LITE mode by setting
params.encodingPreset           = XDM_HIGH_SPEED;
extH264Params.encQuality      = 2;
the H264 encoder creating will fail,  so I can not run my application in LITE mode. Is there something wrong in my setting?
Your kindly help is greatly appreciated. Thank u very much!
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Mahant S
    Posted by Mahant S
    on May 10 2010 23:56 PM
    Verified Answer
    Verified by Anshuman Saxena
    Prodigy630 points
    Hi Katee,
    I reviewed your encoder settings, it looks fine to me. You can achieve 1080p@30fps only in LITE mode.
    So is your create failing for LITE mode?
    Can you make the below changes and check:
    Also, can you look into the release notes and confirm which version of codec you are using? Can you also inform which board you are using for profiling (DM365 or DM368)?
    rgds, mahant
    Report Abuse
    • Reply
  • Jing C
    Posted by Jing C
    on May 11 2010 02:21 AM
    Hi,  Mahant , thank u  so much for your help.  I have already solved this problem . Like u said , 1080p@30fps only can be achieved in LITE mode ,  but i created fail at the beginning . Finally i found  that i forgot to add the EDMA3 configurations to my encode cfg file ,  when i add it to the cfg file ,the frame rate reach the 30fps.
    But now i have another problem, my output will displays the previous queued frame in place of current queued frame most of the time   (frame-skipping) .
    Can u help me to explain this problem or solve it?  Thanks !
    Report Abuse
    • Reply
  • Yashwant Dutt
    Posted by Yashwant Dutt
    on May 11 2010 03:56 AM
    Genius15110 points
    Katee,
    Since it is encoder, is this preview dsiplay you are reffering to ?  What is the resolution of preview ? Are you using DVSDK 3.1 for your experiments?
    regards
    Yashwant
    Report Abuse
    • Reply
  • Jing C
    Posted by Jing C
    on May 11 2010 05:38 AM
    Hi Yashwant ,
    I am really sorry that i didn't describe the problem clearly .
    I meant  that when i run 1080p@30fps  ,the output video will display  the previous queued frame in place of current queued frame most of the time  by setting continuous mode.
    If i set the single-shot mode, this problem will not exist.
    I think there is something wrong with the VPFE driver, but I am sure this problem is in my  video capture thread , not in preview display.
    regards
    Katee
    Report Abuse
    • Reply
  • xiang xu
    Posted by xiang xu
    on Jun 07 2010 06:52 AM
    Prodigy160 points
      can you tell me how to add the EDMA3 configurations to the encode cfg file?
    Report Abuse
    • Reply
  • xiang xu
    Posted by xiang xu
    on Jun 07 2010 20:19 PM
    Prodigy160 points
    Hi,Katee.
    I set dm368 as you said,however,the frame rate just reaches 21fps.It cannot be up to 30fps.I don't know how to add the EDMA3 configurations to the encode config file. Can ou give me a demo?
    Best regards!
    Report Abuse
    • Reply
  • Jing C
    Posted by Jing C
    on Jun 08 2010 04:42 AM
    Hi , xiang xu :
     I 'm sorry to reply u late .
    You can modify .cfg of your project like below:
    var EDMA3 = xdc.useModule('ti.sdo.fc.edma3.Settings');
    EDMA3.globalInit = true;
    EDMA3.maxQdmaChannels = [10,10,10,10];
    EDMA3.trace = false;
    EDMA3.debug = false;
    EDMA3.maxRequests = 128
    Then you can open the LITE mode in your H264 encoder, which can be up to 30fps....
    Report Abuse
    • Reply
  • xiang xu
    Posted by xiang xu
    on Jun 08 2010 21:34 PM
    Prodigy160 points
    Hi,Katee:
    Thanks for your reply and patience.
    I forgot to tell you that my H264 encoder version is V01_10_00_08 which has no member such as
    The H264 encoder creates failed When I set extH264Params.encQuality = 2 (params.encodingPreset     = XDM_USER_DEFINED).
    Where can I get the h264 encoder ( version 2.0) as he mentioned?
    Your prompt reply will be greatly appreciated.
    Best regards!
    Report Abuse
    • Reply
  • Jing C
    Posted by Jing C
    on Jun 08 2010 22:19 PM
    Hi ,xiang xu :
    30fps needs the version 2.0 or above . U can ask for the TI supportor for help (so did I ) , he/she can give u the latest version .
    Thanks.
    Report Abuse
    • Reply
  • xiang xu
    Posted by xiang xu
    on Jun 09 2010 00:59 AM
    Prodigy160 points
    thanks
    Report Abuse
    • Reply
  • Yashwant Dutt
    on Jun 09 2010 01:04 AM
    Genius15110 points
    Version 2.00.00 H.264 codec will be available on ti.com download site by 25th June.
    regards
    Yashwant
    Report Abuse
    • Reply
  • Jacob5406
    Posted by Jacob5406
    on Jun 22 2010 12:19 PM
    Prodigy390 points
    Yashwant Dutt
    regards
    Yashwant
    Please note that this version 2.00.00 of H.264 codec gets rid of the LITE mode. DM368 ARM frequency has been increased from 405MHz to 432MHz, which enables TI to support full Platinum codec at 1080p30 resolution on the DM368.
    ~Jacob
    Report Abuse
    • Reply
  • Billy Qin
    Posted by Billy Qin
    on Jun 25 2010 21:22 PM
    Prodigy25 points
    Hi,Yashwant,
    where can i get the Version 2.00.00 H.264 codec on the DM368?
    billy
    Report Abuse
    • Reply
  • Yashwant Dutt
    on Jun 28 2010 00:49 AM
    Genius15110 points
    Hi Billy,
    There is  a delay of 1 week in releasing the codecs. It will be available in 1st week of July. I will update the post, the moment it is done.
    regards
    Yashwant
    Report Abuse
    • Reply
  • Billy Qin
    Posted by Billy Qin
    on Jun 28 2010 00:54 AM
    Prodigy25 points
    Thanks a lot! It's very important for us.
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
