I have a very simple DSP_BIOS v5 works with IRAM under debug mode. It's just blinking LED
But it stops working after combined with ARM binary to run in standalone mode, ie burn combined binary into flash and boot out of flash
I recompile DSP_BIOS to use all DDR, it works fine.
ARM code does not use any IRAM
DSP_BIOS does not use L3_RAM for the sake of Boot_Loader as required
I'm using bootLoader from StarterWare with ARM+DSP binary genrated by the tool Out2RpRc, say ARM_DSP.bin
I burned ARM_DSP.bin into flash, run bootLoader in debug mode, I have both ARM & DSP apps up and run, ARM does blinking one LED, and DSP does the 2nd LED
However, with exactly the same bootLoader burned into flash, ONLY ARM works with its LED blinking, but NOT DSP_LED, even I've seen boot message that DSP app starts running too!
My question is how to make DSP_BIOS work with IRAM in stand-alone mode ?
~Duy-Ky
