• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » StarterWare » StarterWare forum » Automatic SPI Chip select generation
Share
StarterWare
  • Forum
Options
  • Subscribe via RSS
This question is not answered
Lars L.
Posted by Lars L.
on Apr 05 2012 08:19 AM
Intellectual305 points
Hey guys
In the SPI examples for starterware there is a manual assert deassert of the SPI chip select. However, from the manual I've come to understand that it is possible to make this generation automatic, so that I don't have to care about it, however I can not find anywhere any kind of information that is straight forward on what has to be done.
"The chip select timing control is only available in master mode with automatic chip select generation (FORCE bit field is cleared to 0)" (under 24.3.3.8 Chip-Select Timing Control) is basically everything I can find on this subject. Does anybody know how to do this?
Kind regards
Lars
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Madhvapathi Sriram
    Posted by Madhvapathi Sriram
    on Apr 06 2012 12:38 PM
    Intellectual465 points
    Lars,
    The assert and deassert APIs are used to keep the SPI chip selects (or the SPIEN as called) activated for the entire transfer, across multiple SPI words of the transfer. This kind of an operation is required with read/write from/to flash devices etc, where CS/SPIEN deassertion could mean change/end of commands.
    Since, the SPI examples of the StarterWare package deal with the flash this feature is used.
    If you don't require such an operation (of SPIEN/CS being active for the entire transfer), just don't use the assert/deassert APIs. The SPIEN/CS should toggle the moment SPI data registers are written to and depending on the timing configuration in the registers programmed.
    Hope this helps.
    Madhvapathi Sriram
    Thanks and regards,
    Madhvapathi Sriram
    Report Abuse
    • Reply
  • Lars L.
    Posted by Lars L.
    on Apr 10 2012 03:02 AM
    Hi Madhvapathi,
    Thanks for your answer! Yes, that is the way I would like it to work, however it is not working. My test transmission basically looks like this (I would like to transmit AA):
      /* Enable the McSPI channel for communication.*/
        McSPIChannelEnable(SOC_SPI_1_REGS, chNum1);
        McSPIIntStatusClear(SOC_SPI_0_REGS, MCSPI_INT_TX_EMPTY(chNum0));
        McSPITransmitData(SOC_SPI_1_REGS, 0xFFFFFFAA, chNum1);
        /* Disable the McSPI channel.*/
        McSPIChannelDisable(SOC_SPI_1_REGS, chNum1);
    When this is done no transmission is seen. However, if I run the assert-command before, and the deassert-command after, the transmission can be seen on my logic analyzer. So basically I am left to manually asserting and asserting the CS. There seems to be something I am missing, does anybody have any clues?
    Kind regards
    Lars
    Report Abuse
    • Reply
    on Apr 11 2012 12:57 PM
    Hi Lars,
    I think there is something with this..
    Read this from the processor guide..
    " Transfer Format With PHA = 0'
    In the transfer format with PHA = 0, SPIEN is activated a half cycle of SPICLK ahead of the first SPICLK edge. In both master and slave modes, McSPI drives the data lines at the time of SPIEN is asserted" .........In master mode, the SPIEN line must be negated and reasserted between each successive SPI word. This is because the slave select pin freezes the data in its shift register and does not allow it to be altered if PHA bit equals 0.
    "Transfer Format With PHA = 1"
    In the transfer format with PHA = 1, SPIEN is activated a delay (tLead) ahead of the first SPICLK edge. In both master and slave modes, McSPI drives the data lines on the first SPICLK edge.
    So you may have to chose MCSPI_CLK_MODE_1 in McSPIClkConfig() as against what is done in the application.
    Hope this helps.
    On another tangent, there is a mistake in your code snippet. You are using SPI_0_REGS for interrupt clearing
    Madhvapathi Sriram
    Thanks and regards,
    Madhvapathi Sriram
    Report Abuse
    • Reply
  • Lars L.
    Posted by Lars L.
    on Apr 12 2012 02:04 AM
    Hi Madhvapathi,
    Unfortunately it seems like that did not help either =/ Fixing the code snippet gave no result either, but thanks :)
    The setup codes for the interface that I'm currently use look like this:
        /* Reset the McSPI instance.*/
        McSPIReset(baseAdd);
        /* Set polarity of SPIEN to low.*/
        McSPICSPolarityConfig(baseAdd, MCSPI_CS_POL_LOW, channel);
        /* Enable chip select pin.*/
        McSPICSEnable(baseAdd);
        /* Enable master mode of operation.*/
        McSPIMasterModeEnable(baseAdd);
        /* Perform the necessary configuration for master mode.*/
        McSPIMasterModeConfig(baseAdd, MCSPI_SINGLE_CH,
                              MCSPI_TX_RX_MODE, MCSPI_DATA_LINE_COMM_MODE_1,
                              channel);
        /* Configure the McSPI bus clock depending on clock mode. */
        McSPIClkConfig(baseAdd, MCSPI_IN_CLK, MCSPI_OUT_FREQ, channel,
                       MCSPI_CLK_MODE_1);
        /* Configure the word length.*/
        McSPIWordLengthSet(baseAdd, MCSPI_WORD_LENGTH(8), channel);
        /* Enable the transmitter FIFO of McSPI peripheral.*/
        McSPITxFIFOConfig(baseAdd, MCSPI_TX_FIFO_ENABLE, channel);
        /* Enable the receiver FIFO of McSPI peripheral.*/
        McSPIRxFIFOConfig(baseAdd, MCSPI_RX_FIFO_ENABLE, channel);
    The functions behind these calls are the same as the example projects. There must be something we're missing here, thanks for the help!
    Kind regards
    Lars
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
