• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » StarterWare » StarterWare forum » ECAP1 capture for C6748 setup
Share
StarterWare
  • Forum
Options
  • Subscribe via RSS
This question is answered
David Luca
Posted by David Luca
on Jun 07 2012 03:41 AM
Expert1990 points
I've been trying to setup ECAP1 in delta-mode to capture a square signal, but the capture events are not changing, I only read 0, could you have a look at the code below please, maybe you can spot something?
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
PSCModuleControl(SOC_PSC_1_REGS, HW_PSC_ECAP0_1_2, PSC_POWERDOMAIN_ALWAYS_ON,  PSC_MDCTL_NEXT_ENABLE);
//Select Pin E4 ECAP1
/* ECAP1 */
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(1)) =  (HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(1)) & (~(SYSCFG_PINMUX1_PINMUX1_31_28))) | (SYSCFG_PINMUX1_PINMUX1_31_28_ECAP1 << SYSCFG_PINMUX1_PINMUX1_31_28_SHIFT);
ECAPCaptureLoadingEnable(SOC_ECAP_1_REGS);
ECAPOperatingModeSelect(SOC_ECAP_1_REGS, ECAP_CAPTURE_MODE);
ECAPPrescaleConfig(SOC_ECAP_1_REGS, 0);//no prescale
ECAPCapeEvtPolarityConfig(SOC_ECAP_1_REGS, 1, 1, 1, 1);//rising, rising, rising, rising edges so that after 3 rising edges I have full rotation
ECAPCaptureEvtCntrRstConfig(SOC_ECAP_1_REGS, 1, 1, 1, 1 );//reset counter each time rising edge is found
ECAPContinousModeConfig(SOC_ECAP_1_REGS);   //set ecap in continuous mode to measure speed continuously
ECAPIntDisable(SOC_ECAP_1_REGS, ECAP_CEVT1_INT | ECAP_CEVT2_INT | ECAP_CEVT3_INT | ECAP_CEVT4_INT | ECAP_CNTOVF_INT | ECAP_PRDEQ_INT | ECAP_CMPEQ_INT);
ECAPSyncInOutSelect(SOC_ECAP_1_REGS, ECAP_SYNC_IN_DISABLE, ECAP_SYNC_OUT_DISABLE);
ECAPCounterConfig(SOC_ECAP_1_REGS, 0);//capture time base   =>reset ecap
ECAPCounterControl(SOC_ECAP_1_REGS, ECAP_COUNTER_FREE_RUNNING);//timer base counter to increase
Thank you in advance,
David.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • David Luca
    on Jun 07 2012 05:07 AM
    Verified Answer
    Verified by David Luca
    Expert1990 points
    I think I found the problems:
    In ecap.h the definitions for the ECAP_CAPTURE_MODE parameter for ECAPOperatingModeSelect function should be 0 instead of 1
    #define ECAP_CAPTURE_MODE 0 //check page spruh79a.pdf, bit 9
    #define ECAP_APWM_MODE 1  ...correction, it was ok, ECAPOperatingModeSelect is a bit confusing, set parameter to 1 to clear bit.
    Also, for ECAPSyncInOutSelect function the definitions are wrong, it overwrites the bit 9 setting it back to pwm mode
    #define ECAP_SYNC_IN (00 << ECAP_ECCTL2_SYNCO_SEL_SHIFT)
    #define ECAP_PRD_EQ (01 << ECAP_ECCTL2_SYNCO_SEL_SHIFT)
    #define ECAP_SYNC_OUT_DISABLE (10 << ECAP_ECCTL2_SYNCO_SEL_SHIFT)  //this should be 2 <<
    Hope someone can confirm this.
    David.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
