I am currently working on a video processing project with omapl138 evm board and using sample composite video test code which i found at logicpd website. I couldn't figure out how can i process video by vpif module. I included the file "pspdrivers_01_30_01\packages\ti\pspiom\vpif\src\vpif.c", but i received:
Severity and Description Path Resource Location Creation Time Iderrors encountered during linking; "DSPEVMCompositeVideoTest.out" not built DSP EVM Composite Video Test line 0 1343898819580 805unresolved symbol _BCACHE_wbInv, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 780unresolved symbol _C64_enableIER, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 781unresolved symbol _CLK_getltime, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 782unresolved symbol _ECM_ATTRS, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 783unresolved symbol _ECM_disableEvent, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 784unresolved symbol _ECM_dispatchPlug, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 785unresolved symbol _ECM_enableEvent, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 786unresolved symbol _MEM_free, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 787unresolved symbol _MEM_valloc, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 788unresolved symbol _PWRM_registerNotify, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 789unresolved symbol _PWRM_releaseDependency, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 790unresolved symbol _PWRM_setDependency, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 791unresolved symbol _PWRM_unregisterNotify, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 792unresolved symbol _QUE_get, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 793unresolved symbol _QUE_put, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 794unresolved symbol _SEM_create, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 795unresolved symbol _SEM_delete, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819564 796unresolved symbol _SEM_pend, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819580 797unresolved symbol _SEM_post, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819580 798unresolved symbol _SWI_ATTRS, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819580 799unresolved symbol _SWI_create, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819580 800unresolved symbol _SWI_delete, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819580 801unresolved symbol _SWI_post, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819580 802unresolved symbol _TSK_create, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819580 803unresolved symbol _TSK_delete, first referenced in ./Vpif.obj DSP EVM Composite Video Test line 0 1343898819580 804incompatible redefinition of macro "BIOS_PWRM_ENABLE" (declared at line 63 of "../Vpif.c") F:/Texas Instruments/pspdrivers_01_30_01/packages/ti/pspiom/vpif/src VpifLocal.h line 49 1343898819564 779incompatible redefinition of macro "CHIP_OMAPL138" (declared at line 62 of "../Vpif.c") F:/Texas Instruments/pspdrivers_01_30_01/packages/ti/pspiom/vpif/src VpifLocal.h line 48 1343898819564 778.
Can someone please help me how can i capture top and bottom frame using vpif_isr?
Thanks.
serim keskinI couldn't figure out how can i process video by vpif module. I included the file "pspdrivers_01_30_01\packages\ti\pspiom\vpif\src\vpif.c
You should import the project from within CCS (v3 I guess). You will need DSP/BIOS, EDMA packages for using PSP driver package. Please refer to the accompanying user guide.
Hope this helps.
Thanks and regards,
Madhvapathi Sriram
