Dear Starterware team, Could you able to provide UART1/UART2/UART3/UART4/UART5 , example code please?
I am working on AM3358 beaglebone black with starterware, My uart0 is working fine and looking for a coed to build UART4
in fact, to use the others UARTs you need to activate the internal clocks (L3S and L4). It took me a few days to realise they are in different power domains (wakeup and Peripheral).
There I took the DMTimer2ModuleClkConfig() and the UARTModuleClkConfig() from the libs (because timer2 are in the same power domain the UART1) and made this UART1clock config.
It worked for UART1, but not for UART5. There is this PIN MUX MODES described in the BeagleBone Black manual that I don´t understand yet.
sorry for my english, Maybe someone on the team can help.
HI carlos, Thanks for the reply. I enable the L3SClk and L4clk but still not working, I look at the UART4 register,
THR is not changing at all
Hi Carlos, I tried activating L3S and L4, with no success.
So I turned on every fracking clock and still no-go.
AND I am seeing interface and functional clock activity on UART1 also!
Some gremlin in that chip really does not like me.
So can you please post your code UART1clockconfig?
thanks..................dd
this code I made based on Starterware_uart0. you can change each "1" for the desired uart. I've tested all of them. Sorry, it´s been a long time i made this. The code is supplied "as is".
static void UART1ModuleClkConfig(void)
HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) =
CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) &
CM_PER_L3S_CLKSTCTRL_CLKTRCTRL) != CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) =
CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) &
CM_PER_L3_CLKSTCTRL_CLKTRCTRL) != CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) =
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) &
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE) !=
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE);
HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) =
CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) &
CM_PER_L3_CLKCTRL_MODULEMODE) != CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE);
HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) =
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while((HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) &
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL) !=
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) =
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) &
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) =
CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) &
CM_PER_L4LS_CLKCTRL_MODULEMODE) != CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
HWREG(SOC_CM_PER_REGS + CM_PER_UART1_CLKCTRL) |= CM_PER_UART1_CLKCTRL_MODULEMODE_ENABLE;
while((HWREG(SOC_CM_PER_REGS + CM_PER_UART1_CLKCTRL) &
CM_PER_UART1_CLKCTRL_MODULEMODE) != CM_PER_UART1_CLKCTRL_MODULEMODE_ENABLE);
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) &
CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) &
CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) &
(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK |
CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK)));
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) &
(CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_UART_GFCLK)));
/* Waiting for MODULEMODE field to reflect the written value. */
while(CM_PER_UART1_CLKCTRL_MODULEMODE_ENABLE !=
CM_PER_UART1_CLKCTRL_MODULEMODE));
** Waiting for IDLEST field in CM_WKUP_UART0_CLKCTRL register to attain
** desired value.
while((CM_PER_UART1_CLKCTRL_IDLEST_FUNC <<
CM_PER_UART1_CLKCTRL_IDLEST_SHIFT) !=
CM_PER_UART1_CLKCTRL_IDLEST));
/* RXD */
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_UART_RXD(1)) =
(CONTROL_CONF_UART1_RXD_CONF_UART1_RXD_PUTYPESEL |
CONTROL_CONF_UART1_RXD_CONF_UART1_RXD_RXACTIVE);
/* TXD */
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_UART_TXD(1)) =
CONTROL_CONF_UART1_TXD_CONF_UART1_TXD_PUTYPESEL;
void Config_Uart1(void)
unsigned int divisorValue = 0;
/* Configuring the system clocks for UART0 instance. */
UART1ModuleClkConfig();
/* Performing a module reset. */
UARTModuleReset(SOC_UART_1_REGS);
/* Computing the Divisor Value. */
divisorValue = UARTDivisorValCompute(UART_MODULE_INPUT_CLK,
BAUD_RATE_115200,
UART16x_OPER_MODE,
UART_MIR_OVERSAMPLING_RATE_42);
/* Programming the Divisor Latches. */
UARTDivisorLatchWrite(SOC_UART_1_REGS, divisorValue);
/* Switching to Configuration Mode B. */
UARTRegConfigModeEnable(SOC_UART_1_REGS, UART_REG_CONFIG_MODE_B);
/* Programming the Line Characteristics. */
UARTLineCharacConfig(SOC_UART_1_REGS,
(UART_FRAME_WORD_LENGTH_8 | UART_FRAME_NUM_STB_1),
UART_PARITY_NONE);
/* Disabling write access to Divisor Latches. */
UARTDivisorLatchDisable(SOC_UART_1_REGS);
/* Disabling Break Control. */
UARTBreakCtl(SOC_UART_1_REGS, UART_BREAK_COND_DISABLE);
/* Switching to UART16x operating mode. */
UARTOperatingModeSelect(SOC_UART_1_REGS, UART16x_OPER_MODE);
/* Enabling the specified UART interrupts. */
UARTIntEnable(SOC_UART_1_REGS, (UART_INT_LINE_STAT | UART_INT_RHR_CTI) );
All,
Please take a look at the attached doc for a procedure on modifying the UART0 example in the ProcessorSDK package to work with UART1. This is for BeagleBone BLack (BBB). Hoping to get this doc into a wiki.
There might be some redundant steps in this draft, so please provide any feedback on any steps that don't make sense.
Steps start with the PinMux tool changes ==>Testing UART1 on the BBB.
Hi Chris. Thanks. I'll get around to fixing this problem eventually.
Making good progress on MMC right now, plus I gotta job.
later..............dd
