Hello TI,
I am tring to use LWIP with 3rd party RTOS. SO I found out the startware lwip example is a very good startpoint.
But I found out a problem in the example code that the package receive process is all done in the receive interrupt function. So if a lot of packages come in a very short interval, The receive process will cost a lot of time. So that other interrupt may be skipped. Is this real?
Can I just mask the CPDMA interrupt when receive package then let another process to process.When the process thread finish processing then unmask the CPDMA interrupt. Is it way OK?
Or any other better suggestion is welcome?
Thank you very much!
