Using ccs ,i just use spi0 only and init two pins in sip0(CLK and DAT1 for receive),and enable the rx full ISR,when i write 16 bit data to Tx reg,oscilloscope the CLK output and received data in DAT1,but use the CCS to monitor the Rx reg value,it is the same as date write in Tx reg for the first time. and when Rx_full set ,the code doest't jump into the ISR,is there something i missed? the modified place was colour bule and coda as follows,
SPI0Pinmux()
//SPI0_CLK : A17
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_SPI0_SCLK) = 0x30;
//SPI0_D1: B16
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_SPI0_D1) = 0x30;
static void SPI0AintcConfigure(void)
/* Register McSPIIsr interrupt handler */
IntRegister(SYS_INT_SPI0INT, McSPIIsr);
/* Set Interrupt Priority */
IntPrioritySet(SYS_INT_SPI0INT, 0, AINTC_HOSTINT_ROUTE_IRQ);
/* Enable system interrupt in AINTC */
IntSystemEnable(SYS_INT_SPI0INT);
static void McSPISetUp(void)
{ /* Reset the McSPI instance.*/
McSPIReset(SOC_SPI_0_REGS);//P4032
/* Enable chip select pin.*/
//McSPICSEnable(SOC_SPI_0_REGS);//mcspi_MODULCTR bit1 PIN34=0 //P4044
McSPICSDisable(SOC_SPI_0_REGS);//cs not used
/* Enable master mode of operation.*/
McSPIMasterModeEnable(SOC_SPI_0_REGS);
/* Perform the necessary configuration for master mode.*/
McSPIMasterModeConfig(SOC_SPI_0_REGS, MCSPI_SINGLE_CH, MCSPI_TX_RX_MODE, MCSPI_DATA_LINE_COMM_MODE_5, 0);
/* Configure the McSPI bus clock depending on clock mode. */ McSPIClkConfig(SOC_SPI_0_REGS, MCSPI_IN_CLK, MCSPI_OUT_FREQ, 0, MCSPI_CLK_MODE_2);
/* Configure the word length.*/
McSPIWordLengthSet(SOC_SPI_0_REGS, MCSPI_WORD_LENGTH(16), 0);
/* Set polarity of SPIEN to low.*/
McSPICSPolarityConfig(SOC_SPI_0_REGS, MCSPI_CS_POL_LOW, 0);
/* Enable the transmitter FIFO of McSPI peripheral.*/
McSPITxFIFOConfig(SOC_SPI_0_REGS, MCSPI_TX_FIFO_ENABLE, 0);
/* Enable the receiver FIFO of McSPI peripheral.*/
McSPIRxFIFOConfig(SOC_SPI_0_REGS, MCSPI_RX_FIFO_ENABLE, 0);
//add
HWREG(SOC_SPI_0_REGS + 0x17C) |= 0x101;// when Rx has two byte,then occur Rx ISR
// SPIEN line is forced to low state.
McSPICSAssert(SOC_SPI_0_REGS, 0);//p4046 bit20
McSPIIntEnable(SOC_SPI_0_REGS, MCSPI_INT_RX0_OVERFLOW | MCSPI_INT_RX_FULL(0));//P4040
McSPIChannelEnable(SOC_SPI_0_REGS, 0);//p4051 channel0 enable
void SPI0_Init(void)
McSPI0ClkConfig();
SPI0Pinmux();
SPI0AintcConfigure();
McSPISetUp();
int main(void)
IntAINTCInit();
IntMasterIRQEnable();
SPI0_Init();
while(1)
McSPITransmitData(SOC_SPI_0_REGS,0x5555, 0);
McSPITransmitData(SOC_SPI_0_REGS,0xAAAA, 0);
Debug steps:
set breakpoint at send data 0x5555 and 0xAAAA.
1.send 0x5555, can see Tx and Rx reg is 0x5555,and Rxfull set
2.send 0xAAAA, just Tx reg value change to 0xAAAA, others no change at all.
3.repeat step1&2 about 8 times, i think all data can send success cause the output clk is ok . at the ninth time,the RXFFF was set and no clk output again.
i wonder how to triger the Rx ISR and why the Rx reg value =0x5555 at the first send ?
should anyone can give me some suggestion?
thanks for ahead!
