I am using the starter ware for AM335x. I need to bring up UART interfaces UART1 , UART2 , UART3 , UART4 and UART 5. I started with UART1. I did the necessary initializations w.r.t to UART1. But I am unable to see anything on UART1. I am trying to modify the uartEcho.c
Here are the initializations I had done
/*clk config */
UART1ModuleClkConfig();
/* Performing the Pin Multiplexing for UART0 instance. */
UARTPinMuxSetup(1);
/* Performing a module reset. */
UARTModuleReset(SOC_UART_1_REGS);
/* Performing FIFO configurations. */
Uart1FIFOConfigure();
/* Performing Baud Rate settings. */
Uart1BaudRateSet();
/* Switching to Configuration Mode B. */
UARTRegConfigModeEnable(SOC_UART_1_REGS, UART_REG_CONFIG_MODE_B);
/* Programming the Line Characteristics. */
UARTLineCharacConfig(SOC_UART_1_REGS,
(UART_FRAME_WORD_LENGTH_8 | UART_FRAME_NUM_STB_1),
UART_PARITY_NONE);
UARTDivisorLatchDisable(SOC_UART_1_REGS);
/* Disabling Break Control. */
UARTBreakCtl(SOC_UART_1_REGS, UART_BREAK_COND_DISABLE); //configured //
/* Switching to UART16x operating mode. */
UARTOperatingModeSelect(SOC_UART_1_REGS, UART16x_OPER_MODE);
/* Performing Interrupt configurations. */
Uart1InterruptEnable();
The UART1ModuleClkConfig() function has the below mentioned configurations
void UART1ModuleClkConfig(void)
HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) =
CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) &
CM_PER_L3S_CLKSTCTRL_CLKTRCTRL) != CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) =
CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) &
CM_PER_L3_CLKSTCTRL_CLKTRCTRL) != CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) =
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) &
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE) !=
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE);
HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) =
CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) &
CM_PER_L3_CLKCTRL_MODULEMODE) != CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE);
HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) =
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while((HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) &
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL) !=
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) =
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) &
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) =
CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) &
CM_PER_L4LS_CLKCTRL_MODULEMODE) != CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) &
CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) &
CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) &
(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK |
CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK)));
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) &
(CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_UART_GFCLK)));
HWREG(SOC_CM_PER_REGS + CM_PER_UART1_CLKCTRL) &= ~CM_PER_UART1_CLKCTRL_MODULEMODE;
HWREG(SOC_CM_PER_REGS + CM_PER_UART1_CLKCTRL) |=
CM_PER_UART1_CLKCTRL_MODULEMODE_ENABLE;
while((HWREG(SOC_CM_PER_REGS + CM_PER_UART1_CLKCTRL) &
CM_PER_UART1_CLKCTRL_MODULEMODE) != CM_PER_UART1_CLKCTRL_MODULEMODE_ENABLE);
Please let me know whether the clock configurations are correct or not.
Also Please provide me the steps to configure all the UART interfaces
Thanks and regards
Ajit S J
