Team,
I am trying to build the HSR/PRP examples (C:\ti\sysbios_ind_sdk_2.1.1.2\sdk\examples\hsr_prp_app) that are documented at:
It seems that importing the project from CCS does not work well. The C src code is not copied to the workspace. Same problem for the hsr_prp_app/snmp associated project. Most of the PATH are wrongly referenced.
Other example like the ethercat example import correctly and you can build it out of the box. But not the HSR/PRP projects.
Can you confirm that there is an issue with the import?
I have used CCS 6.0.1.000040, ndk_2_24_03_35, xdctools_3_30_03_47_core, sysbios_ind_sdk_2.1.1.2.
Thansk.
Anthony
