I'm trying to send an image to LCD_DATA pin ... not as easy as I though ....
I've used the tools bmptoraster to convert a 16 bit image to a header file ....
Looks like that the tools can't convert a 16 bit image, it has to be a 24 bit image <image format required 565/24>
After that I tried to take code from different place and I got :
/** * \brief This function will configure the required clocks for LCDC instance. * * \return None. * */ void LCDModuleClkConfig(void) { HWREG(SOC_PRCM_REGS + CM_PER_L3S_CLKSTCTRL) |= CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP; while((HWREG(SOC_PRCM_REGS + CM_PER_L3S_CLKSTCTRL) & CM_PER_L3S_CLKSTCTRL_CLKTRCTRL) != CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP); HWREG(SOC_PRCM_REGS + CM_PER_L3_CLKSTCTRL) |= CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP; while((HWREG(SOC_PRCM_REGS + CM_PER_L3_CLKSTCTRL) & CM_PER_L3_CLKSTCTRL_CLKTRCTRL) != CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP); HWREG(SOC_PRCM_REGS + CM_PER_L3_INSTR_CLKCTRL) |= CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE; while((HWREG(SOC_PRCM_REGS + CM_PER_L3_INSTR_CLKCTRL) & CM_PER_L3_INSTR_CLKCTRL_MODULEMODE) != CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE); HWREG(SOC_PRCM_REGS + CM_PER_L3_CLKCTRL) |= CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE; while((HWREG(SOC_PRCM_REGS + CM_PER_L3_CLKCTRL) & CM_PER_L3_CLKCTRL_MODULEMODE) != CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE); HWREG(SOC_PRCM_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) |= CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP; while((HWREG(SOC_PRCM_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) & CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL) != CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP); HWREG(SOC_PRCM_REGS + CM_PER_L4LS_CLKSTCTRL) |= CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP; while((HWREG(SOC_PRCM_REGS + CM_PER_L4LS_CLKSTCTRL) & CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) != CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP); HWREG(SOC_PRCM_REGS + CM_PER_L4LS_CLKCTRL) |= CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE; while((HWREG(SOC_PRCM_REGS + CM_PER_L4LS_CLKCTRL) & CM_PER_L4LS_CLKCTRL_MODULEMODE) != CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE); /* lcd pixel clock is derived from peripheral pll */ HWREG(SOC_CM_DPLL_REGS + CM_DPLL_CLKSEL_LCDC_PIXEL_CLK) = CM_DPLL_CLKSEL_LCDC_PIXEL_CLK_CLKSEL_SEL3; HWREG(SOC_PRCM_REGS + CM_PER_LCDC_CLKCTRL) |= CM_PER_LCDC_CLKCTRL_MODULEMODE_ENABLE; while((HWREG(SOC_PRCM_REGS + CM_PER_LCDC_CLKCTRL) & CM_PER_LCDC_CLKCTRL_MODULEMODE) != CM_PER_LCDC_CLKCTRL_MODULEMODE_ENABLE); while(!(HWREG(SOC_PRCM_REGS + CM_PER_L3S_CLKSTCTRL) & CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK)); while(!(HWREG(SOC_PRCM_REGS + CM_PER_L3_CLKSTCTRL) & CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK)); while(!(HWREG(SOC_PRCM_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) & (CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK | CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK))); while(!(HWREG(SOC_PRCM_REGS + CM_PER_L4LS_CLKSTCTRL) & (CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK | CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_LCDC_GCLK))); } void LCDPinMuxSetup(){ // gpios : GpioPinMuxSetup(0x9b0, CONTROL_CONF_MUXMODE(3)); /* mode 3 CLKOUT1 24MHZ enabled with the sysboot[5]*/ // HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(0)) = (0 << CONTROL_CONF_LCD_DATA0_CONF_LCD_DATA0_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA0_CONF_LCD_DATA0_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA0_CONF_LCD_DATA0_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA0_CONF_LCD_DATA0_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA0_CONF_LCD_DATA0_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(1)) = (0 << CONTROL_CONF_LCD_DATA1_CONF_LCD_DATA1_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA1_CONF_LCD_DATA1_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA1_CONF_LCD_DATA1_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA1_CONF_LCD_DATA1_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA1_CONF_LCD_DATA1_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(2)) = (0 << CONTROL_CONF_LCD_DATA2_CONF_LCD_DATA2_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA2_CONF_LCD_DATA2_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA2_CONF_LCD_DATA2_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA2_CONF_LCD_DATA2_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA2_CONF_LCD_DATA2_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(3)) = (0 << CONTROL_CONF_LCD_DATA3_CONF_LCD_DATA3_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA3_CONF_LCD_DATA3_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA3_CONF_LCD_DATA3_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA3_CONF_LCD_DATA3_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA3_CONF_LCD_DATA3_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(4)) = (0 << CONTROL_CONF_LCD_DATA4_CONF_LCD_DATA4_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA4_CONF_LCD_DATA4_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA4_CONF_LCD_DATA4_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA4_CONF_LCD_DATA4_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA4_CONF_LCD_DATA4_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(5)) = (0 << CONTROL_CONF_LCD_DATA5_CONF_LCD_DATA5_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA5_CONF_LCD_DATA5_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA5_CONF_LCD_DATA5_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA5_CONF_LCD_DATA5_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA5_CONF_LCD_DATA5_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(6)) = (0 << CONTROL_CONF_LCD_DATA6_CONF_LCD_DATA6_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA6_CONF_LCD_DATA6_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA6_CONF_LCD_DATA6_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA6_CONF_LCD_DATA6_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA6_CONF_LCD_DATA6_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(7)) = (0 << CONTROL_CONF_LCD_DATA7_CONF_LCD_DATA7_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA7_CONF_LCD_DATA7_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA7_CONF_LCD_DATA7_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA7_CONF_LCD_DATA7_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA7_CONF_LCD_DATA7_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(8)) = (0 << CONTROL_CONF_LCD_DATA8_CONF_LCD_DATA8_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA8_CONF_LCD_DATA8_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA8_CONF_LCD_DATA8_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA8_CONF_LCD_DATA8_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA8_CONF_LCD_DATA8_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(9)) = (0 << CONTROL_CONF_LCD_DATA9_CONF_LCD_DATA9_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA9_CONF_LCD_DATA9_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA9_CONF_LCD_DATA9_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA9_CONF_LCD_DATA9_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA9_CONF_LCD_DATA9_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(10)) = (0 << CONTROL_CONF_LCD_DATA10_CONF_LCD_DATA10_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA10_CONF_LCD_DATA10_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA10_CONF_LCD_DATA10_PUTYPESEL_SHIFT)| (1 << CONTROL_CONF_LCD_DATA10_CONF_LCD_DATA10_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA10_CONF_LCD_DATA10_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(11)) = (0 << CONTROL_CONF_LCD_DATA11_CONF_LCD_DATA11_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA11_CONF_LCD_DATA11_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA11_CONF_LCD_DATA11_PUTYPESEL_SHIFT) | (1 << CONTROL_CONF_LCD_DATA11_CONF_LCD_DATA11_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA11_CONF_LCD_DATA11_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(12)) = (0 << CONTROL_CONF_LCD_DATA12_CONF_LCD_DATA12_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA12_CONF_LCD_DATA12_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA12_CONF_LCD_DATA12_PUTYPESEL_SHIFT) | (1 << CONTROL_CONF_LCD_DATA12_CONF_LCD_DATA12_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA12_CONF_LCD_DATA12_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(13)) = (0 << CONTROL_CONF_LCD_DATA13_CONF_LCD_DATA13_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA13_CONF_LCD_DATA13_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA13_CONF_LCD_DATA13_PUTYPESEL_SHIFT) | (1 << CONTROL_CONF_LCD_DATA13_CONF_LCD_DATA13_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA13_CONF_LCD_DATA13_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(14)) = (0 << CONTROL_CONF_LCD_DATA14_CONF_LCD_DATA14_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA14_CONF_LCD_DATA14_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA14_CONF_LCD_DATA14_PUTYPESEL_SHIFT) | (1 << CONTROL_CONF_LCD_DATA14_CONF_LCD_DATA14_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA14_CONF_LCD_DATA14_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_DATA(15)) = (0 << CONTROL_CONF_LCD_DATA15_CONF_LCD_DATA15_MMODE_SHIFT) | (1 << CONTROL_CONF_LCD_DATA15_CONF_LCD_DATA15_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_DATA15_CONF_LCD_DATA15_PUTYPESEL_SHIFT) | (1 << CONTROL_CONF_LCD_DATA15_CONF_LCD_DATA15_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA15_CONF_LCD_DATA15_SLEWCTRL_SHIFT); // HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_VSYNC) = (0 << CONTROL_CONF_LCD_VSYNC_CONF_LCD_VSYNC_MMODE_SHIFT) | (0 << CONTROL_CONF_LCD_VSYNC_CONF_LCD_VSYNC_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_VSYNC_CONF_LCD_VSYNC_PUTYPESEL_SHIFT) | (1 << CONTROL_CONF_LCD_VSYNC_CONF_LCD_VSYNC_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_VSYNC_CONF_LCD_VSYNC_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_HSYNC) = (0 << CONTROL_CONF_LCD_HSYNC_CONF_LCD_HSYNC_MMODE_SHIFT) | (0 << CONTROL_CONF_LCD_HSYNC_CONF_LCD_HSYNC_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_HSYNC_CONF_LCD_HSYNC_PUTYPESEL_SHIFT) | (1 << CONTROL_CONF_LCD_HSYNC_CONF_LCD_HSYNC_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_HSYNC_CONF_LCD_HSYNC_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_PCLK) = (0 << CONTROL_CONF_LCD_PCLK_CONF_LCD_PCLK_MMODE_SHIFT) | (0 << CONTROL_CONF_LCD_PCLK_CONF_LCD_PCLK_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_PCLK_CONF_LCD_PCLK_PUTYPESEL_SHIFT) | (1 << CONTROL_CONF_LCD_PCLK_CONF_LCD_PCLK_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_PCLK_CONF_LCD_PCLK_SLEWCTRL_SHIFT); HWREG(SOC_CONTROL_REGS + CONTROL_CONF_LCD_AC_BIAS_EN) = (0 << CONTROL_CONF_LCD_AC_BIAS_EN_CONF_LCD_AC_BIAS_EN_MMODE_SHIFT) | (0 << CONTROL_CONF_LCD_AC_BIAS_EN_CONF_LCD_AC_BIAS_EN_PUDEN_SHIFT) | (0 << CONTROL_CONF_LCD_AC_BIAS_EN_CONF_LCD_AC_BIAS_EN_PUTYPESEL_SHIFT) | (1 << CONTROL_CONF_LCD_AC_BIAS_EN_CONF_LCD_AC_BIAS_EN_RXACTIVE_SHIFT) | (0 << CONTROL_CONF_LCD_DATA23_CONF_LCD_DATA23_SLEWCTRL_SHIFT); // // } /* ** Configures raster to display image */ static void SetUpLCD(void){ /* Enable clock for LCD Module */ LCDModuleClkConfig(); LCDPinMuxSetup(); ConsoleUtilsPrintf("\nsetup LCD\n"); /* **Clock for DMA,LIDD and for Core(which encompasses ** Raster Active Matrix and Passive Matrix logic) ** enabled. */ RasterClocksEnable(LCDC_INSTANCE); /* Disable raster */ RasterDisable(LCDC_INSTANCE); /* Configure the pclk */ RasterClkConfig(LCDC_INSTANCE, 23040000, 192000000); //RasterClkConfig(LCDC_INSTANCE, 800000, 192000000); /* Configuring DMA of LCD controller */ RasterDMAConfig(LCDC_INSTANCE, RASTER_DOUBLE_FRAME_BUFFER, RASTER_BURST_SIZE_16, RASTER_FIFO_THRESHOLD_8, RASTER_BIG_ENDIAN_DISABLE); /* Configuring modes(ex:tft or stn,color or monochrome etc) for raster controller */ RasterModeConfig(LCDC_INSTANCE, RASTER_DISPLAY_MODE_TFT_PACKED, RASTER_PALETTE_DATA, RASTER_COLOR, RASTER_RIGHT_ALIGNED); /* Configuring the polarity of timing parameters of raster controller */ RasterTiming2Configure(LCDC_INSTANCE, RASTER_FRAME_CLOCK_LOW | RASTER_LINE_CLOCK_LOW | RASTER_PIXEL_CLOCK_HIGH| RASTER_SYNC_EDGE_RISING| RASTER_SYNC_CTRL_ACTIVE| RASTER_AC_BIAS_HIGH , 0, 255); /* Configuring horizontal timing parameter */ RasterHparamConfig(LCDC_INSTANCE, 480, 4, 8, 43); /* Configuring vertical timing parameters */ RasterVparamConfig(LCDC_INSTANCE, 272, 10, 4, 12); RasterFIFODMADelayConfig(LCDC_INSTANCE, 128); } /* ** configures arm interrupt controller to generate raster interrupt */ static void LCDAINTCConfigure(void){ /* Register the ISR in the Interrupt Vector Table.*/ IntRegister(SYS_INT_LCDCINT, LCDIsr); IntPrioritySet(SYS_INT_LCDCINT, 0, AINTC_HOSTINT_ROUTE_IRQ ); /* Enable the System Interrupts for AINTC.*/ IntSystemEnable(SYS_INT_LCDCINT); } /* ** For each end of frame interrupt base and ceiling is reconfigured */ static void LCDIsr(void){ unsigned int status; status = RasterIntStatus(LCDC_INSTANCE,RASTER_END_OF_FRAME0_INT_STAT | RASTER_END_OF_FRAME1_INT_STAT ); status = RasterClearGetIntStatus(LCDC_INSTANCE, status); if (status & RASTER_END_OF_FRAME0_INT_STAT){ RasterDMAFBConfig(LCDC_INSTANCE, (unsigned int)curr_image, (unsigned int)curr_image + sizeof(image1) - 2, 0); } if(status & RASTER_END_OF_FRAME1_INT_STAT){ RasterDMAFBConfig(LCDC_INSTANCE, (unsigned int)curr_image, (unsigned int)curr_image + sizeof(image1) - 2, 1); } // last_image = curr_image; }
and in the main function, I've :
LCDAINTCConfigure(); SetUpLCD(); /* Configuring the base ceiling */ RasterDMAFBConfig(LCDC_INSTANCE, (unsigned int)curr_image, (unsigned int)curr_image + sizeof(image1) - 2, 0); RasterDMAFBConfig(LCDC_INSTANCE, (unsigned int)curr_image, (unsigned int)curr_image + sizeof(image1) - 2, 1); /* Enable End of frame0/frame1 interrupt */ RasterIntEnable(LCDC_INSTANCE, RASTER_END_OF_FRAME0_INT | RASTER_END_OF_FRAME1_INT); /* Enable raster */ RasterEnable(LCDC_INSTANCE);
what is wrong with that ? Why can't I see any signal going out ?
