Tool/software: Starterware
Hi ,
I am currently trying to execute a UART program, its as below:
#include "uart_irda_cir.h"
#include "soc_AM335x.h"
#include "evmAM335x.h"
#include "hw_types.h"
#include <hw_uart_irda_cir.h>
** INTERNAL MACRO DEFINITIONS
#define UART_CONSOLE_BASE (SOC_UART_0_REGS)
#define BAUD_RATE_115200 (115200)
#define UART_MODULE_INPUT_CLK (48000000)
** INTERNAL FUNCTION DECLARATIONS
static void UARTStdioInitExpClk(unsigned int baudRate,
unsigned int rxTrigLevel,
unsigned int txTrigLevel);
static void UartFIFOConfigure(unsigned int txTrigLevel,
unsigned int rxTrigLevel);
static void UartBaudRateSet(unsigned int baudRate);
void UARTConsolePutc(unsigned char data);
unsigned char UARTConsoleGetc(void);
void UARTConsoleInit(void);
** FUNCTION DEFINITIONS
* \brief This function initializes the specified UART instance for use.
* This does the following:
* - Enables the FIFO and performs the FIFO settings\n
* - Performs the Baud Rate settings\n
* - Configures the Line Characteristics to 8-N-1 format\n
* \param baudRate The baud rate to be used for communication
* \param rxTrigLevel The receiver FIFO trigger level
* \param txTrigLevel The transmitter FIFO trigger level
* \return None
* \note By default, a granularity of 1 will be selected for transmitter
* and receiver FIFO trigger levels.
/* Performing a module reset. */
UARTModuleReset(UART_CONSOLE_BASE);
/* Performing FIFO configurations. */
UartFIFOConfigure(txTrigLevel, rxTrigLevel);
/* Performing Baud Rate settings. */
UartBaudRateSet(baudRate);
/* Switching to Configuration Mode B. */
UARTRegConfigModeEnable(UART_CONSOLE_BASE, UART_REG_CONFIG_MODE_B);
/* Programming the Line Characteristics. */
UARTLineCharacConfig(UART_CONSOLE_BASE,
(UART_FRAME_WORD_LENGTH_8 | UART_FRAME_NUM_STB_1),
UART_PARITY_NONE);
/* Disabling write access to Divisor Latches. */
UARTDivisorLatchDisable(UART_CONSOLE_BASE);
/* Disabling Break Control. */
UARTBreakCtl(UART_CONSOLE_BASE, UART_BREAK_COND_DISABLE);
/* Switching to UART16x operating mode. */
UARTOperatingModeSelect(UART_CONSOLE_BASE, UART16x_OPER_MODE);
** A wrapper function performing FIFO configurations.
unsigned int fifoConfig = 0;
/* Setting the TX and RX FIFO Trigger levels as 1. No DMA enabled. */
fifoConfig = UART_FIFO_CONFIG(UART_TRIG_LVL_GRANULARITY_1,
txTrigLevel,
rxTrigLevel,
1,
1,
UART_DMA_EN_PATH_SCR,
UART_DMA_MODE_0_ENABLE);
/* Configuring the FIFO settings. */
UARTFIFOConfig(UART_CONSOLE_BASE, fifoConfig);
** A wrapper function performing Baud Rate settings.
unsigned int divisorValue = 0;
/* Computing the Divisor Value. */
divisorValue = UARTDivisorValCompute(UART_MODULE_INPUT_CLK,
baudRate,
UART16x_OPER_MODE,
UART_MIR_OVERSAMPLING_RATE_42);
/* Programming the Divisor Latches. */
UARTDivisorLatchWrite(UART_CONSOLE_BASE, divisorValue);
* - Transmitter and Recevier Threshold Levels are 1 byte each\n
* - Baud Rate of 115200 bits per second(bps)\n
* \param None
* \return None
/* Configuring the system clocks for UART0 instance. */
UART0ModuleClkConfig();
/* Performing the Pin Multiplexing for UART0 instance. */
UARTPinMuxSetup(0);
UARTStdioInitExpClk(BAUD_RATE_115200, 1, 1);
* \brief This function puts a character on the serial console.
* \param data The character to be put on the serial console
* \return None.
UARTCharPut(UART_CONSOLE_BASE, data);
* \param none
* \return Character as input from the console
return ((unsigned char)UARTCharGet(UART_CONSOLE_BASE));
int main()
UARTStdioInitExpClk(BAUD_RATE_115200,UART_FCR_TX_TRIG_LVL_56,UART_FCR_RX_TRIG_LVL_8);
UartFIFOConfigure(UART_FCR_TX_TRIG_LVL_56,UART_FCR_RX_TRIG_LVL_8);
UartBaudRateSet(BAUD_RATE_115200);
UARTConsoleInit();
UARTConsolePutc('S');
During debugging after the 1903th line i am getting an error as no source available as shown below.
We have included all the necessary source and header files.
Kindly help us to overcome with this issue.
