Good morning,
i'm try to know the CPU Load of my application.
I'm using C6457 CCS V5.3 and SYS/BIOS 6.34.2.218 and System Analyzer 1.1.1.14.
I'have instrumented my application with LiggingSetup and enable Load Logging and swi, hwi and task logging.
During the analisys in the CPU Graph i obtain this warning: CPU load may be not accurate as HWI and SWI loads not enabled.
1) Question: How is possible to enable SWI and HWI loads?. I'have yet checks the Enable Swi/Hwi Logging in the LoggingSetup configuration of my .CFG.
2) Question: CPU graph reports the loads of IDLE loop or Anything other than IDLE loop as derscribed in SPRUh43d para. 4.10 CPU Load view?
3) QUESTION: is ncessary use the module in .CFG "ti.sysbios.utils.load" and how to set it , or is not possible use it with LoggingSetup?
Thanks in advance
Fabio
