I followed the directions as per the lab manual, also double checked to see if I set up my build variables correctly. I'm using ccsv6 on Ubuntu 14.04.
Description Resource Path Location Type
<a href="file:/home/krithik/ti/ccsv6/tools/compiler/dmed/HTML/10234.html">#10234-D</a> unresolved symbols remain blink_tm4c_hwi C/C++ Problem
unresolved symbol heartBeatFxn, first referenced in /home/krithik/Projects/workspaces/ccs/ti_rtos_intro_workshop/blink_tm4c_hwi/Debug/configPkg/package/cfg/empty_min_pem4f.oem4f blink_tm4c_hwi C/C++ Problem
#10229-D output section ".data" refers to load symbol "heartBeatFxn" and hence cannot be compressed; compression "rle" is ignored blink_tm4c_hwi C/C++ Problem
#10010 errors encountered during linking; "blink_tm4c_hwi.out" not built blink_tm4c_hwi C/C++ Problem
