I'm currently working with TMS320C6678 simulator in CCS 5.5. I would like to provide communication between CORE0-3 using MessageQ (for transport data) and Notify (for synchronization). In my case Ipc.procSync is set to Ipc.ProcSync_PAIR. CORE0 is master and other cores works as slaves. Off course I call Ipc_attach in CORE0-3. Each core create their own queue. CORE0 open message queue from cores 1-3 and CORE0 open queue form cores 1-3. Here is code from CORE0 task:
Ipc_attach_with_core(1); Ipc_attach_with_core(2); Ipc_attach_with_core(3); Notify_registerEvent(1, INTERRUPT_LINE, EVENTID, (Notify_FnNotifyCbck)cbFxn, NULL); //notify events for simple synchronization Notify_registerEvent(2, INTERRUPT_LINE, EVENTID, (Notify_FnNotifyCbck)cbFxn, NULL); Notify_registerEvent(3, INTERRUPT_LINE, EVENTID, (Notify_FnNotifyCbck)cbFxn, NULL); HeapBufMP_Params_init(&heapBufParams); //creation heap heapBufParams.regionId = 0; heapBufParams.name = HEAP_NAME; heapBufParams.numBlocks = 20; heapBufParams.blockSize = sizeof(A_ES_i_B_ES); heapHandle = HeapBufMP_create(&heapBufParams); if (heapHandle == NULL) { System_abort("HeapBufMP_create failed\n" ); } /* Register this heap with MessageQ */ MessageQ_registerHeap((IHeap_Handle)heapHandle, HEAPID); /* Create the local message queue */ Id_MASTER_queue = MessageQ_create("MASTER_CORE0", NULL); open_queue("SLAVE_CORE1", &Id_CORE1_queue); open_queue("SLAVE_CORE2", &Id_CORE2_queue); open_queue("SLAVE_CORE3", &Id_CORE3_queue); A_ES_i_B_ES_wsk = (A_ES_i_B_ES **) calloc(1, sizeof(A_ES_i_B_ES *)); Vs_wsk = (pot_wezlow_ukladu **) calloc(1, sizeof(pot_wezlow_ukladu *)); Vs_wsk[0] = (pot_wezlow_ukladu *) MessageQ_alloc(HEAPID, sizeof(pot_wezlow_ukladu)); pointer_Vs = Vs_wsk[0]; pointer_A_ES_i_B_ES = A_ES_i_B_ES_wsk[0]; while (TRUE) { System_printf("Start iteration - CORE0 \n"); Notify_sendEvent(1, INTERRUPT_LINE, EVENTID, 0, TRUE); //start signal to other cores Notify_sendEvent(2, INTERRUPT_LINE, EVENTID, 0, TRUE); Notify_sendEvent(3, INTERRUPT_LINE, EVENTID, 0, TRUE); MessageQ_get(Id_MASTER_queue, (MessageQ_Msg *)&pointer_A_ES_i_B_ES, MessageQ_FOREVER); ... MessageQ_get(Id_MASTER_queue, (MessageQ_Msg *)&pointer_A_ES_i_B_ES, MessageQ_FOREVER); ... MessageQ_get(Id_MASTER_queue, (MessageQ_Msg *)&pointer_A_ES_i_B_ES, MessageQ_FOREVER); ... pointer_Vs->Vs[0] = 7.55; pointer_Vs->Vs[1] = 3.78; pointer_Vs->Vs[2] = -0.12; MessageQ_put(Id_CORE1_queue, (MessageQ_Msg)wskaznik_Vs); MessageQ_put(Id_CORE2_queue, (MessageQ_Msg)wskaznik_Vs); MessageQ_put(Id_CORE3_queue, (MessageQ_Msg)wskaznik_Vs); System_printf("Iteration done - CORE0 \n"); }
My structures definitions:
typedef struct A_ES_i_B_ES { MessageQ_MsgHeader header; float B_ES[6]; float A_ES[6][6]; } A_ES_i_B_ES; typedef struct pot_wezlow_ukladu { MessageQ_MsgHeader header; float Vs[3]; } pot_wezlow_ukladu;
Buffers (global) definitions and pointers (local):
pot_wezlow_ukladu * wskaznik_Vs; A_ES_i_B_ES * wskaznik_A_ES_i_B_ES;
static A_ES_i_B_ES ** A_ES_i_B_ES_wsk = 0; static pot_wezlow_ukladu ** Vs_wsk = 0;
At the moment code in other cores is similar (CORES1-3):
while (Ipc_attach(0) < 0) { Task_sleep(1); } Notify_registerEvent(0, INTERRUPT_LINE, EVENTID, (Notify_FnNotifyCbck)cbFxn, NULL); do { //open heap status = HeapBufMP_open(HEAP_NAME, &heapHandle); if (status < 0) { Task_sleep(1); } } while (status < 0); /* Register this heap with MessageQ */ MessageQ_registerHeap((IHeap_Handle)heapHandle, HEAPID); /* Create the local message queue */ Id_SLAVE_queue = MessageQ_create("SLAVE_COREN", NULL); //N is core Id open_queue("MASTER_CORE0", &Id_MASTER_queue); A_ES_i_B_ES_wsk = (A_ES_i_B_ES **) calloc(1, sizeof(A_ES_i_B_ES *)); A_ES_i_B_ES_wsk[0] = (A_ES_i_B_ES *) MessageQ_alloc(HEAPID, sizeof(A_ES_i_B_ES)); Vs_wsk = (pot_wezlow_ukladu **) calloc(1, sizeof(pot_wezlow_ukladu *)); pointer_Vs = Vs_wsk[0]; pointer_A_ES_i_B_ES = A_ES_i_B_ES_wsk[0]; while (TRUE) { while(start_calculations == FALSE); //it's set in Notify callback - wait for start signal from MASTER start_calculations = FALSE; System_printf("Start iteration - CORE N \n"); //N is core Id pointer_A_ES_i_B_ES->A_ES[0][0] = 9.98; pointer_A_ES_i_B_ES->B_ES[0] = -1.23; MessageQ_put(Id_MASTER_queue, (MessageQ_Msg)pointer_A_ES_i_B_ES); MessageQ_get(Id_SLAVE_queue, (MessageQ_Msg *)&pointer_Vs, MessageQ_FOREVER); System_printf("Iteration done - CORE N \n"); //N is core Id }
My functions definitions:
Void open_queue(String name, MessageQ_QueueId *queue_Id) { int status; do { status = MessageQ_open(name, queue_Id); if (status < 0) { Task_sleep(1); } } while (status < 0); } Void Ipc_attach_with_core(UInt16 number_of_core) { while (Ipc_attach(number_of_core) < 0) { Task_sleep(1); } }
My cfg file is the same for all cores:
var nameList = MultiProc.getDeviceProcNames();
MultiProc.setConfig(null, nameList);
var System = xdc.useModule('xdc.runtime.System');
System.extendedFormats = '%$L%$S%$F%f';
var SysStd = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
/* Modules explicitly used in the application */
var Notify = xdc.useModule('ti.sdo.ipc.Notify');
var MessageQ = xdc.useModule('ti.sdo.ipc.MessageQ');
var Ipc = xdc.useModule('ti.sdo.ipc.Ipc');
var HeapBufMP = xdc.useModule('ti.sdo.ipc.heaps.HeapBufMP');
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
/* BIOS/XDC modules */
var BIOS = xdc.useModule('ti.sysbios.BIOS');
BIOS.heapSize = 0x8000;
var Task = xdc.useModule('ti.sysbios.knl.Task');
var tsk0 = Task.create('&tsk0_func');
tsk0.instance.name = "tsk0";
/* Synchronize all processors (this will be done in Ipc_start) */
Ipc.procSync = Ipc.ProcSync_PAIR;
/* Shared Memory base address and length */
var SHAREDMEM = 0x0C000000;
var SHAREDMEMSIZE = 0x00200000;
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
SharedRegion.setEntryMeta(0,
{ base: SHAREDMEM,
len: SHAREDMEMSIZE,
ownerProcId: 0,
isValid: true,
My problem is with exception in CORE2. After this line I get exception:
... MessageQ_get(Id_SLAVE_queue, (MessageQ_Msg *)&pointer_Vs, MessageQ_FOREVER); //exception ...
Exception:
[TMS320C66x_2] ti.sdo.ipc.SharedRegion: line 380: assertion failure: A_idTooLarge: id cannot be larger than numEntries
xdc.runtime.Error.raise: terminating execution
I tried increase SharedRegion.numEntries to 8 in cfg file but it still doesn't work. How can I solve it ?
My configuration is as follow:
IPC: 1.24.3.32
BIOS: 6.33.6.50
MATHLIB C66x: 3.1.0.0
