I'm using DSP/BIOS 5.42.01.09 with XDCTools 3.24.5.48 in CCS6 under Linux. I work with C6745 DSP at custom board with 8Mb SDRAM.
I have some problems with placing task stack into SDRAM.
- BIOS goes to restart when try to execute task with stack in SDRAM
- Tasks with different stack location has different stackPeak value in ROV
- Task stack located in SDRAM seems to be uninitialized at main() entry point (filled with 0xBEBEBEBE)
Could anyone help me?
Below I list minimal working example to illustrate my problem:
I use a bit modified DSP/BIOS tsk example from evmC6747 package (RED marks changes since original example)
SDRAM configuration performed by GEL, before application starts
TCF
utils.loadPlatform("ti.platforms.evm6747");
bios.enableRealTimeAnalysis(prog);
bios.enableMemoryHeaps(prog);
bios.enableRtdx(prog);
bios.enableTskManager(prog);
bios.IRAM.createHeap = true;
bios.IRAM.enableHeapLabel = true;
bios.IRAM["heapLabel"] = prog.extern("SEG0");
bios.IRAM.heapSize = 0x2000;
bios.MEM.BIOSOBJSEG = prog.get("IRAM");
bios.MEM.MALLOCSEG = prog.get("IRAM");
bios.GBL.C64PLUSCONFIGURE = 0;
bios.GBL.C64PLUSMAR128to159 = 0x0000ffff;
bios.CLK.TIMERSELECT = "Timer 0"; /* Select Timer 0 to drive BIOS CLK */
bios.CLK.RESETTIMER = true; /* Take the selected timer our of reset */
bios.LOG_system.bufLen = 512;
var trace = bios.LOG.create("trace");
trace.bufLen = 1024;
trace.logType = "circular";
var task0 = bios.TSK.create("task0");
task0.priority = 1;
task0["fxn"] = prog.extern("task");
task0.arg0 = 0;
var task1 = bios.TSK.create("task1");
task1.priority = 1;
task1["fxn"] = prog.extern("task");
task1.arg0 = 1;
task1.stackMemSeg = prog.get("SDRAM");
var task2 = bios.TSK.create("task2");
task2.priority = 1;
task2["fxn"] = prog.extern("task");
task2.arg0 = 2;
// !GRAPHICAL_CONFIG_TOOL_SCRIPT_INSERT_POINT!
if (config.hasReportedError == false) {
prog.gen();
Task view of ROV:
name | handle | state | priority | timeout | time | block | stackBase | stackSize | stackPeak |
TSK_idle | 0x1180c60c | Ready | 0 | 0 | 0 | 0x1180a6e0 | 1024 | 168 | |
task0 | 0x1180c66c | Ready | 1 | 0 | 0 | 0x1180aee0 | 1024 | 100 | |
task1 | 0x1180c6cc | Ready | 1 | 0 | 0 | 0xc0000000 | 1024 | 0 | |
task2 | 0x1180c72c | Ready | 1 | 0 | 0 | 0x1180b2e0 | 1024 | 100 |
Memory dumps at main() entry point
task0$stkptr
BEBEBEBE 00000000 00000000 11803320 00000000 11802AF8 00000000 00000000 00000000 00000000 00000000
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 1180A5A4
11802C60 00000000 00000000 BEBEBEBE
task1$stkptr
BEBEBEBE BEBEBEBE BEBEBEBE BEBEBEBE BEBEBEBE BEBEBEBE BEBEBEBE BEBEBEBE BEBEBEBE BEBEBEBE BEBEBEBE
Memory dumps at BIOS_init() entry
task0$stkptr
task1$stkptr
00000000 00000000 00000000 00000000 00000001 00000000 00000000 00000000 00000000 00000000 1180A5A4
