Am trying to load X.out file in DSP_CORE0 and Y.out file in DSP_CORE1 - to test IPC communication . But the program get into indefinite run state in Ipc_attach().
But the code works fine incase of single .out file where code for each core is differentiated using an If statement. Ipc example program also denotes the same running procedure for IPC.
Is it possible to run different .out file in different core ?
Any additional change is required in the .cfg file ?
How to synchronize different core ?_-Synchronize core in group is not functioning ?
