Hi
I am Using Code Composer Studio Version: 6.0.1.00040
Board :-TM4C1294 EVM Kit
I add the one more switch and LED for PORTE PIN0 and PIN1 and Modified the gpiointerrupt Project files
In gpiointerrupt.c add one more function and modified main function, modified EK_TM4C1294XL.C and Baord.h But still not working What changes need to do
* ======== gpiointerrupt.c ========
void gpioButtonFxn2(void) {
/* Clear the GPIO interrupt and toggle an LED */
GPIO_toggle(Board_LED3);
GPIO_clearInt(Board_BUTTON2);
if (count++ == 100) {
count = 0;
* ======== main ========
int main(void) {
/* Call board init functions */
Board_initGeneral();
Board_initGPIO();
Board_initUART();
/* Turn on user LED */
GPIO_write(Board_LED0, Board_LED_OFF);
GPIO_write(Board_LED1, Board_LED_OFF);
GPIO_write(Board_LED3, Board_LED_ON);
System_printf("Starting the GPIO Interrupt example\nSystem provider is set"
" to SysMin. Halt the target to view any SysMin contents in"
" ROV.\n");
/* SysMin will only print to the console when you call flush or exit */
System_flush();
/* Initialize interrupts for all ports that need them */
GPIO_setupCallbacks(&Board_gpioCallbacks0);
/* Enable interrupts */
GPIO_enableInt(Board_BUTTON0, GPIO_INT_RISING);
GPIO_enableInt(Board_BUTTON2, GPIO_INT_RISING);
* If more than one input pin is available for your device, interrupts
* will be enabled on Board_BUTTON1.
if (Board_BUTTON0 != Board_BUTTON1) {
/* Need to call setup if the button is on a different port */
if (&Board_gpioCallbacks0 != &Board_gpioCallbacks1) {
GPIO_setupCallbacks(&Board_gpioCallbacks1);
GPIO_enableInt(Board_BUTTON1, GPIO_INT_FALLING);
/* Start BIOS */
BIOS_start();
return (0);
* ======== EK_TM4C1294XL.c ========
* This file is responsible for setting up the board specific items for the
* EK_TM4C1294XL board.
* =============================== GPIO ===============================
/* Place into subsections to allow the TI linker to remove items properly */
#if defined(__TI_COMPILER_VERSION__)
#pragma DATA_SECTION(GPIO_config, ".const:GPIO_config")
#pragma DATA_SECTION(gpioHWAttrs, ".const:gpioHWAttrs")
#endif
#include <ti/drivers/GPIO.h>
/* Callback functions for the GPIO interrupt example. */
void gpioButtonFxn0(void);
void gpioButtonFxn1(void);
void gpioButtonFxn2(void);
/* GPIO configuration structure */
const GPIO_HWAttrs gpioHWAttrs[EK_TM4C1294XL_GPIOCOUNT] = {
{GPIO_PORTN_BASE, GPIO_PIN_1, GPIO_OUTPUT}, /* EK_TM4C1294XL_USR_D1 */
{GPIO_PORTN_BASE, GPIO_PIN_0, GPIO_OUTPUT}, /* EK_TM4C1294XL_USR_D2 */
{GPIO_PORTJ_BASE, GPIO_PIN_0, GPIO_INPUT}, /* EK_TM4C1294XL_USR_SW1 */
{GPIO_PORTJ_BASE, GPIO_PIN_1, GPIO_INPUT}, /* EK_TM4C1294XL_USR_SW2 */
{GPIO_PORTE_BASE, GPIO_PIN_0, GPIO_OUTPUT},
{GPIO_PORTE_BASE, GPIO_PIN_1, GPIO_INPUT}
/* Memory for the GPIO module to construct a Hwi */
Hwi_Struct callbackPortJHwi,callbackPortEHwi;
const GPIO_Callbacks EK_TM4C1294XL_gpioPortJCallbacks = {
GPIO_PORTJ_BASE, INT_GPIOJ, &callbackPortJHwi,
{gpioButtonFxn0, gpioButtonFxn1, NULL, NULL, NULL, NULL, NULL}
const GPIO_Callbacks EK_TM4C1294XL_gpioPortECallbacks = {
GPIO_PORTE_BASE, INT_GPIOE, &callbackPortEHwi,
{ gpioButtonFxn2,NULL,NULL, NULL, NULL, NULL, NULL}
const GPIO_Config GPIO_config[] = {
{&gpioHWAttrs[0]},
{&gpioHWAttrs[1]},
{&gpioHWAttrs[2]},
{&gpioHWAttrs[3]},
{&gpioHWAttrs[4]},
{&gpioHWAttrs[5]},
{NULL},
* ======== EK_TM4C1294XL_initGPIO ========
void EK_TM4C1294XL_initGPIO(void)
/* Setup the LED GPIO pins used */
GPIOPinTypeGPIOOutput(GPIO_PORTN_BASE, GPIO_PIN_0 | GPIO_PIN_1);
GPIOPinTypeGPIOOutput(GPIO_PORTE_BASE, GPIO_PIN_0 );
/* Setup the button GPIO pins used */
GPIOPinTypeGPIOInput(GPIO_PORTJ_BASE, GPIO_PIN_0 | GPIO_PIN_1);
GPIOPinTypeGPIOInput(GPIO_PORTE_BASE, GPIO_PIN_1);
GPIOPadConfigSet(GPIO_PORTJ_BASE, GPIO_PIN_0 | GPIO_PIN_1, GPIO_STRENGTH_2MA,
GPIO_PIN_TYPE_STD_WPU);
GPIOPadConfigSet(GPIO_PORTE_BASE, GPIO_PIN_0 , GPIO_STRENGTH_2MA,
/* Once GPIO_init is called, GPIO_config cannot be changed */
GPIO_init();
//**************Board.h **************************
#define Board_LED3 EK_TM4C1294XL_D3
#define Board_BUTTON2 EK_TM4C1294XL_USR_SW3
