* Copyright (c) 2014, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== fatsd.cfg ========
/* ================ General configuration ================ */
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Error = xdc.useModule('xdc.runtime.Error');
var Log = xdc.useModule('xdc.runtime.Log');
var Main = xdc.useModule('xdc.runtime.Main');
var Memory = xdc.useModule('xdc.runtime.Memory');
var System = xdc.useModule('xdc.runtime.System');
var Text = xdc.useModule('xdc.runtime.Text');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var FatFS = xdc.useModule('ti.sysbios.fatfs.FatFS');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var UART = xdc.useModule('ti.drivers.UART');
var SPI = xdc.useModule('ti.drivers.SPI');
var Timer = xdc.useModule('ti.sysbios.hal.Timer');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
/* System stack size (used by ISRs and Swis) */
Program.stack = 768;
/* get handle to xdc Reset module */
var Reset = xdc.useModule('xdc.runtime.Reset');
/* install a "reset function" */
Reset.fxns[Reset.fxns.length++] = '&EPI_Init';
* Comment this line to allow module names to be loaded on the target.
* The module name strings are placed in the .const section. Setting this
* parameter to false will save space in the .const section. Error and
* Assert messages will contain an "unknown module" prefix instead
* of the actual module name.
Defaults.common$.namedModule = false;
* Minimize exit handler array in System. The System module includes
* an array of functions that are registered with System_atexit() to be
* called by System_exit().
System.maxAtexitHandlers = 2;
* Comment this line to allow Error, Assert, and Log strings to be
* loaded on the target. These strings are placed in the .const section.
* Setting this parameter to false will save space in the .const section.
* Error, Assert and Log message will print raw ids and args instead of
* a formatted message.
Text.isLoaded = false;
/* ================ System configuration ================ */
var SysStd = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
/* Enable Semihosting for GNU targets to print to CCS console */
if (Program.build.target.$name.match(/gnu/)) {
var SemiHost = xdc.useModule('ti.sysbios.rts.gnu.SemiHostSupport');
/* ================ BIOS configuration ================ */
* Disable unused BIOS features to minimize footprint.
* This example uses Tasks but not Swis or Clocks.
var BIOS = xdc.useModule('ti.sysbios.BIOS');
BIOS.libType = BIOS.LibType_Custom;
BIOS.swiEnabled = false;
BIOS.logsEnabled = false;
BIOS.assertsEnabled = false;
/* Reduce the heap size 64KB */
//BIOS.heapSize = 61440; // 60KB okey
BIOS.heapSize = 65536/*81920*/;
/* No runtime stack checking is performed */
Task.checkStackFlag = false;
/* Reduce the number of task priorities */
Task.numPriorities = 16;
/* Remove the Idle Task */
Task.enableIdleTask = false;
/* ================ Driver configuration ================ */
var TIRTOS = xdc.useModule('ti.tirtos.TIRTOS');
var GPIO = xdc.useModule('ti.drivers.GPIO');
var SDSPI = xdc.useModule('ti.drivers.SDSPI');
GPIO.libType = GPIO.LibType_NonInstrumented;
SDSPI.libType = SDSPI.LibType_NonInstrumented;
var timer0Params = new Timer.Params();
timer0Params.instance.name = "timer0";
timer0Params.period = 1000;
timer0Params.startMode = xdc.module("ti.sysbios.interfaces.ITimer").StartMode_USER;
Program.global.timer0 = Timer.create(1, "&INTR_Isr_TIMER0", timer0Params);
var timer1Params = new Timer.Params();
timer1Params.instance.name = "timer2";
timer1Params.period = 1000;
timer1Params.startMode = xdc.module("ti.sysbios.interfaces.ITimer").StartMode_USER;
Program.global.timer2 = Timer.create(2, "&INTR_Isr_TIMER2", timer1Params);
Hwi.dispatcherSwiSupport = false;
