I had problems configuring input pin as GPIO_CFG_INPUT with GPIO_setConfig() and GPIO_Init() in the latest TI-RTOS and think there is a bug in the GPIO_setConfig() routing in GPIOMSP430.c
The code uses the defines from GPIO.h
#define GPIO_CFG_INPUT (((uint32_t) 1) << GPIO_CFG_IO_LSB) /*! Pin is an input. */ #define GPIO_CFG_IN_NOPULL (((uint32_t) 1) << GPIO_CFG_IO_LSB) /*! Input pin has no PU/PD */ #define GPIO_CFG_IN_PU (((uint32_t) 3) << GPIO_CFG_IO_LSB) /*! Input pin has Pullup */ #define GPIO_CFG_IN_PD (((uint32_t) 5) << GPIO_CFG_IO_LSB) /*! Input pin has Pulldown */
and in GPIOMSP430.c/GPIO_setConfig()
if (!(pinConfig & GPIO_CFG_IN_INT_ONLY)) { if (pinConfig & GPIO_CFG_INPUT) { /* Configure as input */ if (pinConfig & GPIO_CFG_IN_PU) { GPIO_setAsInputPinWithPullUpResistor(gpioPort, gpioPin); } else if (pinConfig & GPIO_CFG_IN_PD) { GPIO_setAsInputPinWithPullDownResistor(gpioPort, gpioPin); } else { GPIO_setAsInputPin(gpioPort, gpioPin); } }
Any input line will always be configured as a GPIO_CFG_IN_PU as (pinConfig & GPIO_CFG_IN_PU) will always be true if the input is GPIO_CFG_INPUT as (1&3) and (1&5) will always result in true.
The workaround I've used for now is to use the GPIO_setAsInputPin(gpioPort, gpioPin); API directly and not the RTOS API.
