Hello!
In out project we noticed repeated program crash after switching from UIA 1.3.1.08 to 2.0.3.43. Just in hope that someone may faced similar issue, please suggest, what to check first.
Thanks in advance.
Hello!
Thanks in advance.
Hello Janet,
Thank you for response. We are using C6670 on custom board.
CGT 7.4.14
SYS/BIOS 6.40.4.47
XDCtools 3.31.1.33 core
UIA 2.0.3.43
MCSDK 2.1.2.6
PDK 1.1.2.6
Please see complete cfg file attached. One thing we note, that likely the line
LoggingSetup.sysbiosHwiLogging = true;
is making troubles. Honestly, I don't know, when and how that line was added as I joined the project late.
Thanks again.
The Hwi logging could be affecting the timing of things. If you disable the Hwi logging do you still see the crashing? Could you also check if changing the logging to JTAGSTOPMODE has any affect?
Are you able to get any information on the crash that is happening?
Janet
