Folks,
Other than less code written by the user, what's another advantage of creating a Task statically vs dynamically?
Is there any speed improvement, or performance in general?
Folks,
Pototo,
The primary benefit of creating Tasks statically is that the Task creation code (both the application calls to Task_create(), and Task_create() itself) does not need to reside on the target, so code footprint is reduced. Once a Task is created, there is no difference in performance depending on whether it was statically or dynamically created.
A key benefit for dynamic creation is that these tasks can be dynamically deleted.
You might want to open Bios_User_Guide.pdf in your installation, and search for mentions of “static”.
Scott
Hi Scott,
I have a question too similarly about dynamic vs static.
If a task was statically defined, will it appear in the cfg file?
The reason I ask is because the SensorTag example project for CC2650 which is TI-RTOS based is using tasks (It can be seen it in the code) but when I go to the cfg file under tasks->instances I see the list of tasks is empty. I assume TI configured the tasks statically and therefore they cannot be configured dynamically.
I might have answered my own question but I would like you to please confirm my understanding.
