i am looking for help in order to configure a mailbox to use a specific memory segment.
I use this code (which compile and link correctly)
extern Int SDRAM_HEAP;
MBX_Attrs mbxAttrs;
mbxAttrs.segid = SDRAM_HEAP;
g_hMailbox = MBX_create(sizeof(ear_trace), 16, &mbxAttrs);
However, it seems that all segment Id (SDRAM_HEAP, IRAM,... ) are set to the same value : 0
extern Int IRAM;
extern Int DSP_BIOS;
extern Int SDRAM_CODE;
I suspect that something is missing but i do not know what. I want to either specify a value or let CCS set a different value for each segment Id.
Does someone know how to correctly configure theses values ?
Thank
