I am going off the TI-RTOS for TivaC example udpEcho_DK_TM4C129X_GNU_TivaTM4C129XNCZAD
Instead of using recvfrom() to workout what ip address to echo back to, I would like to modify this function so that I only send out information, instead of waiting for a message to echo back.
Therefore, how would I go about defining an IP address within code so that the tiva sends a message to a PC console?
udpEcho.c
/* * ======== udpEcho.c ======== * Contains BSD sockets code. */ #include <string.h> #include <xdc/std.h> #include <xdc/cfg/global.h> #include <xdc/runtime/System.h> #include <ti/sysbios/BIOS.h> #include <ti/sysbios/knl/Task.h> #include <ti/drivers/GPIO.h> /* NDK BSD support */ #include <sys/socket.h> /* Example/Board Header file */ #include "Board.h" #define UDPPACKETSIZE 256 /* * ======== echoFxn ======== * Echoes UDP messages. * */ Void echoFxn(UArg arg0, UArg arg1) { int bytesRcvd; int bytesSent; int status; int server; fd_set readSet; struct sockaddr_in localAddr; struct sockaddr_in clientAddr; socklen_t addrlen; char buffer[UDPPACKETSIZE]; server = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP); if (server == -1) { System_printf("Error: socket not created.\n"); goto shutdown; } memset(&localAddr, 0, sizeof(localAddr)); localAddr.sin_family = AF_INET; localAddr.sin_addr.s_addr = htonl(INADDR_ANY); localAddr.sin_port = htons(arg0); status = bind(server, (struct sockaddr *)&localAddr, sizeof(localAddr)); if (status == -1) { System_printf("Error: bind failed.\n"); goto shutdown; } do { /* * readSet and addrlen are value-result arguments, which must be reset * in between each select() and recvfrom() call */ FD_ZERO(&readSet); FD_SET(server, &readSet); addrlen = sizeof(clientAddr); /* Wait forever for the reply */ status = select(server + 1, &readSet, NULL, NULL, NULL); if (status > 0) { if (FD_ISSET(server, &readSet)) { bytesRcvd = recvfrom(server, buffer, UDPPACKETSIZE, 0, (struct sockaddr *)&clientAddr, &addrlen); if (bytesRcvd > 0) { bytesSent = sendto(server, buffer, bytesRcvd, 0, (struct sockaddr *)&clientAddr, addrlen); if (bytesSent < 0 || bytesSent != bytesRcvd) { System_printf("Error: sendto failed.\n"); goto shutdown; } } } } } while (status > 0); shutdown: if (server > 0) { close(server); } } /* * ======== main ======== */ int main(void) { /* Call board init functions */ Board_initGeneral(); Board_initGPIO(); Board_initEMAC(); /* Turn on user LED */ GPIO_write(Board_LED0, Board_LED_ON); System_printf("Starting the UDP Echo example\nSystem provider is set to " "SysMin. Halt the target to view any SysMin contents in" " ROV.\n"); /* SysMin will only print to the console when you call flush or exit */ System_flush(); /* Start BIOS */ BIOS_start(); return (0); }
udpEchoHooks.c
/* * ======== udpEchoHooks.c ======== * Contains non-BSD sockets code (NDK Network Open Hook) */ /* XDCtools Header files */ #include <xdc/std.h> #include <xdc/cfg/global.h> #include <xdc/runtime/Error.h> #include <xdc/runtime/System.h> /* BIOS Header files */ #include <ti/sysbios/BIOS.h> #include <ti/sysbios/knl/Task.h> #define UDPPORT 1000 /* Prototypes */ Void echoFxn(UArg arg0, UArg arg1); /* * ======== netOpenHook ======== * NDK network open hook used to initialize IPv6 */ void netOpenHook() { Task_Handle taskHandle; Task_Params taskParams; Error_Block eb; /* Make sure Error_Block is initialized */ Error_init(&eb); /* * Create the Task that handles UDP "connections." * arg0 will be the port that this task listens to. */ Task_Params_init(&taskParams); taskParams.stackSize = 1024; taskParams.priority = 1; taskParams.arg0 = UDPPORT; taskHandle = Task_create((Task_FuncPtr)echoFxn, &taskParams, &eb); if (taskHandle == NULL) { System_printf("main: Failed to create udpHandler Task\n"); } }
