Hi all,
there is a something_pe66.c under /debug/configpackage/package/cfg.
What does it stand for? Who or what program uses it? Why is it under debug folder although
it is a c source file.
thanks in advance..
mustafa
edit: typo fix
Hi all,
thanks in advance..
mustafa
edit: typo fix
mustafa,
that source file and a linker command file with the extension .xdl are generated based on your CFG script. That's how your CFG controls your application. The C file is compiled in the process of building your app, and then it's linked with your source files. All generated files are located in the directory package/cfg so it's easier to remove them whenever your project is reconfigured and also not to pollute the top directory where your source files are located.
Here is a much longer description of the RTSC config flow: rtsc.eclipse.org/.../Introducing_RTSC.
