I have a working library and I want to make it XDAIS compliant for my project. In order to do so, I have generated a XDAIS compliant project using XDM GenAlg version 7.21 successfully. I followed this link in order to do that.
processors.wiki.ti.com/.../XDM_GenAlg_Wizard_FAQ
However, I understood that the project generated is a "Standard Makefile Project" but not a CCS project. https://e2e.ti.com/support/embedded/tirtos/f/355/t/165201
Can you please point out to me, where the Compiler options for the generated project are? Please find the screen cap for Project Properties for the GenAlg created project.
I need to set the compiler options because it is important for us to build this project with optimization level enabled in order to verify the performance of the algorithm.
I am currently using CCS Version: 6.0.1.00040.
As shown in the screen cap below, I do not find a C6000 Compiler option. Is there a fix for this? Evidently there was a fix in older 5.1 and 5.2 versions, but now it's broken again ?
NOTE: Maybe I am doing this all wrong, since I already have a working library and all I need is a XDAIS wrapper around the code. Is there any way that I can include c files from my library and build a XDAIS compliant library in a more simpler way?
Thanks!
Sarvani Chadalapaka
HPC Systems Engineer
Signalogic Inc.
