I'm trying to write a code to comminucate flash(w25x40) with spi. Write and read status = 0 ( it means this functions works )but write and read buffer didn't work properly. I didn't use read and write buffer . If anyone know about how to use this buffers please help me.
Here is project in github:
I was write that code :
* Copyright (c) 2016, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// ======== uartecho.c ========
// XDCtools Header files //
#include <xdc/std.h>
#include <xdc/runtime/System.h>
#include <xdc/cfg/global.h>
// BIOS Header files //
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Clock.h>
// TI-RTOS Header files //
#include <ti/drivers/PIN.h>
#include <ti/drivers/UART.h>
#include <ti/drivers/I2C.h>
#include <ti/drivers/SPI.h>
// Example/Board Header files
#include "Board.h"
#include <stdlib.h>
#include <stdbool.h>
#include <stdint.h>
#define TASKSTACKSIZE 768
Task_Struct task0Struct;
Char task0Stack[TASKSTACKSIZE];
// Global memory storage for a PIN_Config table
static PIN_State ledPinState;
static SPI_Handle spiHandle;
static SPI_Params spiParams;
// Application LED pin configuration table:
// - All LEDs board LEDs are off.
PIN_Config ledPinTable[] = {
Board_LED0 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
Board_LED1 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
Board_LED2 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
Board_GENERALPURPOSE1 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX,
Board_CP2103UARTRESET | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX,
Board_SPI_FLASH_CS | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MIN,
// Board_SPI0_MOSI | PIN_PULLDOWN,
// Board_SPI0_MISO | PIN_PULLDOWN,
// Board_SPI0_CLK | PIN_PULLDOWN,
PIN_TERMINATE
PIN_Handle ledPinHandle;
int bspSpiWriteRead(uint8_t *buf, uint8_t wlen, uint8_t rlen)
SPI_Transaction masterTransaction;
bool success;
masterTransaction.count = wlen + rlen;
masterTransaction.txBuf = buf;
masterTransaction.arg = NULL;
masterTransaction.rxBuf = buf;
success = SPI_transfer(spiHandle, &masterTransaction);
if (success)
System_printf("data transfered\n");
System_flush();
memcpy(buf,buf+wlen,rlen);
return success ? 0 : -1;
int bspSpiRead(uint8_t *buf, size_t len)
//uint8_t status;
bool s;
masterTransaction.count = len;
masterTransaction.txBuf = NULL;
SPI_Status status;
//System_printf("status = %u \n", status);
s= SPI_transfer(spiHandle, &masterTransaction) ? 0 : -1;
System_printf("spi read status = %d\n", masterTransaction.status);
return s;
int bspSpiWrite(const uint8_t *buf, size_t len)
bool s1;
masterTransaction.txBuf = (void*)buf;
masterTransaction.rxBuf = NULL;
s1= SPI_transfer(spiHandle, &masterTransaction) ? 0 : -1;
System_printf("spi write status = %d\n", masterTransaction.status);
return s1;
#define EFL_ADDR_RECOVERY 0x20000
#define EFL_SIZE_RECOVERY 0x20000
#define EFL_PAGE_SIZE 0x1000
#define EFL_FLASH_SIZE 0x80000
#define BLS_PROGRAM_PAGE_SIZE 256
#define BLS_CODE_PROGRAM 0x02 /**< Page Program */
#define BLS_CODE_READ 0x03 /**< Read Data */
#define BLS_CODE_READ_STATUS 0x05 /**< Read Status Register */
#define BLS_CODE_WRITE_ENABLE 0x06 /**< Write Enable */
#define BLS_CODE_SECTOR_ERASE 0x20 /**< Sector Erase */
#define BLS_CODE_MDID 0x90 /**< Manufacturer Device ID */
bool extFlashWrite(size_t offset, size_t length, const uint8_t *buf)
uint8_t wbuf[4];
while (length > 0)
/* Wait till previous erase/program operation completes */
size_t ilen; /* interim length per instruction */
ilen = BLS_PROGRAM_PAGE_SIZE - (offset % BLS_PROGRAM_PAGE_SIZE);
if (length < ilen)
ilen = length;
wbuf[0] = BLS_CODE_PROGRAM;
wbuf[1] = (offset >> 16) & 0xff;
wbuf[2] = (offset >> 8) & 0xff;
wbuf[3] = offset & 0xff;
offset += ilen;
length -= ilen;
/* Up to 100ns CS hold time (which is not clear
* whether it's application only in between reads)
* is not imposed here since above instructions
* should be enough to delay
* as much. */
PIN_setOutputValue(ledPinHandle,Board_SPI_FLASH_CS,Board_FLASH_CS_ON);
if (bspSpiWrite(wbuf, sizeof(wbuf)))
/* failure */
PIN_setOutputValue(ledPinHandle,Board_SPI_FLASH_CS,Board_FLASH_CS_OFF);
return false;
if (bspSpiWrite(buf,ilen))
/* failure */
return false;
buf += ilen;
return true;
bool extFlashRead(size_t offset, size_t length, uint8_t *buf)
uint8_t wbuf[4];
/* SPI is driven with very low frequency (1MHz < 33MHz fR spec)
* in this temporary implementation.
* and hence it is not necessary to use fast read. */
wbuf[0] = BLS_CODE_READ;
/* failure */
return false;
int ret = bspSpiRead(buf, length);
return ret == 0;
// ======== echoFxn ========
// Task for this function is created statically. See the project's .cfg file.
Void taskFxn(UArg arg0, UArg arg1)
ledPinHandle = PIN_open(&ledPinState, ledPinTable);
PIN_setOutputValue(ledPinHandle, Board_LED0, 1);
/* Configure SPI as master, 1 mHz bit rate*/
SPI_Params_init(&spiParams);
spiParams.bitRate = 1000000;
spiParams.mode = SPI_MASTER;
spiParams.transferMode = SPI_MODE_BLOCKING;
/* Attempt to open SPI. */
spiHandle = SPI_open(Board_SPI0, &spiParams);
if (spiHandle == NULL)
System_printf("spi is not open \n");
System_flush();
else{
System_printf("spi is open \n");
System_flush();
size_t offset;
static uint8_t wrbuf[25] = { 3 };
static uint8_t rdbuf[25] = {4};
memset(wrbuf,5, sizeof(wrbuf));
memset(rdbuf,4, sizeof(rdbuf));
bool success;
uint32_t address;
success = extFlashWrite(EFL_ADDR_RECOVERY, sizeof(wrbuf), wrbuf);
if (success)
extFlashRead(EFL_ADDR_RECOVERY, sizeof(rdbuf), rdbuf);
//success = buf[2] == pIntFlash[2] && buf[3] == pIntFlash[3];
System_printf("read buf %u %u \n", rdbuf[2], rdbuf[3]);
System_printf("write buf %u %u \n", wrbuf[3], wrbuf[4]);
System_flush();
//for (address=0; address<EFL_SIZE_RECOVERY && success; address+=EFL_PAGE_SIZE)
//for (offset=0; offset<EFL_PAGE_SIZE; offset+=sizeof(wrbuf))
// const uint8_t *pIntFlash;
// Copy from internal to external flash
//pIntFlash = (const uint8_t*)address + offset;
//memcpy(buf,pIntFlash,sizeof(buf));
// ======== main ========
int main(void)
Task_Params taskParams;
// Call board init functions
Board_initGeneral();
Board_initSPI();
// Construct BIOS objects
Task_Params_init(&taskParams);
taskParams.stackSize = TASKSTACKSIZE;
taskParams.stack = &task0Stack;
Task_construct(&task0Struct, (Task_FuncPtr)taskFxn, &taskParams, NULL);
// Open LED pins
if(!ledPinHandle) {
System_printf("Error initializing board LED pins\n");
System_flush();
else{
System_printf("Perfect! initializing board LED pins\n");
System_flush();
// PIN_setOutputValue(ledPinHandle, Board_LED0, 1);
PIN_setOutputValue(ledPinHandle, Board_LED1, 1);
PIN_setOutputValue(ledPinHandle, Board_LED2, 1);
PIN_setOutputValue(ledPinHandle, Board_CP2103UARTRESET, 1);
// PIN_setOutputValue(ledPinHandle, Board_GENERALPURPOSE1, 1);
// Start BIOS
BIOS_start();
return (0);
