I am using a Timer to implement a "delayMicroSeconds" function, which does a semaphore_pend on a semaphore that will be posted by the timer.
I have also added a PWM control. When I init the PWM, the second delayMicroseconds() basically blocks on the semaphore_pend forever - which indicates the timer may not be getting fired.
I was wondering if the introduction of the PWM timer is conflicting with the one-shot timer. For the PWM I am using TIMERA0_BASE, TIMERA. For the one-shot timer, I use TIMER_ANY
I init the Timer_Handle so
Timer_Handle timerHandle; void microSecondTimerFxn(UArg arg0) { Semaphore_post(semMicroSecDelay); } void init() { Error_Block eb; Timer_Params timerParams; Task_Handle taskHandle; Error_init(&eb); Timer_Params_init(&timerParams); timerParams.startMode = Timer_StartMode_USER; timerParams.runMode = Timer_RunMode_ONESHOT; timerHandle = Timer_create(Timer_ANY, microSecondTimerFxn, &timerParams, &eb); if (timerHandle == NULL) { System_abort("[pmSensor] Timer create failed"); } ... } void delayMicroseconds(int delayus) { // disable interrupts if an interrupt could lead to // another call to Timer_start(). UInt key = Hwi_disable(); Timer_setPeriodMicroSecs(timerHandle, delayus); Timer_start(timerHandle); Hwi_restore(key); System_printf("[delayMicroSeconds] semaphore pend\n"); Semaphore_pend(semMicroSecDelay, BIOS_WAIT_FOREVER); } void doStuff() { ... delayMicroseconds(100); .... delayMicroseconds(100); <----- hangs here on pend, consistently .... delayMicroseconds(100); .... }
Here is the PWM stuff
PWM_Handle fanPWMHandle = NULL; uint16_t pwmPeriod = 3000; // Period and duty in microseconds void FAN_init() { PWM_Params params; PWM_Params_init(¶ms); params.period = pwmPeriod; fanPWMHandle = PWM_open(Board_PWMFAN, ¶ms); if (fanPWMHandle == NULL) { System_abort("Board_PWMFAN did not open\n"); } else { System_printf("Board_PWNFAN has been initialized!\n"); } } void FAN_set(int fan, int speedPercent) { if (!fanPWMHandle) { return; } System_printf("[FAN] set %d fan to speed %d\n", fan, speedPercent); uint16_t duty = (speedPercent/100.0 * pwmPeriod); PWM_setDuty(fanPWMHandle, duty); }
Board.h
#define Board_PWMFAN CC3200_LAUNCHXL_PWM0
CC3200_LAUNCHXL.h
/*! * @def CC3200_LAUNCHXL_PWMName * @brief Enum of PWM names on the CC3200_LAUNCHXL dev board */ typedef enum CC3200_LAUNCHXL_PWMName { CC3200_LAUNCHXL_PWM0 = 0, CC3200_LAUNCHXL_PWMCOUNT } CC3200_LAUNCHXL_PWMName;
CC3200_LAUNCHXL.c
/* * =============================== PWM =============================== */ /* Place into subsections to allow the TI linker to remove items properly */ #if defined(__TI_COMPILER_VERSION__) #pragma DATA_SECTION(PWM_config, ".const:PWM_config") #pragma DATA_SECTION(pwmTimerCC3200HWAttrs, ".const:pwmTimerCC3200HWAttrs") #endif #include <ti/drivers/PWM.h> #include <ti/drivers/pwm/PWMTimerCC3200.h> PWMTimerCC3200_Object pwmTimerCC3200Objects[CC3200_LAUNCHXL_PWMCOUNT]; const PWMTimerCC3200_HWAttrs pwmTimerCC3200HWAttrs[CC3200_LAUNCHXL_PWMCOUNT] = { { /* CC3200_LAUNCHXL_PWM0 */ /* TIMERA0A - From Redbear pins_energia.h */ .baseAddr = TIMERA0_BASE, .timer = TIMER_A } // { /* CC3200_LAUNCHXL_PWM7 */ // .baseAddr = TIMERA3_BASE, // .timer = TIMER_B // } }; const PWM_Config PWM_config[] = { { .fxnTablePtr = &PWMTimerCC3200_fxnTable, .object = &pwmTimerCC3200Objects[0], .hwAttrs = &pwmTimerCC3200HWAttrs[0] }, // { // .fxnTablePtr = &PWMTimerCC3200_fxnTable, // .object = &pwmTimerCC3200Objects[1], // .hwAttrs = &pwmTimerCC3200HWAttrs[1] // }, {NULL, NULL, NULL} }; /* * ======== CC3200_LAUNCHXL_initPWM ======== */ void CC3200_LAUNCHXL_initPWM(void) { PWM_init(); }
Sridhar
