I migrated from CCS 6.1.2 (RTOS 2.14.0.10 for TivaC). to CCS 6.1.3.00034 (RTOS for TivaC 2.16.1.14), When I rebuilt my existing projects, I got the following errors. Your advice is solicited.
Description Resource Path Location Type
gmake: *** [../src/sysbios/sysbios.aem4f] Error 2 EKU_Firmware C/C++ Problem
gmake: Target 'all' not remade because of errors. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'BIOS.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'family/arm/lm4/Timer.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'family/arm/lm4/TimestampProvider.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'family/arm/m3/Hwi_asm_switch.sv7M', needed by 'm3_Hwi_asm_switch.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'family/arm/m3/Hwi_asm.sv7M', needed by 'm3_Hwi_asm.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'family/arm/m3/Hwi.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'family/arm/m3/IntrinsicsSupport_asm.sv7M', needed by 'm3_IntrinsicsSupport_asm.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'family/arm/m3/TaskSupport_asm.sv7M', needed by 'm3_TaskSupport_asm.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'family/arm/m3/TaskSupport.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'gates/GateAll.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'gates/GateHwi.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'gates/GateMutex.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'hal/Hwi_stack.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'hal/Hwi_startup.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'hal/Hwi.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'hal/Timer.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'heaps/HeapMem.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'io/DEV.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'io/GIO.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'io/IOM_stub.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'knl/Clock.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'knl/Event.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'knl/Idle.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'knl/Intrinsics.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'knl/Queue.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'knl/Semaphore.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'knl/Swi_andn.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'knl/Swi.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'knl/Task.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'utils/Load_CPU.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'utils/Load.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: *** No rule to make target 'xdcruntime/SemThreadSupport.c', needed by 'BIOS.obj'. EKU_Firmware C/C++ Problem
gmake[1]: Target 'all' not remade because of errors. EKU_Firmware C/C++ Problem
