I was trying to use XGCONF to open a BIOS .cfg file, but couldn't. Please see attached screen shot.
Jianzhong
Jianzhong
Jianzhong,
it's a known bug caused by the call to loadCapsule() - bugs.eclipse.org/.../show_bug.cgi. Please look at the bug for possible workarounds. There is an existing thread with the same error - e2e.ti.com/.../1735066
The workaround that worked for me was to replace the line
var ipc_cfg = xdc.loadCapsule("../../shared/ipc.cfg.xs");
with
You are not using the reference 'ipc_cfg' anywhere, so the workaround should not have any effect on your configuration.
