Tool/software: TI-RTOS
Hi Champs,
I am investigating unexpected pulse on the PWM in this case that defined Int_4
Actually, when we look into oscilloscope, some times "H" term is longer as expect.
So, When we set "all" on the mask interrupt for HWI_Int4 (GPIO interrupt), this phenomenon was fixed it.
For investigating this issue, we would like to disable another Hardware interrupt.
Actually, our use case , we set this GPIO_Int and UART_int as HWI.
But, when we look another HWI category in the .tcf file, system automatically assign,
HWI_IN11(_HSRTDX_xmt),HWI_12(_HSRTDX_rec),HWI_RESERVED1,HWI_INT14(CLK_F_isr).
We tried to disable these interrupt , there is not able to choice disble.
Do you know how to disable HWI for reserved interrupt on .tcf file ?
Kaz
