Tool/software: TI-RTOS
Please find the attachment i observed for uart0 texas used as output echo ,but in my design i have used FOR CAN protocol .,,,and one more question i have designed one board in that i am using TCK,TMS,TDI,TDO FOR programming apart that i am using uart2 pins same pins i connected to GSM module is their any problem..is their any specific team to verifi my design pls help me6567.DATALOGER(1)(1).pdf
Hi Kota,
Not sure if I fully understand your post. There is a pinmux tool you can use that automatically gives you the configuration of the various pins based on which peripherals (e.g. CAN, UART) you want in your system: http://dev.ti.com/pinmux. This tool should give you the pins configuration in a pinout.c file. You basically need to ensure all the settings in the PinoutSet() function in pinout.c is captured in the EK_TM4C1294XL.c file (ie. 'Board'.c file) in your project. The latter has a bunch of functions named 'Board'_init*() that initializes the pins for the various peripherals using calls to GPIOPinConfigure() etc.
Also, if you are looking for help with your hardware design, you may wish to post on the TM4C hardware forum instead:
Vincent
Thanks you for replay ....as per my design i have done pinmux configuration has been done using http://dev.ti.com/pinmux. ...
from that we down loaded pinout.c and pinout.h file after that how to add this files to project and where to add
